GBUCKLEY Samba Member
Posted: Sun Jun 29, 2025 4:43 pm Post subject: Repairing pinhole leaks in oil bath air cleaner |
I was prepping my 1970 convertible for engine drop due to considerable oil leak.
Noticed that the removed oil bath was leaking pretty badly. Good news because I don’t have to pull the engine after all.
I’d attempted a fix of leaks in two damaged air cleaners with JB weld, but that was not effective. Anyone have advice on locating all the leaks and properly patching? Keeping it looking good would also be nice. Thanks in advance. George in NY _________________ I smell like Volkswagen. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1764 Location: Niagara Region, CANADA
Posted: Sun Jun 29, 2025 4:49 pm Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
POR15 |
Posted: Sun Jun 29, 2025 6:30 pm Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
What por15 product would be best for pinholes? There is a patch, a spray topcoat, a rust prevention product to be brushed on… _________________ I smell like Volkswagen. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33202 Location: Hot Arizona
Posted: Sun Jun 29, 2025 7:41 pm Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
I'd be surprised if JB Weld wouldn't work, if the surface was taken to bare metal. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jun 30, 2025 2:12 am Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
I know, right. I hold the unit up to the bright sky and apply the JB to the obvious holes. Might have to also repaint with epoxy or POR15 _________________ I smell like Volkswagen. |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1366 Location: South West (Pa.)
Posted: Mon Jun 30, 2025 3:29 am Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
Around 5 years or so ago I had wanted to paint and put a new decal on my oil bath air cleaner. I had 2 of them so thinking I chose the better of the 2 I did just that . After trying to install by filling with oil it started leaking before I could get it installed. Since it was already painted and a new decal on it figured I'd repair it. All I did was coat the inside bottom with black seam sealer. Auto body seam sealer I've used before on welds and such. napa sells it or I've bought it on line before at summit racing. Just make sure to clean beforehand with alcohol and let it dry at least 24 hours. It dries to a hard rubber. Like I said this was 5 years ago and hasn't leaked a drop since. L |
Posted: Mon Jun 30, 2025 4:27 am Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
Looks great. I’m trying that. Thanks all. _________________ I smell like Volkswagen. |
Posted: Mon Jun 30, 2025 5:15 am Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
After posting this I was thinking I may have sealed on the outside of the air cleaner on the bottom so easy enough to go check. After going downstairs to my garage it turns out the seam sealer is on the bottom of my air cleaner still doing it's job. As far as the inside , I have a feeling I put it on both sides. The inside a limited amount. Like I said it's been at least 5 years.
Posted: Mon Jun 30, 2025 5:17 am Post subject: Re: Repairing pinhole leaks in oil bath air cleaner |
GBUCKLEY wrote: |
What por15 product would be best for pinholes? There is a patch, a spray topcoat, a rust prevention product to be brushed on… |
Original. Brush works fine. |
