Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 446 Location: Clare MI
Posted: Mon Jul 07, 2025 12:04 pm Post subject: 002/091 Bell Housing Starter??? |
Hello again,
I have a 5-rib with an 091 bell housing transaxle in my sand rail build. I have a Type 1 2276 stroker motor that will be built and used in it.
I picked up an 091 front bell housing at a swap meet this spring and it's going to be mounted onto one of my three motor stands and I hope to use it as a start up stand when the motor is completed.
On my sand rail 091 bell housing, I have the correct 091 adapter and TDI starter set up. I really don't want to pull the parts from my sand rail bell housing to the run stand every time I want to fire up a motor.
My question, what starter do I need to buy for the 091 bell housing with a Type 1 motor and 12v flywheel? Do I just purchase a '76 bus starter?
Thanks, Dan |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4599 Location: Fair Oaks/Orangevale, CA
Posted: Mon Jul 07, 2025 3:33 pm Post subject: Re: 002/091 Bell Housing Starter??? |
Yes you need a starter for the 091. Starter has to throw further out, and inside bell housing is deeper.
There has been others that milled the 091bell housing at starter location to use a standard Bug starter. I think it does require some filler weld in one place. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Jul 07, 2025 4:00 pm Post subject: Re: 002/091 Bell Housing Starter??? |
jsturtlebuggy wrote: |
There has been others that milled the 091bell housing at starter location to use a standard Bug starter. I think it does require some filler weld in one place. |
Thanks, at least I know what I need to do now!
Dan |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 2065 Location: North Carolina
jim martin Samba Member
Joined: January 14, 2004 Posts: 337 Location: Vancouver, BC
Posted: Tue Jul 08, 2025 8:17 am Post subject: Re: 002/091 Bell Housing Starter??? |
^^^^^^ THIS ^^^^^^^ _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20803 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jul 08, 2025 9:32 am Post subject: Re: 002/091 Bell Housing Starter??? |
Think it would be cheaper all around to just find a 002 bellhousing.... I paid $10 for mine with starter..... _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Tue Jul 08, 2025 2:09 pm Post subject: Re: 002/091 Bell Housing Starter??? |
Dale, Have you looked lately for a used 002 bell housing?
If you can find one for Cheap let Dan Know.
Have seen what the prices are now for a Bus IRS transaxle? _________________ Joseph
Elrod Motorsports
