Muffler to Head nuts question
Snoopy1971
Snoopy1971 is offline
PostPosted: Wed Jul 09, 2025 12:56 pm    Post subject: Muffler to Head nuts question Reply with quote
I was watching a vid of somebody assembling their engine, and they put their muffler to head nuts on like this:
Is this correct? When I recently reassembled my engine, I put them on the opposite way (I hadnt paid attention to how they were on when I took it apart). I put them on the opposite way because I figured the partially connected round part was supposed to act as like a built in lock washer.
If the pic above is indeed showing the correct installation, then what is tge purpose of the partially connected round part?
1968 Bug
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jul 09, 2025 1:09 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
The picture is correct. That's a locking ring on the nut.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Jul 09, 2025 1:14 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
The threads of the main nut and the ring are not quite aligned. So when you screw it on a stud, the change in thread engagement distorts the nut, making it grip harder and therefore it will not loosen so easily; no separate locknut is needed.
I use anti-seize on the stud threads so it doesn't rust in place, even with copper or brass nuts.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Snoopy1971
PostPosted: Wed Jul 09, 2025 1:29 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
Ok ... interesting ... thanks all!!
1968 Bug
baldessariclan
baldessariclan is offline
PostPosted: Wed Jul 09, 2025 1:37 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
Just to clarify, those "copper" nuts are actually copper-plated steel. The copper outer plating is used to help keep them from corroding and seizing under high temperature conditions.
LeeFred
LeeFred is offline
PostPosted: Wed Jul 09, 2025 1:38 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
When we first got our SB, there were regular nuts on there and they all came loose. When I put those VW lock nuts on there, no more issues.
Cusser
Cusser is offline
PostPosted: Wed Jul 09, 2025 2:13 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
I use the brass nuts that utilize an 11mm wrench on mine. Same 8.0mm x 1.25mm thread.
Even Amazon sells them https://www.amazon.com/Exhaust-Clearanced-Brass-Co...&gQT=1
Snoopy1971
PostPosted: Wed Jul 09, 2025 2:35 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
Yeah my spark plug socket was hitting the 13mm intake nuts, so I replaced them with these 10mm nuts with a 13mm flange base
https://a.co/d/1kuGXaL
1968 Bug
my3bugs
my3bugs is offline
PostPosted: Wed Jul 09, 2025 3:05 pm    Post subject: Re: Muffler to Head nuts question Reply with quote
i have used those copper plated steel lock nuts in the past , they held great untill it was time to come apart and they took out a few studs with em . maybe just a quirk .
runamoc Premium Member
runamoc is offline
PostPosted: Thu Jul 10, 2025 9:56 am    Post subject: Re: Muffler to Head nuts question Reply with quote
my head 'studs' were long enough so that I could double nut them
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
Mr. 010
Glenn is offline
PostPosted: Thu Jul 10, 2025 10:04 am    Post subject: Re: Muffler to Head nuts question Reply with quote
Long studs on the #1 and #3 lower studs can hit the bend of the heater boxes.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
runamoc is offline
PostPosted: Thu Jul 10, 2025 10:20 am    Post subject: Re: Muffler to Head nuts question Reply with quote
Heater boxes? The long studs don't interfere with the bends in my 'Bazooka' exhaust.
Here hold this while I paint it w/BBQ Grill paint
