Unused attachment points in Weekender interior.
vanagonjr
vanagonjr is offline
PostPosted: Fri Jul 04, 2025 12:31 pm    Post subject: Unused attachment points in Weekender interior. Reply with quote
Can someone tell me what this hole on the lower corner is used for ?
Also, in the top of the photo is a Phillips pan head screw into a small welded plate that does not appear to be used either.
Side note-anyone know where I could get a plug for this oblong hole in the floor. I’m missing one of the four.
Extra points for one for the no longer used ECU harness hole, but being round, that should be easier.
GreggK
GreggK is offline
PostPosted: Fri Jul 04, 2025 1:23 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
Almost positive the Philips screw on the upper deck is for the seat/bed hinge bracket.
'86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady
vanagonjr
PostPosted: Fri Jul 04, 2025 1:30 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
Interesting, because they aren’t being used on my van. Wonder if I left something out last time I pulled the interior?
?Waldo?
?Waldo? is offline
PostPosted: Fri Jul 04, 2025 1:31 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
I've made several large grommets for round or irregular holes like that using 1/2" thick rubber, cutting it similarly shaped but larger than the hole, and then making a shallow slice around the perimeter.
GreggK
GreggK is offline
PostPosted: Fri Jul 04, 2025 3:14 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
The part I'm pointing to in the picture is where the bracket sits and the screw goes through into the body. Terrible picture but it's the only one I could find. It wa in the classifieds.
MayorMcCheese
MayorMcCheese is offline
PostPosted: Fri Jul 04, 2025 6:19 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
The ECU hole should be 2". Find a 2" plug
syncrodoka
syncrodoka is offline
PostPosted: Fri Jul 04, 2025 7:34 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
Body plug
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Jul 05, 2025 1:35 am    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
The M6 threaded hole is for a Westfalia weekender bench.
vanagonjr
PostPosted: Sun Jul 06, 2025 7:54 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
I perused Ace, Lowe’s & Home Depo.
The largest they sell is 1-1/2” (as you stated, hole is 2” / ~50.5mm measurement)
The heater holes are 1-1/16”. (27.2mm)
I found 1” and 1-1/4” metal plugs.
Note: BusLab does sell plugs that fit the heater holes.
The elongated plug remains elusive.
I can fabricate something, but was hoping for a simple quick solution. For now it’s gorilla tape. I might try McMaster, but now it’s getting ready for West River Westies (VT), followed the next weekend by Bike Hoopla (western MA) and then Jerry Jam (VT)
vanagonjr
PostPosted: Sun Jul 06, 2025 8:00 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
Yes, the ones on the floor I’m using (although I think they may be M8, but I shouldn’t doubt you!) I just installed the seat today and noted a couple of other curiosities that would qualify me for the dull men’s club. Perhaps, I’ll post later to bore everyone.
The sidewall hole is unused (and the top threaded one mentioned with screw installed). Just curious as to their function.
Maybe for tin top rear seats?
Timwhy
Timwhy is offline
PostPosted: Mon Jul 07, 2025 3:41 am    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
This may work for the ECU hole. https://www.napaonline.com/en/p/NOE6004013?srsltid...ry=PICK_UP
HD has other 2" plugs, for pipes
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Jul 07, 2025 11:40 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
No I'm talking about the M6 on the top , over the engine, same level as the engine lid.
vanagonjr
PostPosted: Tue Jul 08, 2025 10:10 am    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
Hmm, mine is not using those M6 upper attachment points. I put the seat back in yesterday - I don;t think I am missing anything-I hope! I wish I had taken pictures for future reference, but I did locate this one
I found someone else stating the same:
Altoona wrote:
I think the Weekender bench hinges are significantly different than a full camper. The Weekender bench sits lower when in seat mode but folds out to the same height as a full camper when in bed mode. The Weekender hinges don't have those mounting bars that extend towards the rear and affix to the top of the rear deck.
I'm at West River Westies this weekend, I'll try to remember to poke around a few man - mind you all for this geek's curiosity's sake.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 09, 2025 11:43 am    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
I shouldn't be on TheSamba late at night, I meant Westy camper but was reading weekender Rolling Eyes Rolling Eyes . But the body shells were made the same way for both , just the interior varies, that's why it's so easy to retrofit them.
?Waldo?
?Waldo? is offline
PostPosted: Wed Jul 09, 2025 12:32 pm    Post subject: Re: Unused attachment points in Weekender interior. Reply with quote
I just made one last weekend for a 1.5" X 2.5" oval hole in an '85 Adventurewagen I own. I had the rubber on hand - left over 3/8" thick sheet that I bought previously for a different project. Making the grommet took less than 20 minutes to cut it out and install it. It would have taken me longer just to drive to the local hardware and look at the grommets that were all too small... Smile
