LeeFred Samba Member
Joined: October 13, 2023 Posts: 103 Location: Arizona
Posted: Tue Jun 24, 2025 2:10 pm Post subject: 1974 Super Beetle Speedometer Seal |
I probably need to replace the rubber seal that goes around the speedometer in our 74 SB. The speedometer assembly slowly pushes out towards the driver as the vehicle is being driven. I can't seem to locate this piece of rubber from the usual places - is it reproduced? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11099 Location: Oregon
Posted: Tue Jun 24, 2025 2:16 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
This?
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111957375 _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Tue Jun 24, 2025 2:27 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
No, it's this thick piece of rubber that goes around the speedometer housing and makes a tight fit into the opening in the dash:
Cusser Samba Member
Joined: October 02, 2006 Posts: 33093 Location: Hot Arizona
Posted: Wed Jun 25, 2025 6:23 am Post subject: Re: 1974 Super Beetle Speedometer Seal |
Take the speedometer head to Ace Hardware, and see if one of the big O-rings in the little drawers fits. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2051 Location: Wichita, KS
Posted: Wed Jun 25, 2025 6:51 am Post subject: Re: 1974 Super Beetle Speedometer Seal |
Don't know of any new production for these, but they sell original used ones here: https://www.bugcity.com/shop/shop.lasso?pquery=speedometer+seal _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Wed Jun 25, 2025 1:14 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
Cusser wrote: |
Take the speedometer head to Ace Hardware, and see if one of the big O-rings in the little drawers fits. |
I would think a piece of bicycle innertube would be more appropriate than an o-ring. It's quite a bit wider than your standard o-ring. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4489 Location: viroqua wi.
Posted: Wed Jun 25, 2025 1:44 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
Electrical rubber tape. |
viiking Samba Member
Joined: May 10, 2013 Posts: 3165 Location: Sydney Australia
Posted: Wed Jun 25, 2025 4:12 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
It doesn't have to be a complete "O", like an o-ring.
Just get a flat piece of rubber of the correct thickness and cut it to width and length and just glue it round the speedometer so the ends meet. It's only there to take up the slack between the OD of the speedometer and the ID of the hole in the dash. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 870 Location: Moreno Valley
Posted: Wed Jun 25, 2025 4:33 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
never seen the band your showing but im also not familiar with SB's at all but for most of us we use this ring in the grove around the speedo , shows it fits your year
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111957375 |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26533 Location: Douglas, WY
Posted: Wed Jun 25, 2025 5:28 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
It is not a seal or gasket. It is a ring made out of rubber, ribbed for your dashboard's pleasure. It is only for the 73-79 1303 series Super Beetle, the part linked just above is not it... that one is for models where it mounts to the flat steel dashboard. Not the molded curved dashboard found in a late Super.
I don't know what you call it precisely. Myself, I've called it a mounting or retaining ring. Looking in the old VW parts book they show the speedometer with the ring already on it and not as a separate part.
I've got one around here somewhere, but I don't think it has any kind of number on it. If there was I would have pictured it when I made up this photo of it a few years ago:
_________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
Posted: Wed Jul 16, 2025 9:52 pm Post subject: Re: 1974 Super Beetle Speedometer Seal |
FIXED!
I had to pull the speedometer this last weekend to do some wiring work. When I put the speedometer back in, I made sure there was no excess speedometer cable jammed between the speedometer itself and the bulkhead. That was the issue - too much cable was putting pressure on the speedometer and forcing it out. |
vamram  Samba Member
Posted: Thu Jul 17, 2025 5:37 am Post subject: Re: 1974 Super Beetle Speedometer Seal |
Ah the simple things! Glad you found the issue and posted your fix! _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
