'59 Karmann Ghia fever
Page: Previous  1, 2, 3 ... 365, 366, 367
kingkarmann
kingkarmann is offline
PostPosted: Wed Jun 11, 2025 3:56 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Trust me when I say your contributions to our community have been outstanding.
Whether you sell or not you have left some valuable information.
Thank you Cool
Trylon
Trylon is offline
PostPosted: Wed Jun 11, 2025 4:15 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Thank you Cool
What a sweet sentiment King!
Thanks for your help and continued interest.
1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel!
Trylon
Trylon is offline
PostPosted: Mon Jun 16, 2025 11:24 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
It’s out!
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Marcdeb
Marcdeb is offline
PostPosted: Mon Jun 16, 2025 11:39 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Applause Applause Applause Applause Applause Applause
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
Trylon
Trylon is offline
PostPosted: Thu Jul 03, 2025 10:17 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Back on this:
I believe this is the last system that we haven’t looked into and, as you might expect, it seems the PO left his mark here as well:
The first axle bearing (driver’s side) seems to be functioning as expected while the passenger’s side bearing spins freely and seems to not be fully seated in the housing.
Thoughts? What’s a novice mechanic to do?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Fri Jul 04, 2025 9:10 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Oh, I almost forgot— I promised entertainment for expertise:
Ok, your turn.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Sat Jul 05, 2025 5:32 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
So I am wondering what caused that transmission fluid to leak on the driver’s side. I thought it was the boot but upon inspection it seems intact. The large o-ring, although I have yet to remove it, also does not seem to have any issues. The one thing that is odd though is that there seems to be a single paper shim. Perhaps it is two stuck together but I am suspicious that it was of an insufficient thickness as the axle simply flops about. I believe there is supposed to be some resistance?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
John Moxon Premium Member
John Moxon is offline
PostPosted: Sat Jul 05, 2025 8:53 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Have a looks at Pete's YouTube videos on Swing Axle Installation Parts 1 & 2
John.
Trylon
Trylon is offline
PostPosted: Sat Jul 05, 2025 10:49 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Thanks John! As you might imagine, I have been voraciously consuming YouTube videos on the subject. I have yet to find these though.
As I circle around our current project (and now I have ChatGPT to consult, albeit cautiously), it is my current understanding that the axle shaft should be dry. It is wet along its entire length! Further there is pooling of gear oil in the housing. The conclusion to draw from this seems to be that the inner axle seal has failed. It also seems to be the case that this can occur if the paper shims are not of the proper thickness. Sigh… I have yet to measure but I have yet to see a single case where one such shim is sufficient. Seems as though someone thought is was simply a gasket and, well, why waste another?
So it looks like we have to dig deeper. Gotta find a puller for this bearing…
[edit] Well it seems that the axle is indeed supposed to be wet in a swing axle setup—
From Rod and Dave:
If you have a swing axle, the bearings are harder to get out as you need an "inside" puller to grab the inside of the outer bearing race (after removing the cover plate inside the brake assembly of course). The only other way to get this off is to remove the whole axle and axle-tube from the car and tap the gearbox end of the axle so it pushes the bearing out of the outer end (using the axle itself to push the bearing out). The bearings are not really tight in the tube - just nothing to grab on to to help remove them. Once again, when taking the brake assembly off the spring plate - make sure you mark them so you can re-align them on re-assembly. There is a "v" notch in the top of the brake hub assembly to help you with this - just make a mark on the spring plate next to it.
These bearings use oil from the gearbox which sloshes up the axle tubes and sits behind the bearing. Low oil in the gearbox can therefore cause dry wheel bearings (the gearbox must be filled with 80w90 or 85w90 Hypoid Gear Oil until it runs out the filler plug in the left side of the gearbox).
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Sun Jul 06, 2025 5:21 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Okay, passenger’s side opened:
I was surprised at the emptiness found haha!
Also, have finally discovered the number of the transmission:
Nose cone is next, then a parts list for sealing this all back up again.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
kingkarmann
PostPosted: Sun Jul 06, 2025 8:19 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Doing this kind of work is easier when you have a nice little 914 to clear your head after a day of wrenching.
Your in deep now.
That will look great after a good powerwash Cool
Trylon
Trylon is offline
PostPosted: Sun Jul 06, 2025 8:40 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Your in deep now.
Ha! Don’t you know it!
Off to Lime Rock next Sunday:
FCP Euro Sunday Motoring Meet at Lime Rock Park - VW/Audi/Porsche/Mercedes
https://www.eventbrite.com/e/fcp-euro-sunday-motor...7093833419
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
kingkarmann
PostPosted: Sun Jul 06, 2025 8:46 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Trylon wrote:
Your in deep now.
Pictures Please!!
Trylon
Trylon is offline
PostPosted: Sun Jul 06, 2025 9:20 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
kingkarmann wrote:
Trylon wrote:
Your in deep now.
Pictures Please!!
I fear most cars will be on the new side but will search out the interesting ones and create a Google album of them for your viewing pleasure King.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Sun Jul 06, 2025 9:37 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Meanwhile, here’s an album of last year’s Bring a Trailer Alumni event:
https://photos.app.goo.gl/xg2U1YXAiz45ickp8
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Braukuche
Braukuche is offline
PostPosted: Sun Jul 06, 2025 11:58 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Wow, some gorgeous cars there!
Pretty hardcore of you delving into mysteries of the transaxle. Good luck with it.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
Trylon
Trylon is offline
PostPosted: Sun Jul 06, 2025 12:01 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Yeah, it was a fun meet-up!
I am hoping to go no further in than simply replacing the o-rings, shims, and whatever the nose cone requires (gasket?). It just was all so wet it would have been remiss to not take the opportunity to at least attempt to slow down the leaks.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Mon Jul 07, 2025 12:17 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
And, lastly, the nose cone.
There were no washers for the attaching nuts.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Fri Jul 18, 2025 12:43 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Such slow going.
So it seems likely that the nosecone seal might have been the reason I had to pull the transmission — transmission fluid was leaking from that general vicinity and it was not intact.
Of course, the seal that came with the kit is not the right one.
Found the right one on JBugs. Another shipping charge, another week.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Page 367 of 367
