bugger-off Samba Member
Posted: Tue Jun 17, 2025 7:00 am Post subject: Early clutch conversion to late style- advantages? |
One of the arms on my throw out bearing shaft in my '68 broke. Since it needs to be replaced, is there any advantage to converting my clutch components to the '71 and up newer style? |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1050 Location: San Juan Islands
Posted: Tue Jun 17, 2025 10:30 am Post subject: Re: Early clutch conversion to late style- advantages? |
I don't know if there is an advantage of one vs the other. Recently I bought a rebuilt trans and forgot to specify it was a late with guide tube. Box that showed up was a 1970 case I believe? No collar. I used one of the adapter kits:
https://www.kustom1warehouse.net/Throw_out_bearing_conversion_kit_p/113141165bconv.htm
That kit saved me from having to replace the pressure plate etc. Been working great for few thousand miles so far.
-Dan _________________ When I set my timing, why do I flush, then take a pee? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4137 Location: Georgia
Posted: Tue Jun 17, 2025 12:29 pm Post subject: Re: Early clutch conversion to late style- advantages? |
If you have a stock engine, I wouldn’t bother. Just get a heavy duty arm and be done. _________________ Volkswagen!
(Compression 8.7:1) |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 210 Location: Eastern north carolina
Posted: Tue Jun 17, 2025 5:07 pm Post subject: Re: Early clutch conversion to late style- advantages? |
I guess the advantage would be that there would be less of a chance of the release bearing falling of the shaft. I have always thought that the later pressure plate without the center ring engaged a little smoother. Good luck |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79403 Location: Sneaking up behind you
Posted: Tue Jun 17, 2025 5:23 pm Post subject: Re: Early clutch conversion to late style- advantages? |
Does your transaxle have the bungs to drill the 3 holes that hold the centering sleeve? _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Wed Jun 18, 2025 6:39 am Post subject: Re: Early clutch conversion to late style- advantages? |
Glenn, it does not. But I don't think I'd need them if I use this conversion kit from Kustom1, or am I wrong?
I'd like to switch it over. I agree with Bob, it seems like the newer style is a better design.
Cusser Samba Member
Joined: October 02, 2006 Posts: 32994 Location: Hot Arizona
Posted: Wed Jun 18, 2025 6:47 am Post subject: Re: Early clutch conversion to late style- advantages? |
bugger-off wrote: |
That kit looks like it would work; it doesn't appear to need 3 holes to be drilled and tapped, like my own 1970 would if I chose to upgrade with STOCK 1971 parts.
1970 transmission has "ears" which could be drilled and tapped:
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Jun 18, 2025 8:01 am Post subject: Re: Early clutch conversion to late style- advantages? |
Aaaaah, THOSE ears. I was looking online to see what Glenn was talking about and didn't see anything. I definitely don't have those on mine. |
