2type2 Samba Member
Joined: June 02, 2002 Posts: 1178 Location: SW Colorado
Posted: Sun Jun 29, 2025 12:48 pm Post subject: Clutch cable length for'65 Frankenbug, all 9are too short |
So my 65 body is on a later chassis, has irs and ball joint beam.( year unknown) The clutch pedal freeplay is about 3" . There is no room left to lengthen cable at the nut.
Given there is only .433 inch/11mm difference between the 54-71,74-79 :2270mm and the 72-74: 2281mm cables -----dont I need more length than that to get to 3/4- 1" pedal play?
At final stages on resto, have not driven bug yet except initially off trailer to shop.Had slight clutch chatter in first getting going. New clutch and plate have been installed. It has 2270 mm cable.
Unless im going nuts, which ain't impossible at my age, what I just read in Bentley is there should be 2mm of free space at nut at the arm when adjusted. What's next step?thanx [/code] _________________ "A life of peace and happiness depends on your own gratefulness" |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25949 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jun 29, 2025 1:06 pm Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
2type2 wrote: |
There is no room left to lengthen cable at the nut. |
Are you trying to say that you can not tighten the nut anymore?????? _________________ In Stereo, Where Available! |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1932 Location: N.W. Georgia
Posted: Sun Jun 29, 2025 1:29 pm Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
Clutch cable Bowden tube in place w proper bow? Clutch cable tube in tunnel intact and tight? _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
2type2 Samba Member
Posted: Sun Jun 29, 2025 1:33 pm Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
I think I got it reversed -- but if I tighten the cable to take up slack there will be no space of 2mm--- like Bently says. I'm at the point where I find it important to review a procedure in the book(s) before proceeding ---- but I'm easily put off track. My brain says tighten it but why does Bently say leave space loose? You can't have slack if you take up the space.
My fault for being too literal, but really getting confused too soon. _________________ "A life of peace and happiness depends on your own gratefulness" |
2type2 Samba Member
Posted: Sun Jun 29, 2025 1:36 pm Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
When I replaced the fuel line in tunnel, clutch tube was OK- and current bowden is correctly bent. _________________ "A life of peace and happiness depends on your own gratefulness" |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2759 Location: Santa Cruz, CA
Posted: Sun Jun 29, 2025 4:18 pm Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
2type2 wrote: |
There is no room left to lengthen cable at the nut...dont I need more length than that to get to 3/4- 1" pedal play? |
Are you saying that the adjusting nut will come off the cable if it's loosened any more, or that it's at the start of the threaded portion of the cable and can't be tightened any more?
If the former is true, just turn the adjusting nut clockwise to take up the free play at the pedal. If the latter is true, and you still have 3" of free play at the pedal, you need a shorter cable.
Five different lengths of clutch cable are available for the Type 1 chassis > Clutch cables
Check the VIN on your pan (located on the frame tunnel near the shift coupler access plate) to see what year it is, then get the right cable for it. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
zerotofifty Samba Member
Posted: Sun Jun 29, 2025 7:21 pm Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
To reduce the pedal freeplay, you need to in effect shorten the cab,e by moving the cab,e adjusting nut towards the clutch arm, i.e. turn the nut so nut travels closer to the front of the car. now if in doing so you run out of thread for the nut to travel on, and free play at the pedal is still to big then you have either or both...
1...Too long a cable for your chassis
2... a defect in...
a... pedal cluster hook to which the cab,e is attached, the hook will wear, the metal thin, and the hook will bend, which will give excess pedal freeplay. once the hook gets that thin and bends, it will soon break and fail, so replace it with new.
b... clutch or throwout bearing problems
c... cable conduit problem inside the chassis tunnel, conduit weld(s) broken loose
d... Improper fitting of the bowden tube
e. busted or disconnected return spring on the lever
f. Pedal stop which is on the floor not adjusted right _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 677 Location: germany
Posted: Mon Jun 30, 2025 3:32 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
2type2 wrote: |
Unless im going nuts, which ain't impossible at my age, what I just read in Bentley is there should be 2mm of free space at nut at the arm when adjusted. What's next step?thanx [/code] |
"All 9 (clutch cables) are too short"!?
If it´s that, what you mean.
Have you all of them already tested?
Since when do you have that issue?
As long as your frame and all clutch parts are original and it´s not an issue of loose tube for cable inside of tunnel, or something like that, I suggest to replace the clutch cable regarding the VIN of frame, not body.
As long as the pan has IRS, it must be later than 9´67.
Clutch cables:
The given length are not allways correct. Mine are from the same source for the followig 3 cables listed.
113 721 335 A, 2190 mm, 1´66 - 7´71
111 721 335 C, 2206 mm, 8´71 - 3´74
111 721 335 E, 2190 mm, 3´74 on
BUT:
A 65 beetle had a 2258 mm cable, 113 721 335 what´s a bigger difference.
In 3´74, the IRS trans had got a longer lever for throw out bearing. |
2type2 Samba Member
Posted: Mon Jun 30, 2025 5:43 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
Not 9 cables, typo, 2 diff cables.... Here's what started my confusion, as I'm guilty of over anylizing things;
Quote Bentley manual page 35 Engine section:
"To adjust the cable, raise the car on a lift or support it on safety stands.Grip the clutch cable with a pair of pliers to keep it from twisting, then adjust the wing nut shown in Fig 14-13 until there is 2.0mm ( about 1/4 inch) clearance between the clutch lever and the wing nut. Recheck freeplay at the pedal to make sure it is within specifications. "
Now this is certainly not the first time I have replaced a clutch cable. My memory is such that I always follow a procedure in the book before/while doing it.
* How can it be possible to achieve a 2mm gap at lever -to-nut, when you are tensioning the nut against the arm to pull the arm forward to eliminate excessive freeplay at pedal end? *
This seems physically impossible- what does Bentley mean by this? Tightening the cable to remove slack at pedal can't allow for'" loose space" 2mm at lever. _________________ "A life of peace and happiness depends on your own gratefulness" |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33092 Location: Hot Arizona
Posted: Mon Jun 30, 2025 6:10 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
I've been adjusting VW clutch cables for 50 years, and I only was concerned with the free play at the pedal (provided that the bowden tube bend is correct).
Don't forget and leave your Vise-Grip pliers on the clutch cable !!! Ask me how I know this ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jun 30, 2025 7:38 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
2type2 wrote: |
This seems physically impossible- what does Bentley mean by this? Tightening the cable to remove slack at pedal can't allow for'" loose space" 2mm at lever. |
Meaning that if someone has a helper push on the clutch pedal that at the rear of the clutch cable the free play should be 2mm. _________________ In Stereo, Where Available! |
Posted: Mon Jun 30, 2025 8:42 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
that that 2 mm dimension is that there is to be 1mm to 2 mm between the thrust surface of the throw out bearing and the clutch release plate.
My Bentley states that.... " You can NOT make this measurement directly, but you can obtain it indirectly by measuring the clutch pedal free play. Measured at the pedal, this clearance is 0.4 to 0.8 inch"
So... Ignore that 2 mm measure. What you adjust to is the PEDAL FREEPLAY OF 0.4 TO 0.8 INCH.
This pedal freeplay of 0.4 to 0.8 inch will give you the1 mm to 2 mm play inside the bell house, which is something that you can NOT measure unless you cut a hole inside the bell house.
Again, IGNORE THAT 1MM TO 2 MM MEASURE, You will obtain that clearance of 1 mm to 2 mm at the throwout bearing to clutch release plate WHEN you have adjusted the pedal freeplay to 0.4 to 0.8 inches
Good luck, Enjoy your Bug, lets see some photos of your Bug!!!! _________________ Sorry About That Chief.
Words to live by. |
Posted: Mon Jun 30, 2025 8:45 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
Eric&Barb wrote: |
2type2 wrote: |
Meaning that if someone has a helper push on the clutch pedal that at the rear of the clutch cable the free play should be 2mm. |
No, that is not correct. that 2mm is NOT the cable free play, rather that is the gap inside the bell house between the throwout bearing surface and the clutch pressure plate ( release plate) See my above post for details. _________________ Sorry About That Chief.
Words to live by. |
Posted: Mon Jun 30, 2025 10:25 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
2type2 wrote: |
...I'm guilty of over analyzing things.
How can it be possible to achieve a 2mm gap at lever -to-nut, when you are tensioning the nut against the arm to pull the arm forward to eliminate excessive freeplay at pedal end? |
zerotofifty wrote: |
Again, IGNORE THAT 1MM TO 2 MM MEASURE, You will obtain that clearance of 1 mm to 2 mm at the throwout bearing to clutch release plate WHEN you have adjusted the pedal freeplay to 0.4 to 0.8 inches. |
Don't over-think it zero's post is correct...this is exactly how it's supposed to work.
2type2 wrote: |
...until there is 2.0mm (about 1/4 inch) |
And for future reference, 2.0mm is about .08"...not .25" _________________ '63 Ragtop (current)
2type2 Samba Member
Posted: Mon Jun 30, 2025 12:13 pm Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
Thanks to all for the clarification. I got it together with the shorter cable but it would have helped to use a few more mm's to pass through the arm hole and start thread. Got about 3/8" at pedal.
Sometimes it seems that the J Muir narrative (re: procedure explanations), while often over simplified, keeps one from " paralysis by analysis" in approaching a problem and solution. _________________ "A life of peace and happiness depends on your own gratefulness" |
2type2 Samba Member
Posted: Sun Jul 20, 2025 1:15 pm Post subject: Re: Clutch cable length for'65 Frankbug, too short,Now Slipping |
Stupid questions on that clutch cable.....The cable was too short to go on lever arm and needed use of prybar to allow catching only a few threads of nut ---Isn't this the cause of slippage on uphill acceleration? Not fully engaged? Pulled too tight? Need another 1/2" or so longer cable.
Puttering around town flats seemed OK, but went uphill l today and able to accelerate to only 50 mph maximum.Loss of accelleration with hitting uphill only. So I do need longer cable? It's brand new plate and disc, btw.
I'm at the point where I'm forgetting a lot procedure even though I've done it before, frustrating. _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Wed Jul 23, 2025 8:12 am Post subject: Re: Clutch cable length for'65 Frankbug, too short,Now Slipping |
2type2 wrote: |
How does the pedal feel?????????????????????
Needs to have that 1/2 to 3/4 inch play between a little spring back and a lot of spring back as the throw out bearing begins to push against the pressure plate. _________________ In Stereo, Where Available! |
Posted: Wed Jul 23, 2025 11:00 am Post subject: Re: Clutch cable length for'65 Frankbug, too short,Now Slipping |
2type2 wrote: |
...went uphill l today and able to accelerate to only 50 mph maximum. Loss of acceleration with hitting uphill only. So I do need longer cable? |
Losing speed when going up hill isn't necessarily a clutch issue, especially if you don't downshift as needed to maintain proper engine RPM. When you give it more gas, is the engine speeding up without a corresponding increase in vehicle speed?
You should feel a solid connection being made as the clutch pedal is fully released and the clutch disc clamps between the pressure plate and flywheel. It's at this point of engagement that you'll feel any slippage if there's excessive disc wear, or the if clutch cable isn't adjusted properly.
As long as you have the necessary free-play at the clutch pedal, and if worn parts aren't an issue, the clutch assembly should be tightly connected to the flywheel when the pedal is fully released. _________________ '63 Ragtop (current)
2type2 Samba Member
Posted: Thu Jul 24, 2025 7:26 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
Definitely needing higher rpm when hit hill, with downshift and attempts to gain speed not happening, can accelerate rpms but still losing speed so gotta be slipping. I got a longer cable to install to allow best adjustment. I will install and test it asap- - all new clutch parts so don't suspect wear or failure and no signs of oil leak.
How can I positively ID the year of my chassis (since '65 body but with irs and bj beam) --- by it's physical characteristics, but not by numbers? The longer cable I got is 90 inch for '72, orig was for '71. Thanx _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Thu Jul 24, 2025 10:08 am Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short |
2type2 wrote: |
How can I positively ID the year of my chassis... |
Find that number here to see what year the chassis is > Beetle VIN / chassis numbers _________________ '63 Ragtop (current)
