dcheek Samba Member
Posted: Mon Jul 07, 2025 11:35 am Post subject: Rabbit Pickup Vent Windows |
I have an '81 Rabbit Pickup with the infamous vent windows with glued latches and lower pivot points. I've had success using rear view mirror adhesive on the latches but, I can't get it to bond the lower pivot point to the glass. I've tried it only with vent assemble intact. I'm wondering if I remove the assembly and glue and clamp if that will work. I would have to assume this is the way the factory did it??
I've also thought of drilling the pivot and the glass and bolting them together. Has anyone tried this?
Dave _________________ 1961 Bug
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Rabbit Pick Up
1982 Diesel Vanagon
2014 Golf (last year German mfr for NA)
2023 Jetta Gli, Autobahn Black Edition 6 speed |
vwjunkie3 Samba Member
Posted: Mon Jul 07, 2025 12:54 pm Post subject: Re: Rabbit Pickup Vent Windows |
VW Rabbits also had the bolt through vent glass on some 83 and 84 cars. |
dcheek Samba Member
Posted: Fri Jul 11, 2025 8:16 am Post subject: Re: Rabbit Pickup Vent Windows |
I ended up using Permatex Rear View Mirror adhesive. I found a way to clamp the glass and the pivot in such a way that it ended up with a good bond. How long will it last? Only time will tell.
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
dcheek Samba Member
Posted: Wed Jul 16, 2025 4:57 am Post subject: Re: Rabbit Pickup Vent Windows |
Update
Permetex did not work. I ordered Loctite epoxy from Amazon. This is used to glue metal hinges on to glass cabinet doors. I will try that and report back.
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
Joined: August 31, 2013 Posts: 13293 Location: North Carolina
Posted: Tue Jul 22, 2025 6:51 pm Post subject: Re: Rabbit Pickup Vent Windows |
Urethane windshield adhesive, glue the windows to their gaskets, you’ll never get those tiny tabs to adhere to the glass for very long, just long enough for you to think they’re secure, then you’ll get to watch them in the rear view mirror as they evaporate when they hit the pavement. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
