Alternator Change on 1968 Bug with Manx Dune Buggy kit
Page: 1, 2, 3  Next
Govolsguy31
Govolsguy31 is offline
PostPosted: Tue Jul 08, 2025 2:32 pm    Post subject: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Did a little searching and couldn’t find an exact answer.
I have a 1968 bug that is a Manx style dune buggy with a faulty alternator. Is it possible to change the alternator without removing the fiberglass body shell? I’ve watched numerous videos and I’m worried I’m not going to be able to get to the top components adequately.
Anyone have any experience doing this or input?
slayer61
slayer61 is offline
PostPosted: Tue Jul 08, 2025 2:38 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
I did mine recently. It was easy enough, but I have a rather wide cut out on the back of wide cutout on the back of my buggy.
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
Cusser
Cusser is offline
PostPosted: Tue Jul 08, 2025 2:57 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Post photos. Taking the engine out may be a lot easier....
Govolsguy31
PostPosted: Tue Jul 08, 2025 3:10 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Here’s a few photos:
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jul 08, 2025 3:53 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Take the engine out.... 4 bolts.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bsairhead
bsairhead is offline
PostPosted: Tue Jul 08, 2025 4:56 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
And it looks like it would be real easy to clear the body on the way out. I would still put it as high in the air as my jack stands would allow. Getting down on my knees is not the issue. Getting up takes some effort.
Govolsguy31
PostPosted: Tue Jul 08, 2025 5:03 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Watched a couple more videos and I think I’ll go this route. Seems like the far lessor of 2 evils.
I have one other question that I’m sure is simple, but I’m a novice mechanic. Currency, the positive is running directly to the battery and nothing is attached to the other terminal on the alternator that is labeled to go to the warning light. That’s just an indicator, right? It wouldn’t impact the functioning of the alternator, I just won’t have a fault light if it’s not working properly? (Basically, there’s no neutral/ negative to hook up on these, correct?)
Mr. 010
Glenn is offline
[quote="bsairhead"]
It's not the years, it's the miles Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bsairhead
PostPosted: Tue Jul 08, 2025 5:12 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
[quote="Glenn"]
My odometer hasn't spun over yet but I know the block well.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Jul 08, 2025 5:18 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
I think the alternator light is supposed to function in order for the alternator to charge. Others will surely weigh in on this. Good luck Bob
bsairhead
PostPosted: Tue Jul 08, 2025 5:33 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Yes it needs to see voltage at both ends of the lamp,
Govolsguy31
PostPosted: Tue Jul 08, 2025 5:53 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Wow. Ok, so that in itself might be the problem. I don’t even have a wire for that tho. How could I hook that up correctly? I don’t think this thing even has a “lamp” (sorry, another dumb question, but is that an actual bulb? Where would that be, on the dash/ gauge cluster?)
chrisflstf
chrisflstf is offline
PostPosted: Tue Jul 08, 2025 6:29 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
The lamp is in your speedo, well the bulb should be there. Alt or gen is on left, red and oil pressure is on right, green.
Cusser
Cusser is offline
PostPosted: Tue Jul 08, 2025 7:45 pm    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Yes, the light bulb for charging light in the speedometer housing MUST be operable for an ALTERNATOR to work. For an internally-regulated alternator, D+ must be connected to the charging light bulb.
Govolsguy31
PostPosted: Wed Jul 09, 2025 7:55 am    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Yep, so I don’t have a warning light at all! Haha. I’ll have to get one ordered.
For wiring, can I just use an unused strand from the wiring harness? It’s a direct connection from the alternator to that bulb, right?
Govolsguy31
PostPosted: Wed Jul 09, 2025 10:38 am    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
So, in troubleshooting today, the neutral indicator light was still in the Speedo, just not connected. I made sure it still functioned and it does. I hooked it up to the alternator and nothing. No light when the ignition is on and the car off. Nothing when I start the car.
Are we back to bad alternator? Anything else it could be? I’m assuming this light is the same as the ones I ordered. It’s green, but that doesn’t matter I’m sure.
bsairhead
PostPosted: Wed Jul 09, 2025 11:23 am    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
You need key on power to the tab for the lights, (oil pressure and generator) Neutral indicator light? No such thing.
Govolsguy31
PostPosted: Wed Jul 09, 2025 11:38 am    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Correct. It had power to it. May not be neutral. Possibly shift indicator? Top middle indicator on the speedo.
bsairhead
PostPosted: Wed Jul 09, 2025 11:40 am    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Top middle?
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Jul 09, 2025 11:56 am    Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit Reply with quote
Top middle (blue) is for high beam headlights.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Page: 1, 2, 3  Next
