2381Buggy Samba Member
Joined: June 18, 2021 Posts: 159 Location: Down South
Posted: Sun Jun 08, 2025 1:22 pm Post subject: 73 Beetle Trans CV boot Replacement -help |
In replacing my cv boots today, I am not sure which way a retainer goes back on the axle.
After installing the new boot, the next step is to reinstall the inside retainer/washer on the axle that the cv joint stops against once installed on the splines.
I found the retainer, which is a little concave, installed one way on one end of the axle and the opposite on the other before removal.
This is not the outer split circlip retainer, but a solid inner retainer. I can't find any info as to whether or not the flat side goes against the cv joint or the concave side.
After a good cleaning and then reassembly of the joints, I was very careful to make sure my joint orientation with regard to the flat and tapered sides of the cage and nut were correct-flats facing outward away from the axle for proper joint movement, but just don't know about this inside clip.
It appears to be called inner joint concave washer. |
modok Samba Member
Joined: October 30, 2009 Posts: 27664 Location: Colorado Springs
Posted: Sun Jun 08, 2025 7:15 pm Post subject: Re: 73 Beetle Trans CV boot Replacement -help |
One would expect concave side of the washer to go against the part with the larger surface, so, the joint. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42532 Location: at the beach
Posted: Mon Jun 09, 2025 12:19 am Post subject: Re: 73 Beetle Trans CV boot Replacement -help |
I don't know Beetles but in 1975 VW deleted those in buses, and said in the tech bulletin that when rebuilt they could be discarded. You might take a look for similar Beetle tech bulletins.
Bus:
Quote: |
... VW dropped the compression washers that used to go on the (Bus) shafts in 1975 https://www.vw-t2-bulli.de/michaelknappmann/tm_h/gross/TM_H_129-1.jpg
Quote: |
An allen Typ 2 Fahrezeugen entfallt mit Beginn des Modelljahares 1975 die Tellerfeder hinter dem Gleichlaufgelenk
translation: From the beginning of the 1975 model year, the diaphragm spring behind the constant velocity joint was eliminated on all Type 2 vehicles |
Quote: |
Die Tellerfeder ist aucj bei Instandserzungen an bisherigen Gellenkwellen (nur Typ 2) nicht wieder einzubauen.
translation: The disc spring does not need to be reinstalled even when repairing existing drive shafts (type 2 only).
_________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
