Xevin  Samba Member
Posted: Fri Mar 12, 2021 12:21 am Post subject: Re: Gene Berg Breather Pics |
croSSeduP wrote: |
Re. wiring...I totally agree with you! But, I don't know what to do about it. I need wiring for oil pressure switch, oil pressure gauge, oil temp switch, oil temp gauge, head temp gauge, etc., etc., etc.! Those wires NEED to be there. I don't know how to clean that up. Now, add breather hoses coming around too, and....
You see my dilemma.
First World problems, for sure. |
Not trying to detour this thread in a different direction since it’s not about wiring. However, I know you are cleaning up engine bay and want to minimize
clutter. My suggestion to you is get rid of those blue crimps and use OEM style crimps. You could cut the blue plastic off those terminals and use black heat shrink instead.
Get rid of that hard plastic corrugated wire loom for one like similar to this.
Alex Tech 10ft - 1/8 inch Cord Protector Wire Loom Tubing Cable Sleeve Split Sleeving For USB Cable Power Cord Audio Video Cable – Protect Cat From Chewing Cords - Black https://www.amazon.com/dp/B07FWCJ7QF/ref=cm_sw_r_c...&psc=1
In some situations you can use heat shrink tubing to camouflage wire colors. Just leaving a tip exposed so you can identify wire colors. Put an appropriate diameter of heat shrink on the and only shrink the ends. Leaving the gauge wires loose inside the tube and still able to identify wire color.
Hope that gives you some ideas. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79662 Location: Sneaking up behind you
Posted: Fri Mar 12, 2021 4:03 am Post subject: Re: Gene Berg Breather Pics |
Put a large rubber cap on the fan shroud nipple that was for the charcoal canister.
I used a cap for a VW brake booster. Here's the part number: 030-133-335A
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
74 Thing Samba Member
Posted: Fri Mar 12, 2021 12:13 pm Post subject: Re: Gene Berg Breather Pics |
Xevin wrote: |
croSSeduP wrote: |
You see my dilemma.
#-o
Not trying to detour this thread in a different direction since it�s not about wiring. However, I know you are cleaning up engine bay and want to minimize
Alex Tech 10ft - 1/8 inch Cord Protector Wire Loom Tubing Cable Sleeve Split Sleeving For USB Cable Power Cord Audio Video Cable � Protect Cat From Chewing Cords - Black https://www.amazon.com/dp/B07FWCJ7QF/ref=cm_sw_r_c...&psc=1
Hope that gives you some ideas. |
If you use that loom also get some shrink wrap and use about an inch on each side to make it look tight. I agree it looks way better! |
onehappykombi Samba Member
Posted: Wed Jul 09, 2025 2:20 pm Post subject: Re: Gene Berg Breather Pics |
There is a hose going “forward” past the fan shroud from the breather box. Can you show what that is hooked up to?
Safe to assume the other 2 hoses go to valve covers? _________________ '56 Early Split & '69 Early Bay
Overlanding the USA
Camper special engine build |
oprn Samba Member
Joined: November 13, 2016 Posts: 14861 Location: Western Canada
Posted: Wed Jul 09, 2025 2:45 pm Post subject: Re: Gene Berg Breather Pics |
It just exits in the wheel well if I recall correctly. Maybe I saw a little filter on the end of the hose... _________________ Our cars get old, we get old but driving an old VW never gets old! |
Glenn  Mr. 010
Posted: Wed Jul 09, 2025 3:18 pm Post subject: Re: Gene Berg Breather Pics |
oprn wrote: |
It just exits in the wheel well if I recall correctly. Maybe I saw a little filter on the end of the hose... |
THIS
It exits the wheel well through and existing hole that was for the charcoal evap canister. I have a small "button" filter on it. The low pressure in the wheel well, when moving, sucks the vapor out.
Not really very green, but then i'm driving a 50+ year old gas guzzler. _________________ Glenn
Member #1009
#BlueSquare
1950split Samba Member
Posted: Thu Jul 10, 2025 5:39 am Post subject: Re: Gene Berg Breather Pics |
To get a cleaner look I switched to a CSP linkage. I use the CSP breather which is similar to GB's.
I have the case connected to the CSP breather tower from the original fuel pump location.
Then there is a hose that is connected to a Fastfab breather box on the firewall which has openings and lets the excess pressure escape. It allowed me to get rid of the small K&N air filter I had before on top of the CSP Tower I hated because I had oil mist spread all around on the CSP Tower.
Finally I have a vent hose to the Fastfab breather from 1-2 valve cover. That's it.
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1872 Location: Grass Pants, Orygun
Posted: Fri Jul 11, 2025 11:23 am Post subject: Re: Gene Berg Breather Pics |
I only vent off the passenger valve cover and the fuel pump hole. I've been running this Berg breather for 15 or 16 years now and venting has been sufficient for 8,500 rpm, low 12 second 1/4 mile passes and highly spirited street driving. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/ |
Glenn  Mr. 010
Posted: Fri Jul 11, 2025 11:45 am Post subject: Re: Gene Berg Breather Pics |
You have the optional vented cap. _________________ Glenn
Member #1009
#BlueSquare
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11208 Location: Oregon
Posted: Fri Jul 11, 2025 11:57 am Post subject: Re: Gene Berg Breather Pics |
stealth67vw wrote: |
I only vent off the passenger valve cover and the fuel pump hole. I've been running this Berg breather for 15 or 16 years now and venting has been sufficient for 8,500 rpm, low 12 second 1/4 mile passes and highly spirited street driving. |
I have nothing to add here.
Just wanted to congratulate on your overall win at the Bug Run this year.
I watched you every round and you did a steller job. _________________ I have learned over the years.
Buy Once, Cry Once!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Fri Jul 11, 2025 12:14 pm Post subject: Re: Gene Berg Breather Pics |
I watched you every round and you did a steller job. |
Thanks you Perry. I was super focused and didn't get to be very social. Missed a lot of people because I spent all day actually racing. _________________ John Bates
