Solex 31 PICT 3 or Brosol 30/31
Marl1993ey
Marl1993ey is offline
PostPosted: Wed Jul 02, 2025 12:26 am    Post subject: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
Good Morning Guys,
just wondering what the difference is in these two carbs? 31 PICT 3 and H30/31. i was under the impresson the 31 pict 3 was the correct choice for my 1.3 AB twinport, but my car seems slightly hesitant and "boggy".
Just wondering if there was a preference? i heard the pict 3 is quite tempremental due to circuitary and the 30/31 is a kind of versitile all rounder.
running a 034 vacuum advance if this makes a difference.
Thanks all for your help Smile
scarabee
scarabee is offline
PostPosted: Wed Jul 02, 2025 5:28 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
The Solex 31Pict3 is the original carb for a 1300 twin port, whereas the Brosol H30/31 is an aftermarket replacement. The Brosol works fine if you jet it properly. I also have a 1971 1300 twin port with its original Solex 31Pict3.
Marl1993ey
PostPosted: Wed Jul 02, 2025 5:32 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
@scarabee thank you for the reply, ive read the 31 Pict 3 is slightly more tempremental that the 30/31. do you find this to be the case?
Cusser
Cusser is offline
PostPosted: Wed Jul 02, 2025 7:42 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
My only input is that my 1600cc DP engine has the Brosol/Solex 30/31 on it (on the adapter) and I'm happy with it.
scarabee
scarabee is offline
PostPosted: Thu Jul 03, 2025 12:59 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
I was having issues with my 31Pict3 and ran a 30/31 for a while. It ran OK, but I overhauled the 31Pict3 and put it back in, mainly because of originality preference. I much prefer the 31Pict3 to the 30/31. Make sure that your accelerator pump operates as it should, i.e., no leaks and spraying where it should. Search The Samba for How-to on this. Throttle shaft bushing repair is also well documented.
ashman40
ashman40 is offline
PostPosted: Thu Jul 03, 2025 4:31 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
Just a note, if you are running a 30/31 carb with an SVDA (034) distributor... the left side vacuum advance port of the 30/31 is NOT the correct vacuum port for that type distributor.
The SVDA distributor requires "ported vacuum". On the 30/31 carb this is the rear-facing bottom right port that is pointed up at an angle. (You can see this port in Cusser's pic above.) So when running an SVDA/DVDA distributor connect your vacuum advance hose to this port on the 30/31 carb.
I'm not familiar with the 31 Pict-3 carb (not common in the US) so not sure if the left side vacuum port is "ported vacuum", or not. On different versions of the Pict carb the left side vacuum port tapped vaccum from different parts of the air flow down the carb. For carbs originally matched to large diameter vacuum canisters the left side vacuum port was connected to (weak) venturi vacuum. This port won't provide the correct vacuum signal to a later small diameter canister distributor which needs a stronger vacuum signal.
AshMan40
BMFBMF
BMFBMF is online now
PostPosted: Thu Jul 03, 2025 5:29 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
I did over 200,000 km on my 31 pict 3, until it wore its bushes on the throttle shaft and started to stall at stops. The 30/31 I've had in there for the last 130,000 km has also been doing fine;-), doing a little better since I jetted it properly, but I put it in originally before the internet.
-----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day.
Failer
Failer is offline
PostPosted: Sun Jul 06, 2025 10:02 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
One caveat that I ran into for putting those on a DP manifold, the adapter that goes between the carb and manifold, it only works with the H30/31. If you try to mount a Solex 30PICT on there, it interferes with the accelerator pump linkage. IDK if you have the exact same arrangement, since my car is an American model but thought I'd mention it.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Jul 06, 2025 5:33 pm    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
I had about 6 or 7 30 pict-1s mounted on dual ports with the adapter and I do not recall any problems with the pump linkage. It was more than 15 years ago so maybe I just forgot. I had generators on all those motors, so maybe the problem was with alternators?
scarabee
scarabee is offline
PostPosted: Mon Jul 07, 2025 6:50 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
On my 1971 1300DP, the dual port manifold has the smaller flange that doesn't require an adapter for the 31Pict3 or H30/31.
Marl1993ey
PostPosted: Tue Jul 08, 2025 4:38 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
@scarabee yes mine was a straight swap, 31/3 really running rough. Swapped back to 30/31 and seems to be running alot better especially in the lower rpm range.
still struggling with hard hot start issue but at least i can drive it around with a bit more confidence and less backfiring.
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Tue Jul 08, 2025 5:39 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
Be careful swapping different styles of carburetors out. The H30/31 is a general all purpose carburetor with many different vacuum fittings on it to allow all the different distributors to work. When you swap it out for a 30 or a 31 pic you have to go the correct way for your distributor or change distributors.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Jul 11, 2025 4:29 am    Post subject: Re: Solex 31 PICT 3 or Brosol 30/31 Reply with quote
Just saw this.
The 31PICT-3 series was intended for the 1300 twin port. And they all were set up for DVDA or SVDA distributors.
Now the Brosol H30/31PICT largely a clone of the 30PICT-3 used on the 1200 engine from 1971 to late 1974 and is set up like that one was for a vacuum-only distributor, but you can use the angled vacuum port they added at the right rear of the carburetor for ported vacuum used on an SVDA. However it's not exactly a good place to route a distributor vacuum hose over to. The last time I messed with one for testing purposes, I did this to keep it from contacting the throttle arm.
Andy T.
