Wiring loom routing...
nize
nize is offline
PostPosted: Tue Dec 25, 2012 2:30 am    Post subject: Wiring loom routing... Reply with quote
I am about to do the nose and headlight bulb support on my 54 but since my bus were so bad I have no reference in how the loom travels from the fuse box to the front right chassis frame rail? (I have got a LHD bus).
Is it routed behind the headlight bulb support inisde the bus or does it go inside the front valance?
----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
RockStock
RockStock is offline
PostPosted: Tue Dec 25, 2012 5:05 pm    Post subject: Reply with quote
Nize
the main loom piece travels down in front of the headlight support panel
held in place by double prong clip (A)
then through a hole (B) in the forward area of the passenger front cab floor panel, behind the front valence
then travels backwards on to the inner edge of rhs main chassis rail
RS
headlight support panel has 2 shaped recesses where the loom passes through the forward cab floor area
-StockRocks-
nize
nize is offline
PostPosted: Wed Dec 26, 2012 12:15 am    Post subject: Reply with quote
That was really helpfull pics! Thank you!
1954 Kombi
marius71
marius71 is offline
PostPosted: Wed Apr 18, 2018 1:40 pm    Post subject: Re: Wiring loom routing... Reply with quote
Sorry, I know it's an old thread.
I urgently need the position from middle and the diameter of the two (three) holes discussed here.
1. hole for main wiring loom
2. hole for ?? small cable (brake pressure switch?)
3. speedo wire
If anyone could help out... and yes, only 28 days to go until leaving home. Wink
And no, I can't use the pattern of the sheet metals. Someone welded a later floor in Evil or Very Mad
marius71
marius71 is offline
PostPosted: Thu Apr 26, 2018 5:10 am    Post subject: Re: Wiring loom routing... Reply with quote
Anyone?
Thanks
3. speedo wire
--------- VW ---------
52 BD Type 221
and some others
Merlin
Merlin is offline
PostPosted: Mon Mar 13, 2023 10:06 am    Post subject: Re: Wiring loom routing... Reply with quote
Hi everyone,
I'm sifting through years of forum posts trying to find answers to a myriad of questions.
I am unfortunately a very isolated barndoor owner in my part of the world, so I am heavily reliant upon the Internet community...
After [far too] many years, my RHD '54 Kombi has arrived home, following extensive metal work. It was largely stripped and left for dead several decades ago, so I had precious little to reference and salvage as investigative material.
We've replaced the cab floors and I've only now discovered that there appears to be a dearth of holes for the wiring harness. This is the current setup:
Which holes am I missing?
Critically, does anyone have measurements and dimensions for any missing holes, please?
Thank you.
iowegian wrote:
People who are allowed to have signature lines annoy me.
myklsmyth
myklsmyth is offline
PostPosted: Mon Mar 13, 2023 12:01 pm    Post subject: Re: Wiring loom routing... Reply with quote
Hoping that this might help you a bit. If you need dimensions, I could get them for you. I will say that I don't know if they are different between LHD and RHD but here are a few pics of my 52, LHD front floor. Unfortunately the pass side is rusted and I'm not sure what may or may not have been there. Mike
Merlin
Merlin is offline
PostPosted: Tue Mar 14, 2023 2:00 am    Post subject: Re: Wiring loom routing... Reply with quote
Thank you very much, myklsmyth. Cool
I have asked the question on a FB group too, in the hopes of finding a RHD bus as a reference.
I want to make 100% certain that there are no differences between LHD and RHD in this respect, before we start drilling...
I will update you ASAP and take up your kind offer if they are the same.
BeaterBarndoor
BeaterBarndoor is offline
PostPosted: Tue Mar 14, 2023 5:14 am    Post subject: Re: Wiring loom routing... Reply with quote
Some of the details here may help?
https://www.thesamba.com/vw/forum/viewtopic.php?t=737136&highlight=
https://www.flickr.com/photos/128070606@N02/albums/
Whaaaaat?
Merlin
Merlin is offline
PostPosted: Tue Mar 14, 2023 5:25 am    Post subject: Re: Wiring loom routing... Reply with quote
Thanks, Beater.
Looking from underneath my bus, I cannot see those holes. I definitely think I have a problem on my hands...
sgellis
sgellis is offline
PostPosted: Wed Jun 25, 2025 12:04 pm    Post subject: Re: Wiring loom routing... Reply with quote
Looking for some calcification on the roof wiring for my 54. At this point just need to clarify where the taps are that secure the harness.
Does the harness split at center front and run both side back to the B pillars for the semaphores? If so there should be tabs in the drip rail on both sides? I see no evidence of tabs on the left side drip rails on my 54 but they are very rusty.
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
DSweinhagen
DSweinhagen is offline
PostPosted: Thu Jun 26, 2025 8:13 am    Post subject: Re: Wiring loom routing... Reply with quote
The semaphore harness runs up the center pillar and down each side. There should be tabs down both sides. I can't say for certain on a '54 standard, but I believe they're all that way.
David S
sgellis
sgellis is offline
PostPosted: Thu Jun 26, 2025 8:39 am    Post subject: Re: Wiring loom routing... Reply with quote
Thanks! That is what I thought just wasn't sure enough to go ahead.
RockStock
PostPosted: Fri Jun 27, 2025 1:41 am    Post subject: Re: Wiring loom routing... Reply with quote
These are 4 tabs I could feel on a 55 Deluxe
I couldn’t feel any under the skylights, but I guess there could be a third one on each side there
The open side of the tab faces outwards
-StockRocks-
sgellis
sgellis is offline
PostPosted: Sat Jun 28, 2025 8:46 am    Post subject: Re: Wiring loom routing... Reply with quote
That is quit different than mine. Positioning was likely based on who was on the line that day.
These are copied from what I could see on right side of my 54.
RockStock
PostPosted: Sat Jun 28, 2025 11:42 am    Post subject: Re: Wiring loom routing... Reply with quote
Let’s call them Clips 1 through 6 from the peak crease each side
#2/#3 and #4 were the ones I could feel
Now you’ve pictured it, I can also feel clips #1 and #3
Maybe not all clips were used, and some sat flat?
So trickier to feel. You can’t see them.
6 clips seems overkill, but I’m sure you have it right…so good work
Clips #5 and #6 would be under the skylight on a deluxe
There’s not really enough room to finger up there (with the seal in place)
-StockRocks-
