Engine Serial numbers? Whats it mean?
Livens
Livens is offline
PostPosted: Thu Sep 15, 2005 6:57 am    Post subject: Engine Serial numbers? Whats it mean? Reply with quote
Hi,
I am trying to determine if my engine is the original that came with the car. Its a 1972 SB.
The engine has this stamped on the front:
AE 606761
Is there a chart somewhere that can tell me anything about this serial number? I looked here:
http://www.bugauto.com/volkswagen/index.php?action=VW_Type_1_Chassis_Engine_Serial_Numbers_1949-1979
but mine didn't seem to fit with the 1972's listed.
Thanks,
Jeremy
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Sep 15, 2005 7:02 am    Post subject: Reply with quote
It says your's is a 72 engine (AE 606 761)
1972 112 2000 000 AE-0-558-001 (USA)
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Livens
Livens is offline
PostPosted: Thu Sep 15, 2005 8:47 am    Post subject: Reply with quote
Thanks Glenn Smile
jgaudiello
jgaudiello is offline
PostPosted: Sat Sep 17, 2005 1:34 pm    Post subject: Chart Reply with quote
I am also trying to figure out the year my engine was made. I have a 72 standard with an engine # of AE 912 149. If I am reading the chart correctly, its a 72 engine as well????? Can anyone verify that for me? Thanks!
rayzor30
rayzor30 is offline
PostPosted: Sun Sep 18, 2005 9:13 pm    Post subject: Serial # doesn't seem to fit the chart Reply with quote
I hate to seem so stupid but I cannot make heads or tails of this. My engine number does not seem to fit the chart located in the post above. I could use some help with this one. Here is the number from the small plate attached to the flange below the alternator stand. To the left of the number there appears to be a circle with some lines coming out to the left, something like the reverse of a Detriot Red wings symbol. Its been partly removed so I cannot make out what it is but I thought it might help ID the thing. Its followed by the stamped numbers below.
# B 5561 AD 337781
Its in a 79 SB vert #1592036475 but I do not know if its original to the car. I suspect it is not.
Thanks for helping me track down the items in my frankenbug.
sguarcello
sguarcello is offline
PostPosted: Fri Jul 04, 2025 10:01 am    Post subject: Re: Engine Serial numbers? Whats it mean? Reply with quote
I know this is an older post and I am wondering if you are still out there? I have the same question about serial number. I too have the little plate rivetted to block and a simlar serial number. Do you have any info to share???
Thanks in advance.
1979 Convertible Super Beetle completely rebuilt
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Fri Jul 04, 2025 10:37 am    Post subject: Re: Engine Serial numbers? Whats it mean? Reply with quote
I believe that to be a rebuilt engine case tag put on by vw at sometime in the past.
