Piston ring land clearance
mcjweller
mcjweller is offline
PostPosted: Thu Jul 10, 2025 5:25 pm    Post subject: Piston ring land clearance Reply with quote
Ok, so AA 90.5 cylinders and pistons. Bently says .003" to .004" piston ring to land clearance. On my AA pistons I have .002" 1st ring, less than .002" 2nd ring. Exactly the same all pistons. I have to say "less than" because I have no way to measure less than .002" as a feeler gauge.
I called AA and enquired, they said their spec is .001" to .002"
That seems tight! Although, all rings can be spun in the groove easily even if dry. And they all fit well for depth, also.
AA says run them...yet I'm paranoid...
daveblank
daveblank is offline
PostPosted: Thu Jul 10, 2025 6:19 pm    Post subject: Re: Piston ring land clearance Reply with quote
The Bentley manual is referring to the original cast aluminum pistons that would have came in the car. The AA pistons are cast hypereutectic & they wont expand as much as standard aluminum ones will so the gap doesn't need to be as big.
I'm not the expert & I'm sure someone will come along & Tell me how wrong I am.
jim martin
jim martin is offline
PostPosted: Thu Jul 10, 2025 8:24 pm    Post subject: Re: Piston ring land clearance Reply with quote
Your good to go
B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0
modok
modok is offline
PostPosted: Thu Jul 10, 2025 8:25 pm    Post subject: Re: Piston ring land clearance Reply with quote
.001-.002 is good
.004" is the wear limit IMO
Rob Combs
Rob Combs is offline
PostPosted: Fri Jul 11, 2025 9:07 am    Post subject: Re: Piston ring land clearance Reply with quote
Do make sure to check them for piston-to-cylinder clearance, then check your ring gaps afterward!
My AA piston to wall clearances were really tight as boxed and needed to be honed.
mcjweller
PostPosted: Fri Jul 11, 2025 2:44 pm    Post subject: Re: Piston ring land clearance Reply with quote
Thanks everyone, for the sanity check! Looks like I am good to go on all counts.
Thanks,
Matt
