Weber 34 ICT fuel line routing
Mr Margaret Scratcher
Mr Margaret Scratcher is offline
PostPosted: Wed Jul 02, 2025 3:48 pm    Post subject: Weber 34 ICT fuel line routing Reply with quote
I got a pair of 34 ICTs a while back but they didn't come with any fitting instructions, and I wanted to confirm the fuel line routing.
Is this right?
Is the fuel hose okay resting on the tinware?
daveblank
daveblank is offline
PostPosted: Wed Jul 02, 2025 6:45 pm    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
I would try to secure them. Over time them rubbing on the tins due to vibration could wear a hole in the line
gtixpress
gtixpress is offline
PostPosted: Thu Jul 03, 2025 8:21 am    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
Is this right?
This looks like a manifold vacuum line, not fuel.
Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible
boxer74
boxer74 is online now
PostPosted: Thu Jul 03, 2025 9:22 am    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
Is this right?
It's a balance tube and should be run to the other manifold, not connected into the fuel system.
74 Super
84 Westy
PostPosted: Thu Jul 03, 2025 4:02 pm    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
Is this right?
Yep, that's the balance tube, but it is very snug against the HT lead - are there different (right angled?) leads that are more suitable?
PostPosted: Thu Jul 03, 2025 4:03 pm    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
Yeah this is what I was thinking - what's the best way to go about that?
cletus_zuber
cletus_zuber is offline
PostPosted: Thu Jul 03, 2025 4:43 pm    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
One way is to protect it. take a piece of your extra fuel line, split it length wise, wrap it around the existing line so it rubs against the tin. secure that to the line with a couple of zip ties.
HPMX 40's & 019
PostPosted: Fri Jul 04, 2025 3:47 am    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
I like that idea
mikedjames
mikedjames is offline
PostPosted: Fri Jul 04, 2025 5:26 am    Post subject: Re: Weber 34 ICT fuel line routing Reply with quote
Is this right?
It is easier to find an elbow for the balance hose. Or even block it off and drill and tap somewhere more sensible for the fitting ( like pointing straight out to the side on the manifold.)
As the hose will also get in the way of a spark plug socket spanner. Which cannot have a 90 degree bend ..
Ancient vehicles and vessels
