Gas tank for tube frame buggy question
liquidrush
liquidrush is offline
PostPosted: Wed Jun 25, 2025 12:27 pm    Post subject: Gas tank for tube frame buggy question Reply with quote
Can you guys post some of your gas tank pics? I'm looking for new ideas on size and location. Thanks!
cbeck
cbeck is offline
PostPosted: Wed Jun 25, 2025 2:22 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
10 gallon jaz cell. Foam filled. Roll over valve in the vent, rubber flap on the fill neck. Opaque enough to see the fuel level.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Wed Jun 25, 2025 6:37 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
I baffled, sumped and guaged a SS 11gal tank...
And then shoved it down as far as I could over the trans for a lower center of gravity.
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
oprn
oprn is offline
PostPosted: Thu Jun 26, 2025 4:54 am    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
How is this for redneck? 5 gallon boat tank ratchet strapped to the floor just behind the front beam. Undo the fuel line, pop the ratchet strap and throw it in the trunk of the car to fill next time we go to town. Puts more weight on the front tires and is plenty of fuel for an old guy trail riding locally.
It won't win "Best of Show" for you but it's very convenient and the coyotes, ground squirrels and crows could care less. When they see that red tank they know it's time to scoot or they will catch the dreaded lead poisoning!
Stinky123
Stinky123 is offline
PostPosted: Thu Jun 26, 2025 8:47 am    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
If money was no object....I'd do what Cbeck has, clean, and functional...and safe.
But, if you look in the dictionary under "Cheap-Bastard", you'll see my picture.
Therefore, I did what OrangeCrusher (possibly a Broncos fan?) did, but with Freon tanks....FREE. I'd make them out of the small ones....cut them w/a SAbre saw....you cut the ends out of one, and cut the center out of the others (making a baffle, of sorts) and stick it in there. 3 tanks hold about 10-11 gals (enough for a 3 day week-end at the dunes, and plenty of gas for a weekend at the beach). 2 tanks is about 6 gals. You braze it together and braze on an Ell, and thread in a ball valve from the HWare store.
If you really felt like engineering it....you could put on a clear-tubed gas gage, like on an airplane, where you see the fuel level in a clear plastic tube.
Install it as low in the frame as you can get it. The Center of Gravity....I liked mine in the rear, for the best traction going up hills. But, suit yourself.
ORANGECRUSHer
PostPosted: Thu Jun 26, 2025 8:53 am    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
I will admit, my 11 gallon tank is way overkill. But then everybody who knows me knows I over engineer everything to death. My vw buddy swung by last weekend and was telling me about his conversation with someone else describing me as someone who over engineers everything. lol It kinda shocked me for a second even though I know it's true. But I was thinking, is that a compliment or a criticism? Guess it depends. I like simple too, it just never turns out that way in the end. Probably being raised by my Italian mother worrying all the time showing through.
Brian H.
Dan_Lockwood
Dan_Lockwood is offline
PostPosted: Thu Jun 26, 2025 4:05 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
Brian, since you said that 11 gallons "may" be an overkill, does that mean that my 12.5 gallon tank will be more than enough for a day's outing on the dunes without refueling??? My buggy came with a 7 gallon tank, but it had several dents and major scratches. So, it went bye bye on Marketplace. The guy needed an overflow tank for his wood stove boiler...
Dan
cbeck
cbeck is offline
PostPosted: Thu Jun 26, 2025 5:38 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
[quote="Stinky123"]If money was no object....I'd do what Cbeck has, clean, and functional...and safe.
Guess I also have too much time on my hands. Leaving Gunnison Tuesday morning after labor day and taking the long way home thru Grand Junction to catch I-70 east all the way home. My 7.3 powerstroke had been out there multiple times, this is the first time towing my 30 trailer out there with my 6.7 ps.
ORANGECRUSHer
PostPosted: Thu Jun 26, 2025 8:29 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
Dan
Uh yeah. I've gone all day in the woods. I think i filled up at one point just because the group i was with needed gas. I have a hard time using it up and i usually have old gas sitting in the tank. I don't get out often enough to make use of that 11 gallons. Maybe that will change once I'm done with my latest upgrades. (If i had a dollar for everytime I've said that...). The fuel injected engine i have in that buggy may get better mileage than a VW though.
Brian H.
racecougar
racecougar is offline
PostPosted: Fri Jun 27, 2025 5:37 am    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
Old photo, but this is the 5 gallon cell I'm running for now. It has a typical sending unit wired to a fuel level gauge on the dash and a small sumped outlet going to the external pump.
I may consider swapping to a larger tank over the Winter; haven't decided yet. Thus far, it's been fine.
Stinky123
PostPosted: Sat Jun 28, 2025 2:56 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
11 gals is to much. It will last for a 3 day weekend at Glamis.
7-8 is enough for 2 days.
ORANGECRUSHer
PostPosted: Sat Jun 28, 2025 6:31 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
I guess you can always fill a big tank half way. Then you have the capacity if you need it.
Brian H.
racecougar
PostPosted: Mon Jun 30, 2025 9:21 am    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
Better photo:
Wulfthang
Wulfthang is offline
PostPosted: Mon Jun 30, 2025 8:21 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
Wow, all this talk of "six gallons for running the trails for two days", etc. has me feeling special. I have a twelve gallon tank behind the seats, a five gallon tank up front and a two, a half gallon pony tank strapped to the side and I still worry about running out of fuel on a long off road trip. Course, I'm running a hostile old school Ford V6 with a Holley Flat tracker carb so it's no wonder my gas mileage is less than most.
Augie
Augie is offline
PostPosted: Sat Jul 05, 2025 1:03 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
I made my tank out of two soda tanks from a pizza joint. I never added a gauge but made a motorcycle-style petcock so I have a reserve. Do not go off road or on the beach much anymore, but it is street legal.
liquidrush
PostPosted: Sat Jul 05, 2025 1:52 pm    Post subject: Re: Gas tank for tube frame buggy question Reply with quote
All of your tanks look great, I'm going to keep my round tank and add a sender and flip up cap. Cbeck I've always liked your car, it looks great. We're sort of local, I'm out by wentzville.
