Which one is the correct steering wheel?
CoastalBug
CoastalBug is offline
PostPosted: Fri Jul 04, 2025 3:36 am    Post subject: Which one is the correct steering wheel? Reply with quote
My '68 came with a steering wheel from a '72 or '73 I believe, so it's one of the first things I'd like to change out. I'm just unsure as to which style would be the correct one. I've seen many peoples 1968's with the horn ring, and without the horn ring. Was there a determining factor when these were built? Mine was built in Oct of '67 for the '68 model year in Germany.
Chris - 1968 Beetle Sedan, a book, and a lot of determination.
baldessariclan
baldessariclan is offline
PostPosted: Fri Jul 04, 2025 8:51 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
You may want to review this thread for further information on which steering wheels were used on what years: https://www.thesamba.com/vw/forum/viewtopic.php?p=10175381
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Fri Jul 04, 2025 9:10 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
Hey your 68 being a US spec bug came with the black wheel and the horn ring and the black plastic center . The horn ring would have been chrome.
CoastalBug
PostPosted: Fri Jul 04, 2025 9:58 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
Thanks Bob!
my3bugs
my3bugs is offline
PostPosted: Fri Jul 04, 2025 10:03 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
here is the 68 owners manual to look over .
https://www.thesamba.com/vw/archives/manuals/1968b...ransit.pdf
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Fri Jul 04, 2025 10:19 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
This is what a '68 steering wheel would look like when new:
From '60 (I believe) - '66 they looked like this:
I've seen the earlier style horn ring used on later steering wheels and visa versa. That said, you will be unable to use either of these stock steering wheels on your bug because you have a '72 - later steering column ... which is a different animal. Personally I don't care for the appearance of the '72 - steering wheel and would want to change it out as well. Unfortunately you'd need to select an aftermarket style with an adapter. There are a variety of styles to choose from, but none look like the stock '68 wheel.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
Bobs67vwagen
PostPosted: Fri Jul 04, 2025 10:29 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
Or I guess if you wanted to put in the work( it's really not that hard) you could get a 68-71 locking column with key and swap it in so you could put the stock steering wheel back on it.
PostPosted: Fri Jul 04, 2025 10:33 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
More steering wheel minutia available here :
https://www.wolfsburgwest.com/wired/wired_04_00/wired_04_00.htm
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
my3bugs
my3bugs is offline
PostPosted: Fri Jul 04, 2025 11:13 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
lots of this info here too .
if you want the horn ring this is what to look for
if just the bar look for this
CoastalBug
PostPosted: Fri Jul 04, 2025 12:25 pm    Post subject: Re: Which one is the correct steering wheel? Reply with quote
OldSchoolVW's wrote:
you will be unable to use either of these stock steering wheels on your bug because you have a '72 - later steering column ....
I don’t think the seller swapped the steering column. Just the wheel.
Bobs67vwagen
PostPosted: Fri Jul 04, 2025 2:00 pm    Post subject: Re: Which one is the correct steering wheel? Reply with quote
I may be wrong but I think the 72 and newer columns are different and the earlier wheel will not work with the later column. Someone else please weigh in on this to fact check me-thanks Bob
CoastalBug
PostPosted: Fri Jul 04, 2025 2:02 pm    Post subject: Re: Which one is the correct steering wheel? Reply with quote
I’ve sent him a text message to confirm.
ETA: I just confirmed that the steering column is what the car had. FWIW, the steering wheel is held together with electrical tape at the moment. So unless the splines are completely different, it’s been rigged to work.
PostPosted: Fri Jul 04, 2025 2:42 pm    Post subject: Re: Which one is the correct steering wheel? Reply with quote
I looked into this a few years ago with several sources. I was told that the splines were different and one could not put an earlier steering wheel on a '72 - later bug and that no adapters are made that would make one work either. The only option if you REALLY wanted the correct stock steering wheel was to change out the column. If that is the correct steering column for a '68, it would be interesting to see how the PO got the later steering wheel to work on it.
Did the car have the correct-for-'68 steering wheel on it before the later style stock one was put on ... or did the later stock one replace an aftermarket wheel?
BTW ... none of us are trying to rain on your parade. Just hate to see you go to the time and expense of trying to get the earlier stock wheel on that column if it is designed for the later wheel.
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
viiking
viiking is offline
PostPosted: Fri Jul 04, 2025 5:17 pm    Post subject: Re: Which one is the correct steering wheel? Reply with quote
This might help. May not.
Here are the photos of my original (been in the family since new) February 1968 German Euro beetle showing the wheel cancelling ring and the column assemblly. If you blow it up you may be able to count the number of splines etc.
Admittedly it is RHD but that shouldn't be an issue as the wheel and column were just moved from the LHS position to the RHS unmodified. That is, the indicator stalk for us in RHD world is on the wrong side i.e. the same side as the shifter.
I can confirm for certain what others have said. Black steering wheel with chrome D ring.
PostPosted: Fri Jul 04, 2025 7:50 pm    Post subject: Re: Which one is the correct steering wheel? Reply with quote
In the meantime, you could get one of these. Trust me, neither you nor anyone else will notice the late style steering wheel. Wink
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
Bobs67vwagen
PostPosted: Sat Jul 05, 2025 5:03 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
Wow, I never cared much for steering wheel covers but that fluffy thing could be a game changer. I'll get one and put in on our riding lawn mower for my wife! Good stuff
PostPosted: Sat Jul 05, 2025 7:40 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
Not sure what you feed it. Might want to take it to the vet for a rabies shot.
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
CoastalBug
PostPosted: Sat Jul 05, 2025 10:11 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
Hmmm…. Looks like I won’t be able to go back with the original.
Bobs67vwagen
PostPosted: Sat Jul 05, 2025 10:47 am    Post subject: Re: Which one is the correct steering wheel? Reply with quote
Try to get the correct column with a key. You can probably have the existing column out and the replacement installed in about 2 to 3 hours. I have seen them for sale in the samba classifieds. Or if there are any wrecking yards near you there may be a bug in there you could pull one from. 68 to 71 should work. There was a 70 in the pick and pull near me about 1 month ago but it's gone now. Good luck-Bob
cletus_zuber
cletus_zuber is offline
PostPosted: Sat Jul 05, 2025 6:05 pm    Post subject: Re: Which one is the correct steering wheel? Reply with quote
.I think you are getting some bogus information. The splines didn't change until 74. A 72 wheel will fit on your 68 just fine, a 68 wheel will fit on a 72, but it will hit the column mounted wiper switch.
HPMX 40's & 019
