Is this Distributor Drive Shaft installed correctly?
damagd
damagd is offline
PostPosted: Fri Jun 13, 2025 11:37 am    Post subject: Is this Distributor Drive Shaft installed correctly? Reply with quote
Tried to follow the Bentley install instructions. I have the crank at TDC. Pretty sure that I have it seated. When I rotate the crank, it pushes the drive shaft up a little. Pulled the distributor off of another engine with that engine at TDC, and the slot is lined up differently. Almost flipped around, and it does not push up when I rotate the crank.
uberaudi
uberaudi is offline
PostPosted: Fri Jun 13, 2025 12:08 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
It takes two full rotations of the crank to get back to TDC...maybe you're only halfway there?
You can tell when the dizzy is engaged with the slots when you grab the rotor and see if it spins once the thing is all the way seated. The rotor should line up with the split in the case at TDC.
'84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI
?Waldo?
?Waldo? is offline
PostPosted: Fri Jun 13, 2025 12:22 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
What method did you use to confirm that you are at TDC for #1 cylinder? Without referencing the valve train you cannot tell if you are at TDC for #1 or #3.
damagd
damagd is offline
PostPosted: Fri Jun 13, 2025 12:48 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
I have the plugs out so I could see and I felt with a screwdriver piston number one. And I also had the rocker arms off and readjusted them according to the Bentley.
Wildthings
Wildthings is offline
PostPosted: Fri Jun 13, 2025 3:38 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
There are two TDCs for a four stroke engine, you need to make sure that crank is turned to the correct one, which if the engine will run will be when the rotor is pointed at the #1 spark plug wire. If they engine will not run or has not been run since a rebuilt, the process of determining the correct TDC is more involved, but not a big deal.
damagd
damagd is offline
PostPosted: Fri Jun 13, 2025 4:50 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
Ok, yeah, this is on a rebuild, so I'm going to have to try and figure out if I'm tdc for #1 or #3. If I was on TDC for number three when I thought I was on number one, will that affect my rocker arm adjustments?
Wildthings
PostPosted: Fri Jun 13, 2025 9:57 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
Yes it would affect your rocker arm adjustment, though hopefully you would have noticed something awry with the valves. When at TDC Compression, whether for adjusting the valves or installing the distributor drive, you should be able to rock the crank 45° either side of TDC without either rocker moving.
damagd
damagd is offline
PostPosted: Sat Jun 14, 2025 5:50 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
I didn't notice anything awry, but I don't really know what I'd be looking for either. I'm just trying to put the engine case back together. I did one of these before about 10 years ago and the engine has been running fine. Don't remember having this much confusion over the distributor drive shaft. Maybe I just got lucky. I'll have to try to find a video or something. Thanks for trying to help, but that 45° rocking of the crank and looking at the rocker thing doesn't make any sense to me. Is there an easier way to explain it?
Wildthings
PostPosted: Sat Jun 14, 2025 6:19 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
Set the crankshaft at TDC by aligning the timing marks and then turn the crankshaft in one direction ~45° and then return it to TDC and turn it ~45° in the opposite direction. If neither rocker on the #1 cylinder moves while doing this test then you are at TDC compression and can adjust your valves and/or correctly install the distributor drive according to the book. If however the rocker arms for the #1 cylinder move, you are at the incorrect TDC and need to turn the crankshaft a full 360° clockwise.
Note that the distributor drive may be forced upwards when the engine is turned CCW without the distributor being in place, so you may need to temporarily install the distributor to prevent this. If you need to turn the drive to make it align with how the book shows it installed, you ONLY want to lift it high enough for it to disengage from the brass gear and NO higher. The properly sized (~5/16") dowel forced into the hole in the top of the drive can be used to lift and turn it.
damagd
damagd is offline
PostPosted: Sat Jun 14, 2025 10:03 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
Thanks. That was simple to understand. Just did it and both rockers on #1 moved. So I easily removed the dist drive shaft and both washers that it sits on with a magnet and I've loosened all of the rockers to readjust. I feel better about removing the drive shaft the entire way to make sure that I didn't loose either of the washers by only pulling it up a little and turning it. I'll then reinstall the drive shaft. If I'm understanding the Bentley correctly, I start to install it with the small C on the water pump side and the slot pretty much parallel with the split in the case and rotate it clockwise about 45° so that the slot is lined up with cylinder #1 when fully seated. Is this correct?
DanHoug
DanHoug is offline
PostPosted: Sat Jun 14, 2025 10:33 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
let us know how it goes re-installing the washers. on my 2.1 i could not get the washers past the drive gear while they were on the shaft. and i had a heckuva time trying to slip the shaft into the two washers resting in position in the case even when i had the case split. YMMV.
-dan
www.thefixitworkshop.com
Wildthings
PostPosted: Sat Jun 14, 2025 10:53 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
damagd wrote:
If NEITHER rocker on the #1 cylinder moves while doing this test then you are at TDC compression and can adjust your valves and/or correctly install the distributor drive according to the book.
Sounds like you missed seeing the word NEITHER, please recheck your work.
Wildthings
PostPosted: Sat Jun 14, 2025 10:56 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
You just take a screw driver or alignment bar and slide them down the shaft. Put a thin smear of grease on them first to help hold them in place.
damagd
damagd is offline
PostPosted: Sat Jun 14, 2025 2:00 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
Yeah, they both moved. Neither moved on cylinder number three so I must be TDC on cylinder number three.
DanHoug
DanHoug is offline
PostPosted: Sat Jun 14, 2025 2:51 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
yeah, i could get them in the case but could not align them perfectly to accept the drive, always hung up as the shaft tried to enter the washers!
-dan
Wildthings
PostPosted: Sat Jun 14, 2025 4:46 pm    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
That sounds correct
Povi
Povi is offline
PostPosted: Sun Jun 15, 2025 4:13 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
I just did this a couple months ago after living with it 180 out for a couple of years.
I don't remember what was used, a wooden skewer or a cut down tapered chopstick. Jammed it in there. Pulled it up just enough until the gears disengaged and rotated it. Over rotated it 180 plus so it settles in at the right spot. There was a ridge of gunk in the bore that it caught up on that had to be cleaned. A little bit of 0000 steel wool on wrapped on said chopstick like a q-tip as to get the gunk off
Thank you Wildthings, I want to say that these are your instructions from another thread. It took me a while to get the courage up to do it. The fear of losing a washer was thankfully unfounded.
89' Westy Subaru 2.2
Backtotheeightiesagain
Backtotheeightiesagain is offline
PostPosted: Thu Jun 19, 2025 10:23 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
I was told that it would only go in one way. Rather than argue the point o just moved on.
Hopefully this will educate many.....
Ps if it's a 50/50 chance with 2 TDC ,daft people could be right half the time.
Wildthings
PostPosted: Thu Jun 19, 2025 11:46 am    Post subject: Re: Is this Distributor Drive Shaft installed correctly? Reply with quote
The drive can go in 12 different ways IIRC, and some work better than others and it's always nice to have it done by the book so the wiring harness sits the way the factory intended, and the next time you have to deal with the distributor you don't get the plug wires back on wrong.
