Driver Door Lock
mellowyellowky
mellowyellowky is offline
PostPosted: Tue Jun 17, 2025 6:52 pm    Post subject: Driver Door Lock Reply with quote
Hi folks! So my driver door lock latch knob thingy came unattached, or at least I think that was the main issue. I thought the lock was "frozen", but I got the latch mechanism off this weekend and everything seemed to work correctly (as far as I could tell). However, after re-attaching everything, I realized that I could manually reach inside the door at work the lock (working the plastic piece up/down), but the key didn't unlock the mechanism. Also, the cylinder felt very spongy and soft.
So my question is: do you think I need a new cylinder? Or is there something else going on?
Regarding the latch and what I noticed - it seemed like I couldn't lock the door (working the lever manually reaching inside the door) unless the door was closed (i.e., the second of the two latches had to be engaged). This seemed different from the passenger door, but it's been so long since the lock worked, I don't remember if that's normal. My key does go in find and turns the mechanism that seems like it should unlock the latch.. but it doesn't seem to turn it enough. Not sure if that's a clue or not, but all this hopefully informs a solution.
Also.. I cannot seem to get the black lock knob re-engaged.. is it just patience or..?!
kamzcab86
kamzcab86 is offline
PostPosted: Tue Jun 17, 2025 8:39 pm    Post subject: Re: Driver Door Lock Reply with quote
mellowyellowky wrote:
it seemed like I couldn't lock the door unless the door was closed... This seemed different from the passenger door...
Driver's door must be closed and latched in order to lock it. All VW's of that era were that way in an effort to prevent locking the keys in the car.
~Kamz Anxious
2016 Golf GTI S
mellowyellowky
PostPosted: Wed Jun 18, 2025 8:00 am    Post subject: Re: Driver Door Lock Reply with quote
Awesome - that's what I figured, just couldn't remember for sure.
mellowyellowky
PostPosted: Thu Jun 19, 2025 7:41 pm    Post subject: Re: Driver Door Lock Reply with quote
So if it's the cylinder, is it worth trying to remove it and fix it? Or just go ahead and get some new ones?
