Bigger brake booster, improved brakes.
Page: Previous  1, 2, 3 ... , 14, 15, 16  Next
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue May 27, 2025 12:05 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Got it, my bad, I thought it was the piston size but that's right, this one has 2 pistons the name doesn't apply to the piston size.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sat Jun 28, 2025 5:37 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
I finally made the swap to the BMW booster I picked up years ago.
A series of delays (a move to Tsawwassen after 26 years in our house in Crescent Beach, a heart attack and bypass surgery followed by remedial surgery to close the hole they left in my chest...) meant I have had the parts kicking around for ages.
So, steering wheel out, dash out, master out, pedals out (!!!) New clutch and brake masters in on top of the 10" ATE booster and much, much bleeding.
And now? The pedal is atrocious, the diametric opposite of "confidence inspiring". Alika's description of stepping in a pile of dog poo is right on. Its mushy as hell and the travel is really excessive - like getting too close to the floor excessive. The booster is much more vocal than the original.
I adjusted the pin very carefully and we have bled the brakes to the bone. When you bleed off the vacuum, the pedal is quite firm with only about an inch of travel.
Did I miss a step? Is there a gasket I should have replaced? Is there an adjustment I can make or do I just take the dash apart again to re-install the OEM booster?
Thanks for any advice, Jake
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
wesitarz
wesitarz is offline
PostPosted: Sat Jun 28, 2025 6:47 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
I had the same with my G-57 Van Cafe big brake. Maybe it's the different booster that accentuates the caliper flex inherent in the G-57. When you press the brake pedal can you see the caliper flex kinda like a wrist flex? Fixed mine with a caliper stiffening kit.
For some reason I had to grind off a bit of metal to get the clips to fit on but doable with a 4 inch gringer with calipers still attached to brake line.
From Tyrollsports and maybe others:
https://www.tyrolsport.com/braking/tyrolsport-brake-caliper-stiffening-kit-for-vw/audi/
Edit: https://www.facebook.com/watch/?v=200468467513057
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Jun 29, 2025 9:59 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
It's not really the flex, it has to do with piston area vs master size.
I had the same happening on stock floating calipers and fixed 4 piston calipers.
Jake, we're happy you're still around tinkering on your van!
Take care!
crazyvwvanman
crazyvwvanman is online now
PostPosted: Sun Jun 29, 2025 10:16 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
The 60 on the caliper with 2 side by side pistons actually does refer to the piston size, indirectly.
That caliper has a total piston area equivalent to a single 60mm piston.
So it uses the same master cyl fluid volume/pressure as a 60 so they mark it 60.
Mark
MarkWard
MarkWard is offline
PostPosted: Sun Jun 29, 2025 10:21 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
The bigger booster should lessen effort. I’d suggest driving it a bit. You may find the actual braking is fine. The dog poo feeling is likely from the additional assist.
Jake de Villiers
PostPosted: Sun Jun 29, 2025 11:50 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Thanks for the feedback you guys.
I don't have the front wheels off to see the flex but that's an interesting observation.
I drove it again yesterday and it does stop okay but I still hate the mushy pedal feel. I should bleed it again before I yank the dashboard apart.
Thanks, Alika, its good to see you're still engaged with the Vanagon community.
www.thebassspa.com
syncrodoka
syncrodoka is offline
PostPosted: Sun Jun 29, 2025 12:38 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Did you manually adjust the rear brake shoes? That makes a surprising difference in pedal height and feel.
Jake de Villiers
PostPosted: Sun Jun 29, 2025 4:14 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Yes it does. The brakes were fine before I replaced the master and the booster.
Even with the handbrake on, the brakes are poopy.
www.thebassspa.com
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Jun 29, 2025 5:13 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Mark
Now all this info makes sense, thank you for the extra explanation!
I installed some SA stock vented brakes recently with a 60mm single piston floating caliper, these feel awesome ( correct pedal feel) and work so much better than the ATE 57 with 288 rotors! Stock booster.
I went down a rabbit hole of brake pads, rotors and piston seal kits to keep these on the road since everything is pretty much NLA unless you cough up a lot of money from VW Classic Parts.
For people interested, I'm having new clevis made for the Vanagon: M9x1 for stock booster and clutch pedal.
M10x1.5 for BMW E30 booster users, and for the new ATE boosters I sell, bc I'm tired of chasing clevis cores and drill+ tap them.
wesitarz
wesitarz is offline
PostPosted: Sun Jun 29, 2025 5:39 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Caliper stiffeners, larger 25mm MC (for a BMW 740i), SS flex hoses and brace for the MC flex was my solution for an acceptable pedal feel.
MarkWard
MarkWard is offline
PostPosted: Sun Jun 29, 2025 6:04 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Going to a larger diameter master cylinder will increase pedal effort. It’s possible to use a 25mm BMW master, but it takes some fitting. It’s documented in another thread.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Jun 29, 2025 10:44 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Some people mount a 1" Transporter T4 master and booster but that's a heavy mod for the cluster and all.
Jake de Villiers
PostPosted: Wed Jul 09, 2025 10:59 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Thanks everybody for sharing your experiences with the E30 booster.
Last weekend I went back in and replaced the bigger booster with the OEM part. The pedal feel is very good now, high and firm, though stopping power is still less than breathtaking.
I'm not sold on the Akebono pads and Van Cafe shoes on the van currently. It stopped a lot better with the Porterfield shoes and EBC YellowStuff pads.
I only had a few thousand miles on the EBC pads when I was persuaded to try the Akebonos and I'm sure I put them in a box when we moved, but I can't find them...
www.thebassspa.com
Last edited by Jake de Villiers on Wed Jul 09, 2025 1:31 pm; edited 1 time in total
MarkWard
MarkWard is offline
PostPosted: Wed Jul 09, 2025 11:07 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
When switching compounds you need to bed them in. This process transfers pad material to the rotor giving you the grip you are looking for. Follow the manufacturer’s procedure. If not, look at hawk brake for their bed in directions.
Also, performance compounds have a best temp working range. Most driving Vanagon brakes aren’t that hot, so a compound for lower temps is better. You need to know your operating temp when choosing compounds. Higher is not always better.
I’ve got performance friction on the front, but their street compound. Brakes have always seemed better with some temp in them. Problem is in a panic stop, generating temp is an option. Not saying this is your problem.
Jake de Villiers
PostPosted: Wed Jul 09, 2025 1:29 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Thanks, Mark. I also have a road racing background and am very familiar with how to bed in brakes. Hence the choice of Porterfield for the rear
shoes. Good people.
The EBC Yellow were excellent when warmed up but brutal cold. The Akebono are just okay at all times.
I'm looking at giving the EBC Reds a try - the description seems to fit my usage.
www.thebassspa.com
do.dah
do.dah is online now
PostPosted: Wed Jul 09, 2025 1:49 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Why not porterfield on the front?
shoes. Good people.
Jake de Villiers
PostPosted: Wed Jul 09, 2025 6:54 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Good question! I think that at the time the Porterfield pad choices seemed too 'racy', whereas the EBC Yellow was pitched as perfect for hard street use.
Do you know something don't?
www.thebassspa.com
Christopher Schimke
PostPosted: Wed Jul 09, 2025 8:34 pm    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
I have run Porterfield's R4S compound front pads on the street, and while a little dusty, I really liked them.
do.dah
PostPosted: Thu Jul 10, 2025 12:13 am    Post subject: Re: Bigger brake booster, improved brakes. Reply with quote
Was just curious why you had porterfield on the rear and not on the front.
Christopher's answer is the same as I'd say.
I have dark/black wheels, so the dust doesn't bother me as much as someone with light colored wheels,, nontheless, I see it and hafta clean them due to ocd...
Page 15 of 16
