Narrowed beam, full flow oil, freeway flier
K9SWR
K9SWR is offline
PostPosted: Wed Jul 02, 2025 6:52 pm    Post subject: Narrowed beam, full flow oil, freeway flier Reply with quote
I have a couple of questions that I have always wondered about but not found an answer to yet.
Be kind I'm just asking...
-- What it the purpose in narrowing the beam - what does it get you?
-- Full flow oil passages, I can understand but where, how is it done?
-- I'm not completely sure on the freeway flier transmission. Is it a heavy duty model or is it just lower final gear ratio to keep the engine speed down?
I started looking these up but the hits are ginormous.
Thanks
Dan[/list]
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jul 02, 2025 6:59 pm    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Wider tires and wheels, or when you lower the front the tires don't hid the fenders
You plug the output of the oil pump and use a special cover that send the oil out to a hose. Then you drill land tap the case and connect the return hose to it.
It's a marketing term and means different things, usually it's taller 4th gear so you can cruise at a faster speed.
Thanks
Dan[/list]
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
K9SWR
K9SWR is offline
PostPosted: Wed Jul 02, 2025 7:03 pm    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Thanks Glenn. That was quick.
oprn
oprn is offline
PostPosted: Thu Jul 03, 2025 3:42 am    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Just a look cool thing that comes with poor road handling at speed as a side effect. Seems to go hand in hand with the broken rear spring, run on the sidewall of your tires look these days. To each his own...
Worthwhile mod to give you full flow oil filtering. Best done with the engine completely disassembled so the chips from drilling and threading can be cleaned out.
Late transaxle parts put into an early transaxle or... a late transaxle re-named for a higher price. I picked up a good used "Freeway Flyer" at the wreckers for $250. It is bone stock from '73 Beetle. 2800 RPM at 60 mph with the tires I have on the car.
HarrysRatBug
HarrysRatBug is offline
PostPosted: Fri Jul 04, 2025 12:26 am    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Another reason for narrowed beam is some/most disc brake conversion kits and lowering spindles push the wheels out a bit!
zerotofifty
zerotofifty is offline
PostPosted: Fri Jul 04, 2025 3:39 pm    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
The freeway flyer can give higher top speed, but it may also force down shifting to 3rd gear sooner, which can mean slow up hill speed, and also reduced down hill speeds when gearing is used for engine braking.
Freeway flyer is however nice usually when one has a powerful motor. You may not like it so much with a stock little 1200 motor, but a big motor, then yeah, the downsides are not so bad.
It is nice if one installs low profile tires, i.e. small diameter tires. The freeway flyer gearing can compensate.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
zerotofifty
PostPosted: Fri Jul 04, 2025 3:59 pm    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
A simple better than nothing sump filter can be used
https://www.jbugs.com/product/17-2872.html?utm_con...3252261149
I run this on one of me Bugs, I use the washable stainless steel mesh insert. I also run magnetic drain plug in this sump.
On me stock sump on another Bug I run with magnets attached to the steel stock sump plate, they fit under the stock screen I fit about four magnets that measure roughly 3/16 x 3/4 × 5/8 inch in size, they hold fast to the steel stock sump plate.
On my big 2180 cc engine I run a full flow filter
On my type IV engine I run a remote full flow filter
Words to live by.
Abscate
Abscate is offline
PostPosted: Sun Jul 06, 2025 3:16 am    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Don’t forget destroying the market value of your purchase so you can later gripe about not being able to sell it.
Very Happy
NJ John
NJ John is offline
PostPosted: Sun Jul 06, 2025 6:49 am    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Does that happen? It’s a reversible modification.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
CanStan
CanStan is offline
PostPosted: Sun Jul 06, 2025 8:04 am    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Very Happy
Anecdotally, I’d say half (or at least close to half) of the VW’s I see are lowered. So by that argument, you’re actually increasing the value to just as many people as you’re alienating when you go to sell it. Every car that is lowered was done because the owner preferred it over stock.
And ultimately, as mentioned, aside from some extreme examples, it’s all reversible anyways.
jinx758
jinx758 is offline
PostPosted: Sun Jul 06, 2025 8:54 am    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Narrowed beam :
Allows non-stock or wider rims to be mounted. But I really think it's just so the tires don't stick out from the edge of the fender. That's just a "look" thing.
Get therapy !
Full flow :
Provides better filtration of engine oil than was provided from factory. Worthwhile modification. I run a Wix filter on mine.
Freeway flyer :
As Glenn said ...
And it slows the RPMs of the fan resulting in less cooling of cylinders. On the fence about this one.
These vehicles were designed when speeds were not 75mph & majority of the ones on the road weighed 3-4x than an ACVW yet had 4drums.
I cringe when owners say "I want it to compete with modern vehicles". That'll NEVER happen due to not having adaptive cruise control, crumple zones, air bags for collisions, & etc.
My 1776cc has an estmated 70ish hp (engine builder claims more but I have my doubts ... Engle 110 & 8.7CR - no clue on heads). Don't care cuz the Seat Dyno equals fun between lights. It's very torque-ee. It's 4drums I keep adjusted along with the E-brake & cables. I've known for many years the speedometer is 3-4mph off, 70 = 66. I don't have "first-itis", don't mind being passed, keep my head on a swivel, & give plenty of following distance.
It's basically a 4wheel motorcycle.
Enjoy them for what they are & respect their limitations.
Good questions
Sorry for twisted ramblings ... stay safe
jinx
PS
As to lowering :
I've bought many ACVWs thru the years & about 40% were lowered. Absolute worst riding/driving P.O.S.es. Hated every one. Felt every cricket I drove over. The last few I demanded a discount on price. They were like "it looks cool", I'm like "SO ?, that's your opinion & very impractical".
Two car club members have done theirs correctly yet it's still a harsher ride than stock with good components - tolerable.
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
oprn
oprn is offline
PostPosted: Sun Jul 06, 2025 10:01 pm    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
jinx758 wrote:
As to lowering :
^^^This!^^^
Some day I hope to buy another Beetle (late Super or Cabriolet) but I am going to be hard to please because I will want to DRIVE it! I have walked past many many "For Sale" Beetles in the past 10 years for the above reasons. Set up the way most do these days makes them virtually lawn ornaments, garage/curb queens and not at all driver friendly never mind that they would not pass a safety inspection. The cost to "reverse all the down grades would make buying an original untouched Beetle and making the changes I want the better and cheaper option.
Some of these improvements by the way are not reversible as the parts are no longer available new or used.
HarrysRatBug
PostPosted: Sun Jul 06, 2025 10:22 pm    Post subject: Re: Narrowed beam, full flow oil, freeway flier Reply with quote
Very Happy
That will be my son's problem, but he likes it that way too!
