What to run to evaporation chamber
Page: Previous  1, 2
stcj
stcj is offline
PostPosted: Thu Jul 24, 2014 4:08 am    Post subject: Reply with quote
stcj wrote:
I am reinstating the original emission system on my 1969 Californian Ghia to help eliminate fuel smells. I've draw a sketch based on your description. Does this look correct (anyone feel free to chime in)? I wasn't sure if the orange line is correct also what the the diameter of the hard line that runs to the rear (mine is currently missing)? Hopefully this sketch helps out others once it is fixed up.
[/img]
Ok i think in the diagram above i had the orange and yellow wrong, the theory is that the fumes/excess liquid come into the tank at the lowest front (front is front) pipe in the expansion chamber, they then condense when it cools and can run back out that low point, while the higher pipe to the rear of the expansion canister only allows fumes/vapor to travel back to the rear charcoal canister, i've fixed the diagram bellow:
Artistic gearhead
Artistic gearhead is offline
PostPosted: Fri Aug 11, 2023 6:59 am    Post subject: Re: What to run to evaporation chamber Reply with quote
Wow, that is complicated. Thanks for the info. I suspect that my simple hose replacement fix is not going to completely solve this issue. Looks like smog gear has been removed years ago so I will try to route a new vent pipe to atmosphere. With the recommended “shepherds crook”. Thankyou all.
David Bunin
David Bunin is offline
PostPosted: Wed Jun 25, 2025 3:25 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
Hello Forum,
I was referred to this thread from my "New Kid" posting, and I've found this very helpful. For those who don't care to read the other thread, I bought a 74 convertible from my Uncle and I've been tinkering with it to make it as close to 100% functional as I can achieve. Among other things, it has a fuel smell while driving (with the top down). This has made me think the problem is somewhere in front of the driver.
I found most (if not all) of the hoses forward of the dashboard as described here, particularly in the revised sketch at the end above. The most deteriorated one on my car appears to be the half-inch vent line from the tank to the fender, but to be fair I haven't explored how I might inspect inside the fender to the filler cap. The drawing suggests there's another hose that is out of my view in the trunk.
What I'm most puzzled about at the moment is the theory of operation for the expansion tank. As best I can see, mine has a small hose at the front face and another small hose on the rear face, and that's it. Neither hose is located at the bottom of the expansion tank, so neither one is going to drain liquid fuel out of it. How does fuel ever end up in there? If it does, how does it ever get out? If the expansion tank can be a trap for a quantity of fuel, what's the point of it?
David
P.S. Edit: I looked inside the fender, and found that the rest of the filler assembly is visible right there. I also think I see where my fuel leak is coming from. There appears to be a dribble coming from where the metal section of the vent tube penetrates the fender wall, on the wheel side. If the leak is from the metal section rather than any of the rubber hoses, that might be "above my pay grade" and worthy of a visit to a legitimate shop. I think the immediate solution (and this was probably Uncle Nelson's solution too) is to simply not fill the car up with gas in the interim.
P.P.S. Edit: I looked again, and maybe the "blue" line is connected near the bottom of the expansion tank, but on my car this hose route up and over the top of the tank at the outboard edge. Maybe it's supposed to bend the other way and run under the tank back to the Tee fitting? Still, that only takes liquid fuel to the tee fitting. Then what?
jeffrey8164
jeffrey8164 is offline
PostPosted: Wed Jun 25, 2025 3:56 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
Nothing to be afraid of here.
The metal pipe that passes through is just that. A metal pipe. It’s simply held in place by rubber grommets. While a little finicky, I don’t remember it being that big a deal. Just make sure you really have to do it first. When I replaced those grommets the pipe was in fine shape.
Leaking liquid will take the path of least resistance so, where you see it might not be where it’s coming from. I don’t know when or if any of the filler neck hose and gaskets have been replaced or any of the breather lines so any or all of them could have some deterioration going on.
Volkswagen!
(Compression 8.7:1)
jeffrey8164
PostPosted: Wed Jun 25, 2025 4:07 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
These are important.
This is how I routed my breather.
I did delete the expansion tank and charcoal canister from mine to simplify things.
Volkswagen!
(Compression 8.7:1)
David Bunin
PostPosted: Thu Jun 26, 2025 3:03 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
I concur that the fill tube is just a metal pipe in a grommet. That's the largest diameter one, shown here in black.
But my concern is the medium diameter vent tube next to it (shown here in yellow). This appears to be a metal tube that is fixed in place. Possibly welded to the wall it penetrates?
I think my fuel smell problem is with the metal section of the vent line, because on the other side, when I looked inside the fender, I saw this:
I'll guess those crimp-style band clamps on the hose are original? I know that at one point in its life, this car had a fender-bender in a parking lot, and the right front fender was repaired. At least in the vicinity of the headlamp and turn signal. I don't know if the repair area extended this far aft.
Given that the vent tube is darkened for the full visible length here (and assuming that leaks typically don't run uphill) I'm hoping that the issue is with the rubber hose section at the top, and not a pinhole leak or a crack in the metal part.
jeffrey8164
PostPosted: Thu Jun 26, 2025 3:11 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
That hose is definitely crusty.
Volkswagen!
(Compression 8.7:1)
22manybugs
22manybugs is offline
PostPosted: Fri Jun 27, 2025 11:35 am    Post subject: Re: What to run to evaporation chamber Reply with quote
The hose circled in red looks like it has the original crimp clamps, so that hose is probably 50+ years old and is almost for sure a problem. The gas trail is probably from the rubber hose leaking, then the gas runs down the metal hose and down the inside fender. I doubt the metal hose is the problem.
When I replaced that hose on my car, it was impossible to bend the replacement hose 90 degrees without kinking it. It might work okay even with the kink, but there is a 90-degree elbow that you can buy as an alternate: https://airheadparts.com/vw-part/fuel-filler-overflow-elbow-141-201-179/
There should be a small nipple on the other side of the fuel filler neck, it should be visible in the area circled in blue. I don't see it in the photo. Normal diameter vapor line (3.5mm?) attaches to that and goes to another metal pass-through to the inside of the trunk. (That is shown as the orange vapor line in the above emission sketch). That line is easy to miss so it often gets overlooked (ask me how I know Rolling Eyes), it can also be bad and cause gas smells. Do you have another small vapor line connected in that area?
What is the area circled in green? I can't tell. Is it just a shadow or an opening to the fuel system? I am asking because I can't see the line on the other side, so wondering if on '74s maybe VW moved the small line to the same side as the larger line, and you are missing the small vapor line. If it is an opening to the fuel system, that definitely needs to be plugged.
Lon
1969 Karmann Ghia convertible
1971 Westfalia camper
David Bunin
PostPosted: Fri Jun 27, 2025 3:35 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
The one you've circled in green is the "orange" line from the diagram. I'll try to back up and get a wider view here:
The fellow who runs the 1974 Ghia Registry reached out to tell me that my car is one of the newer ones to come off the production line. I'll guess (as you did) that they made a design change and moved the small vent line around to the front to Tee in with the main vent line. The hose routing supports that notion. Replacing that hose (particularly getting a new clamp on it) would/will be a challenge at the unseen end where it passes into the trunk wall.
The 90° bend that you gave the link to, is that a rubber hose or a black metal tube? I can't tell from the description or the picture. They describe it as an overflow elbow, which is a metal tube that is also visible in my image above. (Goes nowhere, open end.)
22manybugs
PostPosted: Fri Jun 27, 2025 11:55 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
Thank you for the wider photo; now I see. That small vapor line also looks very deteriorated and should be replaced. That vapor line on my car looked similar condition to yours, didn't look like it was leaking, but as soon as I started tugging on it, it just disintegrated.
The small vapor line was not difficult to replace. It connects to another metal tube that passes through the body into the trunk. The hardest part is getting a hose clamp up in that tight space - there isn't any space to get a normal screw-type clamp or screwdriver to tighten it. I think I used a spring-loaded clamp (that opens when you pinch the ends with pliers, then tightens when you release it). A zip-tie would probably also work.
The 90-degree bend part is rubber; it replaces the rubber line with the 90-degree bend in your photo. Although I see what you mean about the description not being clear, it calls it an "overflow elbow" and says "goes from filler to tee. The hose from tee to tank is 5/8" x 9" not available". I understood that to mean the elbow replaces the large hose with the bend on the fender side, and the unavailable part is the straight hose in the trunk that can be replaced with 5/8" gas hose. The purpose seemed clear from it's shape, and it fits in that position.
Lon
David Bunin
PostPosted: Sat Jun 28, 2025 4:55 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
Ok, I'm convinced enough that I'm ordering the right part. I've bought the 90° elbow.
I'm going to buy a bunch of the small diameter fuel hose locally to replace the vent lines. I agree the vent hose in this image looks deteriorated, and maybe that's the case, but also notice that this area of the fender has been sprayed with something (underbody coating?) and there's plenty of that on the hose contributing (perhaps unfairly) to a deteriorated appearance. When I touched it, it was still surprisingly supple and flexible. But as noted above, probably still not happy with modern ethanol-infused fuels.
We'll see how bad it really was after I've replaced it.
David Bunin
PostPosted: Sun Jul 06, 2025 10:17 am    Post subject: Re: What to run to evaporation chamber Reply with quote
Here's a question that I felt sure would have been answered already in the conversation above, but I don't see it. Where do you guys buy the 1/8" (3.5mm) hose from?
I thought it would be an easy "get" from any local auto parts store, but invariably when I asked for 1/8" fuel hose they all said, "Like for a weed-wacker or a chainsaw?" or "Like for an RC model?"
I could (and probably should) just remove one of the hoses from the car and take it in to show them, but at the moment it's still drivable. In fact, as the fuel level has gone down so has the fuel smell, which supports the notion that the vent lines are the source of the problem.
I did find small fuel line at NAPA but it looks very different from what's on the car. I found something on Amazon that looks right, but I thought I'd ask you guys for your favorite supplier before I shop blindly online.
I'm not interested in spending much extra for some hose made in Germany. I want the car to be safe on the road. This is maintenance, not a restoration. At the same time, I'm not impressed with the soft hose that NAPA had that looks very different from the original, and makes me think that while it might work, it probably isn't right.
Also, once I have a source, how much do I need? Three meters? Four? I presume I'll end up replacing every original hose.
dingerjunkie
dingerjunkie is offline
PostPosted: Mon Jul 07, 2025 4:34 am    Post subject: Re: What to run to evaporation chamber Reply with quote
Okay...my project doesn't have the expansion chamber, canister or any of the lines present. Searches aren't coming up with appropriate parts, here in classifieds or through the usual marketplaces.
Any non-stock analogues people can share, or examples of modified plumbing for direct-to-atmosphere venting with a filter?
David Bunin
PostPosted: Mon Jul 07, 2025 3:26 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
One local shop asked if I could use "vacuum hose" which (they reasoned) must be at least fuel tolerant, even if it's not actually rated as fuel hose.
Again, I'm not looking for perfect authenticity. I am looking for a material that is fit-for-purpose.
22manybugs
PostPosted: Mon Jul 07, 2025 4:49 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
I went through the same discussion. Local stores didn't have fuel line that small and would suggest "vacuum line", but none of the vacuum line packaging stated that it was fuel resistant. I finally used some small-diameter fuel hose from Amazon.
That was 1 or 2 years ago. I just checked Amazon and the fuel line I bought is not available, so you would have to search to see what's available now.
Below is one from Amazon (not the one I used). 1/8" diameter seems pretty small but maybe it will fit, I think I used one size bigger. If you are replacing all the vapor lines, 6 feet is not enough, you would need at least two packs (12 feet). Maybe even 3 packs (18 feet)? And I would not use the clamps that come with it - get real hose clamps.
https://www.amazon.com/AloneGoer-95001-35003-60M-T...&psc=1
Lon
David Bunin
PostPosted: Mon Jul 14, 2025 3:55 pm    Post subject: Re: What to run to evaporation chamber Reply with quote
Thank you. My order has been placed. The link you gave was for a six-foot section, but they also sell ten-foot lengths, so I bought two of those and we'll see if that does the trick. I'll get real hose clamps.
Page: Previous  1, 2
Page 2 of 2
