Random Part Identification
vanillagorilla1969
vanillagorilla1969 is offline
PostPosted: Sun Jun 08, 2025 7:30 am    Post subject: Random Part Identification Reply with quote
Greetings! Weird thing happened and I'm looking for guidance. Doing a brake job yesterday for the 1st time in this car...
Removed LH rear wheel... then removed RH wheel. The drum was stuck, so I put the wheel back on RH drum to assist in getting drum off... Jerking and clunking and then I heard something hit the ground on LH side.
Q1) It seems to be an extra oil seal washer?
-- Nothing looks wrong with the brake assembly or wheel, and it seems to be functioning fine.
Q2) Can the wheel/brake operate correctly with an extra washer?
-- I do not plan on putting washer back on, just wondering why someone might do this and if it could cause problems going forward.
Q3) What purpose would this washer have, if intentionally installed? Why would LH be different than RH?
RH has no such washer. See pics and advise.
*edit to add photo*
Topher
'63 Bug
'73 Squareback
Last edited by vanillagorilla1969 on Sun Jun 08, 2025 2:08 pm; edited 2 times in total
runamoc Premium Member
runamoc is offline
PostPosted: Sun Jun 08, 2025 7:40 am    Post subject: Re: Random Part Identification Reply with quote
probably used as a spacer, or assembled incorrect order. Looks like it's 'inner seal spacer' on a IRS stub axle.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sun Jun 08, 2025 7:59 am    Post subject: Re: Random Part Identification Reply with quote
As for functionality with that extra spacer in place... You ask about brake function, well you have the drum, what does the contact/wear pattern look like?
Also, how good was the alignment of the cotter pin hole with the castellations on the axle nut?
Andy T.
vanillagorilla1969
PostPosted: Sun Jun 08, 2025 9:06 am    Post subject: Re: Random Part Identification Reply with quote
Pad wear was clean and normal.
I removed LH a while ago... as far as I remember, cotter pin was normal placement as well. Doesn't make sense sense to me.
Topher
'63 Bug
'73 Squareback
vanillagorilla1969
PostPosted: Sun Jun 08, 2025 2:10 pm    Post subject: Re: Random Part Identification Reply with quote
[quote="runamoc"]probably used as a spacer, or assembled incorrect order. Looks like it's 'inner seal spacer' on a IRS stub axle.
Thanks for the reply. I know alot of this car was built at a junkyard in Kelso Wa, so random parts wouldn't surprise me.
Would you know what exact purpose would this spacer have, if intentionally installed? Why would LH be different than RH?
Topher
'63 Bug
'73 Squareback
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Jun 08, 2025 2:32 pm    Post subject: Re: Random Part Identification Reply with quote
That particular washer/spacer with the inside chamfer/radius would be the INNER first most assembly spacer that makes the transition from the outer chamfer/radius axle shaft shoulder surface to mate properly to the ball bearing flat surface.
Hopefully its assembled correctly ..
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
mukluk
mukluk is offline
PostPosted: Sun Jun 08, 2025 4:49 pm    Post subject: Re: Random Part Identification Reply with quote
Just a WAG...
Since the car was built in a junkyard, maybe what we're seeing is a transaxle with a '67 long/short axle on the RH side and a '68 long/long axle on the LH side. That additional inner spacer would be about the right width to account for the added spline length of the '68 axle, allowing a stock wide five drum to bolt on. It'd be useful to have a picture of the inside of the drums to see where the shoes were actually contacting. Could also measure the length of the splines to see how far they protrude from the outer spacer to see if they're different side to side.
75-911S
75-911S is offline
PostPosted: Mon Jun 09, 2025 5:16 am    Post subject: Re: Random Part Identification Reply with quote
I've seen such spacers used as Mukluk describes, but on the outside of the drum. To make the castle nut screw on and align with the cotter pin hole,
runamoc is offline
PostPosted: Mon Jun 09, 2025 7:21 am    Post subject: Re: Random Part Identification Reply with quote
they fit over the exposed splines. Just keep tightening until the holes align. Spacers aren't made for that.
75-911S
75-911S is offline
PostPosted: Mon Jun 09, 2025 7:25 am    Post subject: Re: Random Part Identification Reply with quote
On the longer axels, without the spacers (whatever type used) the nut with go beyond the cotter pin hole before it tightens properly.
mukluk
mukluk is offline
PostPosted: Mon Jun 09, 2025 8:45 am    Post subject: Re: Random Part Identification Reply with quote
To spitball another theory, if lug studs have been installed in the rear drums then the spacer may have been added so that the stud heads would clear the brake shoe hardware.
vanillagorilla1969
PostPosted: Mon Jun 09, 2025 4:06 pm    Post subject: Re: Random Part Identification Reply with quote
mukluk wrote:
a WAG indeed
DANG, that appears to be a correct analysis... I measured the length of the splines to see how far they protrude from the outer spacer to see if they're different side to side. They are different and the spacer makes up the difference.
A friend also suggested I measure the drum snouts, which are the same.
Now, when I put back together.. would it make more sense to put spacer on before the drum again, or move the spacer to directly under the washer?
Your help is much appreciated!
Topher
'63 Bug
'73 Squareback
VOLKSWAGNUT
PostPosted: Tue Jun 10, 2025 7:44 am    Post subject: Re: Random Part Identification Reply with quote
Or the spacer was left out and Mr Junkyard just tossed it on to make it work.
67/68 axle reference
aka Ken {o\!/o}
mukluk
mukluk is offline
PostPosted: Tue Jun 10, 2025 12:09 pm    Post subject: Re: Random Part Identification Reply with quote
It definitely couldn't hurt to pull the left axle bearing just to be sure that the inner spacer wasn't left out as per VOLKSWAGNUT's concern, and if all checks out good, I'd put the spacer between the drum and axle nut if there are no issues found when assembled that way.
vanillagorilla1969
PostPosted: Tue Jun 10, 2025 12:27 pm    Post subject: Re: Random Part Identification Reply with quote
VOLKSWAGNUT,
Thanks for the photos and suggestions. Great insight!
mukluk.
Sounds like a great plan. Much appreciated.
Topher
'63 Bug
'73 Squareback
wagen19
wagen19 is offline
PostPosted: Wed Jun 11, 2025 9:25 am    Post subject: Re: Random Part Identification Reply with quote
VOLKSWAGNUT,
mukluk.
Imo, on your rear axle and braking system, some things are mixed up.
What year is your car and trans? 5 or 4 lug? Backing plates with or without holes for trans oil?
Do you have the old style oil slinger till 7´64 and the drums from 10´57 till 7´64?
It seems, there are some IRS and swing axle parts.
VOLKSWAGNUT
PostPosted: Fri Jun 13, 2025 1:28 pm    Post subject: Re: Random Part Identification Reply with quote
I agree.. .Id have to disassemble, inspect and take stock of the situation...
One thing is for certain with Old Vw's .. nothing is certain, never assume, and know ... it most definitely has been worked on at some point.
Axles and bearing and brakes are nothing to take lightly.
aka Ken {o\!/o}
