Vettepilot Samba Member
oprn Samba Member
Joined: November 13, 2016 Posts: 14803 Location: Western Canada
Posted: Mon Nov 04, 2024 2:30 pm Post subject: Re: K & N Air Filters?? |
There is a fellow/company in Europe that makes exactly that with a center mounted air cleaner in Fiberglas. Really nice system but it was priced around $2500 if I recall correctly. Then there is shopping across the pond… _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Mon Nov 04, 2024 3:15 pm Post subject: Re: K & N Air Filters?? |
Yeah. I'm seeing radiator hoses clamped to velocity stacks running to a tractor air filter before I spend 2500$ on an air filter!! Or 1000$!!
Vettepilot |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4061 Location: San Diego
Posted: Mon Nov 04, 2024 3:26 pm Post subject: Re: K & N Air Filters?? |
For guys that dont drive in the dirt or sand, I always though K/N were the best at filtering. They are supposed to filter between 25 and 100 microns
( .00098" to .0039" )
I have a set of Outwears and looking at them with a graduated Eye Loupe, the square holes are between .005 and .010"
A sand particle is roughly .003" |
Posted: Mon Nov 04, 2024 3:27 pm Post subject: Re: K & N Air Filters?? |
Actually, I am feeling something like this:
https://www.cbperformance.com/product-p/7313t.htm
With hoses running up to a home made log in the center up high, with maybe two dual element hat filters on it.
Vettepilot |
Fender38 Samba Member
Joined: April 11, 2015 Posts: 113 Location: Las Vegas, NV
Posted: Mon Nov 04, 2024 4:12 pm Post subject: Re: K & N Air Filters?? |
Vettepilot wrote: |
I always run a two stage, dry paper before oiled foam filter on my offroad buggies, and have had excellent luck with them.
One time, long ago, I installed a PROPERLY OILED K & N filter on a newly built VW engine in a buggy. Over ONE weekend of fairly hard offroad running, the engine ran worse and worse, and started smoking and using a lot of oil.
I found low compression on all cylinders, and tore it down. It was junk!! TOTALLY and completely worn out! Pistons, rings, valve guides, everything! Needless to say, I NEVER used a K & N filter again! EVER!!
So, how and why do they have such a market following?? I can't be the only one with a negative experience. Has anyone here used them offroad with success??
Thanks,
Vettepilot |
Maybe it depends...
It's a different application and not a K&N (but same concept in a reusable gauze filter), on my Golf, I've had one since pretty much the beginning. 165,000 miles later and still runs like new. Oil consumption is literally zero. This style of filter isn't my preference, but I did want the cold air intake, and this is the type of filter that goes with it. My experience tells me it's perfectly adequate, but I don't think I'd do it again. I'm at a place now where I like to keep daily drivers as close to stock as possible.
I wouldn't run this style of filter on my air-cooled engines, and certainly not on anything intended for offroad. So, like I said at the start, maybe it depends. |
oprn Samba Member
Posted: Mon Nov 04, 2024 5:27 pm Post subject: Re: K & N Air Filters?? |
Vettepilot wrote: |
Vettepilot |
Hear you loud and clear, that makes two of us! _________________ Our cars get old, we get old but driving an old VW never gets old! |
oprn Samba Member
Posted: Mon Nov 04, 2024 5:30 pm Post subject: Re: K & N Air Filters?? |
[quote="Fender38"]
Vettepilot wrote: |
Maybe it depends...
I just bought a Jetta with the same air filter and quite frankly I am a bit scared that there is damage already done! _________________ Our cars get old, we get old but driving an old VW never gets old! |
modok Samba Member
Joined: October 30, 2009 Posts: 27677 Location: Colorado Springs
Posted: Mon Nov 04, 2024 8:19 pm Post subject: Re: K & N Air Filters?? |
Why aren't you guys using R2C air filters?
Did they go out of business? Sold out?
Not a perfect solution but, an easy one.
Even if you have to replace the filters often it's easier than replacing the engine. |
DesertSasquatchXploration Samba Member
modok Samba Member
Posted: Mon Nov 04, 2024 8:33 pm Post subject: Re: K & N Air Filters?? |
Good.
I bought a few sets years ago, they self destructed and fell apart by now, but they filtered very well.
My service life expectations are far, far beyond what most hobbits here require, so, small gripe. |
oprn Samba Member
Posted: Tue Nov 05, 2024 6:39 am Post subject: Re: K & N Air Filters?? |
modok wrote: |
Why aren't you guys using R2C air filters? |
To be quite frank I thought they were history. Good to see they are an option again. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Tue Nov 05, 2024 10:49 am Post subject: Re: K & N Air Filters?? |
oprn wrote: |
I just bought a Jetta with the same air filter and quite frankly I am a bit scared that there is damage already done! |
It probably depends on the product they installed and if the PO maintained it properly. If it's some off brand or was never properly cleaned and reoiled, then it could be a problem. I've seen the cheap ones that can be purchased from the local auto parts stores, and you can see actual air gaps in the cotton gauze. The one I have has very dense cotton gauze for the filter material.
Mine is from APR and has a carbon fiber cold air intake. It's very nice quality top to bottom and I've always maintained the filter exactly as per manufacturer instructions.
I can only speak for myself, with 165,000 miles on the clock, it still runs like new. I plan to hit 300,000 miles plus, without giving it a 2nd thought. BTW, all these miles were in a desert environment as well.
I won't do it again, I'm more concerned these days with keeping things simple, and nothing is simpler than the stock air filter. |
oprn Samba Member
Posted: Tue Nov 05, 2024 12:51 pm Post subject: Re: K & N Air Filters?? |
The air filter brand is S&B. I have no idea as to quality. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Backtotheeightiesagain Samba Member
Posted: Tue Jun 17, 2025 3:45 am Post subject: Re: K & N Air Filters?? |
Hi, I used a k+n cone pre filter before a normal air filter.
After 3,000m the paper filter LOOKS clean.
Cannot say that it is without a lab or microscope.
Keyword is cone style =all sealed no leaks around element.
The original kadrons had paper elements (nla).
Ps on the van I wanted to put taller elements in, anybody found paper elements for oval style housing on drla Please?
Seems like k+n only want to sell assemblies not elements.
Are the cb air filters ok for street use, or is there something newer and better??? |
oprn Samba Member
Posted: Thu Jun 19, 2025 2:58 am Post subject: Re: K & N Air Filters?? |
Backtotheeightiesagain wrote: |
If you are talking about the air filters (window screens) that came with my CB linkage and air filter housing kit... no all they stop is 10mm sockets, large sticks, rocks, furry woodland critters and low flying birds! _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Thu Jun 19, 2025 8:52 am Post subject: Re: K & N Air Filters?? |
OK, thanks.
Was hoping the aluminum cased filters were better/filstar ? elements.
I found oval paper filters for mid eighties volvo 240/360 (becoming obsolete).
Hyundai 2.5 h100 diesel.
Some weird one with metal top for mitsubishi shogun.
Both too tall and probably need to make own housing.
Some thing about 80mm tall is needed.
Maybe a round element could be squeezed in.
Without access to a store of filters I'm unlikely to find a fit for K&N housing. |
