Govolsguy31 Samba Member
Joined: June 06, 2025 Posts: 25 Location: Harrisonburg, VA
Posted: Wed Jul 09, 2025 12:05 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
Got ya. Mine’s green, but regardless, it was hooked up as the alternator/ generator indicator would be. From D+ on alternator to positive on the indicator light. Never lights. Not with key on power or with car running. I manually hooked it direct to positive to make sure the bulb worked, which it does.
Could it be anything other than a bad alternator? |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4488 Location: viroqua wi.
Posted: Wed Jul 09, 2025 12:18 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
Govolsguy31 wrote: |
The light does not use a ground. It's grounded only when the generator is not running or producing the equivalent voltage of the battery. So checking it's lighting ability with a direct hot means it has a ground, which it should not. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Wed Jul 09, 2025 12:26 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
Post a pic of the front and the back of your speedo. Who knows what year, and the lights changed. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4044 Location: San Diego
Posted: Wed Jul 09, 2025 2:19 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
The alternator light on the speedo has 12v always on one side. The other side of the bulb comes from the alt. When key on, motor off, light s/b on. When you start motor, alt puts out 12v, which then turns light off ( both sides have 12v = no light)
You can also on the engine, take a 12v test bulb, connect one side to 12v and connect other side to alt. If the alt is working after starting, the light will go out.
Some alternators may need a higher idle rpm to start charging, about 800 to 900, but I have not seen that |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16572 Location: North Florida, USA
Posted: Wed Jul 09, 2025 2:23 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
See this gallery pic of the trunk side of the speedometer:
Notice the other bulb holders higher up in the speedometer where the bulb holders slide into openings in the metal speedometer body. The speedometer body is grounded which means the upper bulbs are grounded at the sides and the male spade of the bulb holder runs to a switched 12v+ power source to turn the bulb ON.
Notce that the three (3) indicator lamps at the bottom of the speedometer are mounted in a black plastic housing... insulating them from the grounded case of the speedometer. Also, in addition to the three (3) male terminals of the three (3) bulb holders there is a fourth male terminal marked "Power for warning lights". This bottom most terminal is powered with 12v+ from the ignition switch and connected to each of the three bulb holders via the U-shaped conductor. This means each of the three (3) bottom indicator lamp male terminals run to a switched GROUND to turn the lamp ON. If you don't have a wire connected to this bottom terminal you will need to run a new wire from either an ignition switched fuse of the fuse box, or piggy back off the fuel gauge vigrator connection which is also powered from the fuse box.
For the GEN lamp, the wire running from the GEN lamp bulb holder (male) to the D+ terminal on the alternator is GROUNDED by the D+ terminal. 12v+ coming from the GEN lamp runs thru the field coil inside the alternator before reaching ground. This is why you cannot use one of the upper speedometer bulbs as your GEN lamp... it is not providing the 12v+ needed to energize the field coil in the alternator.
If you don't have a GEN lamp....
Find a 2W 12v bulb and wire it between the ignition coil #15 (+) terminal and the D+ terminal of the alternator. This lamp will act as the speedometer GEN lamp. It will turn ON with the ignition key before you start the engine and energize the field coil. Once the engine is started and the alternator starts producing a charge this temp GEN lamp will turn OFF. This will work until your normal GEN lamp arrives. _________________ AshMan40
Posted: Wed Jul 09, 2025 2:43 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
The tab by your pinky gets key on power. |
KTPhil  Samba Member
Posted: Wed Jul 09, 2025 3:16 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
As I suspected, your speedo is not form the year of your chassis (no gas gauge is the easy giveaway).
Your older speedo is simpler and so this should be straightforward.
One thing to know about the turn and warning lights at the bottom is that they are reversed polarity from what you may expect. The center tab has key-on power. So the light bulbs light up only when the bulb terminal is grounded.
So for example, your oil light comes on when you turn they key to the run position, because one side of the bulb has power, and the other side, which is connected to your oil pressure sensor, is grounded when oil pressure is low (like with the engine not running). ONce the engine starts, the oil pressure REMOVES the grounding of that wire, so the bulb goes out. Make ssense?
Similar for the turn signal indicator light and the generator/alternator light.
So first confirm that the triple bulb holder at the bottom of the speedo has positive voltage when you turn the key on. Then report back. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Wed Jul 09, 2025 3:59 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
Ignore the bit of my post about fuel gauge vibrator as a source for 12v+ for the bottom three indicator lamps... only applies to '68-later Beetle speedometers. Yours is a pre-'68 speedometer.
The three bottom indicator lamps on these earlier speedometers were powered directly from the fuse box (ignition switched fuse) _________________ AshMan40
Posted: Wed Jul 09, 2025 6:09 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
Guys and Gals, yall are amazing! Your input was a huge help and I got it sorted (I slipped away for a few minutes after dinner, don’t tell the wife) . I put 12v to one terminal and one to the alt. Light clicked on, started car, and it went out. Voltmeter test and I was registering 13.8v at idle.
Once I get the new sockets and bulbs for the Speedo, I’ll get it wired up correctly. I’ll post a few pics once she’s back together! |
Posted: Wed Jul 09, 2025 6:12 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
Cool beans |
Posted: Wed Jul 09, 2025 8:01 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
I put 12v to one terminal and one to the alt. Light clicked on, started car, and it went out. Voltmeter test and I was registering 13.8v at idle. |
Great! Saves you having to pull the engine.  _________________ AshMan40
Cusser Samba Member
Joined: October 02, 2006 Posts: 33083 Location: Hot Arizona
Posted: Thu Jul 10, 2025 6:19 am Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
ashman40 wrote: |
Great! Saves you having to pull the engine.  |
And you learned a lot ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Jul 10, 2025 1:47 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
I have learned a crap ton on this. That’s as much fun as driving it.
I was able to pull that bulb and bulb socket and get it in the right place. I ordered 4 of each that will be here Monday, but I was able to get the dash put back together. I also installed a small 12” LED light bar, which went smooth.
Posted: Thu Jul 10, 2025 2:16 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
Now get that oil pressure light wired. |
Posted: Thu Jul 10, 2025 2:19 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
bsairhead wrote: |
I was literally just reading on that. Hooks up basically the same way I’m guessing? |
Posted: Thu Jul 10, 2025 2:25 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
bsairhead wrote: |
One wire from the switch 'sensor' to the gauge. Originally was blue/green but the electrons don't care. |
Posted: Thu Jul 10, 2025 2:42 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
bsairhead wrote: |
bsairhead wrote: |
Yea, I’m not gonna lie. I used the purple Tach wire for the alternator. Haha.
For the light colors in the Speedo, my color inserts are gone. Can I just use some of the wife’s fingernail polish or something to change the color? A small thing, but now I’m getting picky. Haha. |
Posted: Thu Jul 10, 2025 2:55 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
bsairhead wrote: |
bsairhead wrote: |
So your saying paint the lamps 'light bulbs' ? I think you might have better luck with a Sharpie. |
Cusser Samba Member
Posted: Thu Jul 10, 2025 4:06 pm Post subject: Re: Alternator Change on 1968 Bug with Manx Dune Buggy kit |
For the light colors in the Speedo, my color inserts are gone. |
Some use the colored gels from an inexpensive set of file folder separators. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
