Converting to Manual Steering Rack
ProbablyNotIan
ProbablyNotIan is offline
PostPosted: Tue Jul 01, 2025 10:22 am    Post subject: Converting to Manual Steering Rack Reply with quote
Is this a bad idea?
My '86 has power steering, but it's clear that the rack has already been replaced once with a junkyard part and I don't know if I want to do another.
I'm starting to get a whine from the rack and everything looks fine.
I noticed most places only list the manual rack from '80-'85. Is that just because those or the only years that a manual rack was an option, or is there a difference in fitment between the two?
The Brown Van
Senior Platform Engineer | USSF Grassroots Educator | USSF National C License
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Jul 01, 2025 10:37 am    Post subject: Re: Converting to Manual Steering Rack Reply with quote
You need the rack and the steering shaft attached to it to convert properly. It's plug and play.
I think it's a bad idea, especially since new manual racks are criminal shite...
And your spindles are shorter by 10mm at the tie rod end attachment, so you'll end up forcing even more than another factory van with manual rack unless you replace those as well.
They were only offered up to 85 in the US that's why, some Weekender Westfalia in 87 oddly, but all years in Europe.
1988M5
1988M5 is offline
PostPosted: Tue Jul 01, 2025 11:19 am    Post subject: Re: Converting to Manual Steering Rack Reply with quote
My AC isn't working right, should I convert it a no AC bus? No silly, fix the thing. Downgrades are not typically a first choice.
1991 tin top GL
Some BMWs.
SCM
SCM is offline
PostPosted: Tue Jul 01, 2025 12:03 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
My Suzuki Samurai (a MUCH shorter wheelbase than my Westy) is a bear to parallel park with its non-power steering. I can't imagine dealing with that in my van.
Swapping in a rebuilt PS rack is plug-and-play with the exception of flushing the fluid.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
Van den Broke
Van den Broke is offline
PostPosted: Tue Jul 01, 2025 12:55 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
There's an old thread about this topic here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=225260
dhaavers
dhaavers is offline
PostPosted: Tue Jul 01, 2025 1:02 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
Just do it, simpler is better. Just be sure to upgrade to the correct size steering wheel:
Wink
- Dave
"The WonderVan"
ProbablyNotIan
PostPosted: Tue Jul 01, 2025 1:42 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
I guess the idea of "downgrade" is open to interpretation.
As far as I can tell, I'm currently driving with an incredibly inefficient manual rack. Going to a full manual rack setup means less hoses, belts, pumps, fluids, and other points of failure.
I'm not afraid of having to put a little more muscle into turning. It's why I go to the gym every morning.
I am always worried about the fact that this would (appear to) be the second time a power steering rack has failed in this van.
The Brown Van
AndyBees
AndyBees is offline
PostPosted: Tue Jul 01, 2025 1:57 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
I converted my 84 to Power Steering using a unit from an '85 Westy. I had to have the return hose prepared at a local hose shop. I had all the other stuff which was a junk yard pull from many years ago. I was able to fit everything up with the Power Steering Pump that came on the ALH TDI engine. I used the OE Vanagon Power Steering reservoir.
I've never looked back even after later having to rebuild the rack myself. It is an easy job. There is a Thread on how to do the rebuild. I bought a Gates kit off Rockauto.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
SCM
SCM is offline
PostPosted: Tue Jul 01, 2025 2:05 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
I worry about putting extra strain on the steering shaft connections etc. although I guess they would/should have overbuilt that.
As for this being the second failed rack - that easily could be due to metal bits from the PS pump circulating through the system damaging the seals of the new rack. Was the pump replaced and fluid flushed when the second rack was installed?
jlrftype7
jlrftype7 is offline
PostPosted: Tue Jul 01, 2025 2:38 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
As a Manual only Vanagon since it's an early '84, I'll add that you need to think about people parking REALLY close to you in Parallel parking, if that's a thing where you live.
Living in Chicago, we regularly have people with much more Modern vehicles cram themselves up near our bumpers , usually it's the Front one... Rolling Eyes
I've installed a Back Up Camera to deal with watching how much space I've got behind me, but,,,, Laughing Laughing
Anyhow, I TOO appreciate the simplicity of the Manual Rack system, but wish we HAD power steering in City Parking woes at times..
If that's a Non-Issue for you being in Idaho, you'll probably be fine with Manual Steering if you go that route.
‘84 Tin Top - Hilga....Auto
ProbablyNotIan
PostPosted: Tue Jul 01, 2025 2:39 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
This is a fair point. You would hope they overbuilt, but I've owned enough VW's over the years to know that hope is what kills you.
That I don't know. This van didn't come with a lot of documentation. I just was under there working on my fuel lines and saw the telltale grease pen of a junkyard on the side of the rack.
The Brown Van
Van den Broke
PostPosted: Tue Jul 01, 2025 3:46 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
My daily driver for the last ten years is a small Ford station wagon with a de-powered rack. I did pick up a manual rack at the junkyard years ago but haven't gotten around to swapping it over.
I'm strong enough that it's only a minor nuisance.
The family Vanagon has power steering, which is important as my wife also drives it.
jimf909
jimf909 is offline
PostPosted: Tue Jul 01, 2025 4:08 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
Fly, meet ointment:
There are several threads where people go on about how much they love their electric power steering
https://www.thesamba.com/vw/forum/viewtopic.php?t=732157&postorder=asc
https://www.thesamba.com/vw/forum/viewtopic.php?t=731660&postorder=asc
For your consideration.
- Jim
Butcher wrote:
Guilty as charged.
Van den Broke
PostPosted: Tue Jul 01, 2025 5:03 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
If you are starting with a manual steering van it might make sense to consider the electric system, avoiding the long pipes and hoses and tracking down all the stock parts.
fxr
fxr is offline
PostPosted: Tue Jul 01, 2025 6:36 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
^^^^ This - it's what I did - but if you are starting with factory PS, surely it makes sense to repair or rebuild or replace with similar. Especially if there are dedicated rebuild kits available!
Jim Crowther
Vespa GTS 300
uberaudi
uberaudi is offline
PostPosted: Tue Jul 01, 2025 9:23 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
I have the manual rack in my 84 and at some point upgraded to late model spindles and big brakes. I didn't really notice any additional strain to park the van with that setup and rocked it for a couple years that way. Now I have the EPS setup from Slaughterhouse and it's been a pretty incredible jump in refinement. Parking, rough roads, wind gusts, etc don't really raise any sort of alarm anymore, and last I looked their EPS was only compatible with the manual rack.
'84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI
jimf909
jimf909 is offline
PostPosted: Tue Jul 01, 2025 10:12 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
Thumbs Up
- Jim
Butcher wrote:
Guilty as charged.
Captain Pike
Captain Pike is offline
PostPosted: Wed Jul 02, 2025 6:33 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
Do it. Then send me your old "worn out rack". I'll pay shipping.............
LEARN TO SELF RESCUE
....Bad Sneakers....
skemems
skemems is offline
PostPosted: Wed Jul 02, 2025 8:07 pm    Post subject: Re: Converting to Manual Steering Rack Reply with quote
Pretty sure just about any way you look at it, manual is a 100% downgrade. You can go aircooled and take out the wbx which would mean less hoses, belts, pumps, fluids etc... lol. Not trying to give any jabs its just that PS is effective and for many relatively problem free. Unless your looking for horsepower, dont you get 10hp by removing that pulley and belt. Very Happy
Anyway like someone mentioned, there's a good thread on here on rebuilding them, many have done it. Might be worthwhile in looking into that option.
GL
87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project
joetiger Premium Member
joetiger is offline
PostPosted: Thu Jul 03, 2025 7:28 am    Post subject: Re: Converting to Manual Steering Rack Reply with quote
I went from power to manual on an '85 GL many years ago. My power rack was shot and I found a full, pretty much new manual setup in a U-pull-it yard back when Vanagons were plentiful, steering wheel and all.
I liked the simplicity. I liked the bigger steering wheel so much that I later installed one on my Syncro (with power steering.)
Joe T.
'02 Baja-ish Beetle "Bubbles"
