phil60 Samba Member
Posted: Sun Jun 22, 2025 10:48 am Post subject: Swing axle rubber boots |
Just as a matter of interest - why must the join not point straight up? Various positions are recommended depending on whose advice you take - 3 o'clock / 9 o'clock, 2 o'clock / 10 o'clock etc but for some reason 12 o'clock is frowned upon. It seems the obvious position so why is that? |
aquifer  Samba Member
Joined: August 30, 2021 Posts: 345 Location: Nebraska
Posted: Sun Jun 22, 2025 10:54 am Post subject: Re: Swing axle rubber boots |
Because the joint/seam doesn’t expand. So when the car is raised and the rear wheels drop down, it puts strain on the boot and would probably cause it to pull off off the hub. I think it has to be 3:00 or 9:00, and not 10/2 for the same reason, but 10/2 is much better than 12/6. At 3/9, the joint can just bend and doesn’t need to stretch.
Edited to add: the only time I’ve ever done it, I did 3:00/9:00 and they’re still holding up after 25 years (or more). I’d be tempted to believe that 4:00/8:00 would be better than 10/2, because of how the boot needs to flex when the car is off the ground. It’s rare that the wheels would ever be very far “up”, but they’re down all the time when the car is lifted. I would think that 10/2 would still put plenty of stress on the seam. I’m pretty convinced that 3/9 is the best position. That way it never “pulls” on the seam, the seam simply flexes. _________________ Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown).
Also looking for used white headliner pieces, both perforated and non-perforated.
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 352 Location: Eastern north carolina
Posted: Sun Jun 22, 2025 10:57 am Post subject: Re: Swing axle rubber boots |
Maybe because when the car is jacked up or on a lift and the axles unload and swing down this may put stress on the top of the boot and if your seam is there it might tear. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25934 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jun 22, 2025 12:09 pm Post subject: Re: Swing axle rubber boots |
Yes the thick rubber seam area of the boot will not stretch or even compress as well as the thinner bubble shaped rest of the boot. Due to this the boot tears up sooner than later when installed in the vertical position.
While we do not totally agree with all the literature VW put out over the decades, in this we do, and is backed up with experience we have had with this.
Below from the workshop manual that is a must for any VW owner to have on hand!!
_________________ In Stereo, Where Available! |
phil60 Samba Member
Posted: Sun Jun 22, 2025 1:17 pm Post subject: Re: Swing axle rubber boots |
That makes sense - thank you all for the explanation |
Posted: Sun Jun 22, 2025 1:40 pm Post subject: Re: Swing axle rubber boots |
phil60 wrote: |
No worries!! That is why the vast amount of us crazies are here!
Personally got into VWs way before the whole internet thing. So got a lot of good info from manuals or busting something that should not have gotten busted. Thankfully the old timers that started out in the 1960s & 70s working on VWs that were generous to take some time out of their busy lives to pass on what they had learned to us. Wish could go back and thank everyone of them, have lost touch with a few, most are known to have passed on.....
When you can someday "Pay it forward". Just do be a little careful when you do. Remember Ted Bundy drove a beetle..... _________________ In Stereo, Where Available! |
Posted: Sun Jun 22, 2025 2:20 pm Post subject: Re: Swing axle rubber boots |
Eric and Barb some of us who started working on vws in the 1960s (like me) are still here and still working on them although not as quickly. Like you said we learned from trial and error and also from manuals. I still find it wonderful that I can go to the internet and have lots of first hand experience(like yourself) right at my fingertips. Charles Manson was also a vw guy! |
EVfun  Samba Member
Posted: Sun Jun 22, 2025 10:30 pm Post subject: Re: Swing axle rubber boots |
Personally I run them at 10 and 2 to the rear and install the axle boots dry. The swingaxles move up and forward and the suspension compresses, and down and forward as the suspension drops below zero camber. The idea is to bend the seam, but not compress or stretch it. If it is pointed below level (9 and 3) it may leak a little as it isn't a well clamped joint, nothing solid is backing the seam except the washers under the screws and nuts.
VW recommends 9 and 3 to the rear, and the use of sealant. _________________
Wildthings wrote: |
viiking Samba Member
Joined: May 10, 2013 Posts: 3160 Location: Sydney Australia
Posted: Sun Jun 22, 2025 11:52 pm Post subject: Re: Swing axle rubber boots |
Bobs67vwagen wrote: |
Eric and Barb some of us who started working on vws in the 1960s (like me) are still here and still working on them although not as quickly. Like you said we learned from trial and error and also from manuals. |
Me too. I was 12 when Dad bought home his blue 64 and then later the 68.
I don't know, but I think our generation "just had a go". There was no internet obviously and if you were rich you might have had a manual and lots of shiny tools.
All I know is that I made a lot of mistakes (which I paid for) but generally once made, I didn't repeat them. It's surprising how much learnt on one marque of cars just translated to other marques. I've lost count of how many cars I've had in my lifetime but I've learned a lot. Not saying I'm an expert, but I know some stuff.
Like a lot of technology, the skills on old cars are disappearing with time. So many trades and professions are not there anymore. For newer cars these days, very little is repairable anymore so all you do is replace things. When I open the hood on my electronic this and that daily driver, I realise I wouldn't be able to fix much on these new cars at all. Old cars are very simple and not complex at all like the newer vehicles.
To get it into perspective if I think back to the time my Dad bought home his 64 (i.e.60 odd years ago). When he bought that, 60 year old cars were those being made at the dawn of car building in the early 1900's. The same thing applied. The skills to keep those early cars had also probably disappeared by the 60's.
Now fast forward 60 years from now into the late 21st century, the fabulous state of the art cars we drive now will also be curiosities and probably no-one can be bothered to fix them either. The only difference will be that the information to do so, will be available over the internet or what it will morph into in the future. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Mon Jun 23, 2025 8:28 am Post subject: Re: Swing axle rubber boots |
If you look closely at the boot before you install it, you will see the thickness is not the same all around. It is thinner/thicker at various "clock" positions. It was engineered to resist tearing and stretching for installation at 9/3. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
