5500 Samba Member
Joined: October 16, 2020 Posts: 112 Location: Cape Cod
Posted: Wed May 11, 2022 9:29 am Post subject: Re: What did you do to your Oval today? |
donny273 wrote: |
Putting together a 36 hp wolfsberg west dual port motor with counterwighted crank and a few other goodies. Noticed I have two types of shroud fans lying about. One has more vanes on it than the other. Was one for a buss and the other a type1. Which should I use? Looking for reliability not crazy high performance. Thanks for your help. |
Assuming both have holes in the backing plate (how the early generators were cooled).. The early fans had fewer blades. Later ones cool a bit better at the expense of a couple of horsepower. I went with the later ( I think 24 blade vs. 16). |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1385 Location: Bella Coma Canada
Posted: Tue Jul 19, 2022 3:33 pm Post subject: Re: What did you do to your Oval today? |
I replaced the 30 year old cracked tires with new 185 60 R 15 from CIP 1 and being wider than the original 165 15 I added longer front bolts that keep the tires from rubbing on the front suspension. But the new bolt was too long now I have less steering angle. So back in the shop and grind a few threads off. _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
aa390392 Samba Member
Posted: Mon Aug 29, 2022 8:32 pm Post subject: Re: What did you do to your Oval today? |
Polished the Inca red Kab,
Polished out prairie beige
Picture tomorrow _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Sat Sep 03, 2022 8:04 pm Post subject: Re: What did you do to your Oval today? |
And I sold it today _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
2Dokas Samba Member
Joined: October 09, 2004 Posts: 758 Location: Santa Cruz, CA
Posted: Sun Sep 04, 2022 7:48 am Post subject: Re: What did you do to your Oval today? |
aa390392 wrote: |
And I sold it today |
Looks awesome. Happy or Sad? _________________ 87 Doka 2WD Ej22,
56 Convertible |
Posted: Mon Sep 05, 2022 10:22 am Post subject: Re: What did you do to your Oval today? |
Am kind of remorseful, I put a lot of love/work into it..and enjoyed it immensely
The color, Inca red was most unusual and not often seen..she was fun to share with viewers..hopefully the new owner will also enjoy, but I have my doubts. _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 308 Location: Colorado
Posted: Tue Sep 06, 2022 2:47 pm Post subject: Re: What did you do to your Oval today? |
aa390392 wrote: |
Picture tomorrow |
What a great color. Was that exclusive to convertibles?
Ya gotta be sad to see that one go. Do you have your sights on the next one? |
Posted: Sat Nov 05, 2022 9:45 pm Post subject: Re: What did you do to your Oval today? |
Over the years I've hired a high school kid to lend a hand in my shop and maybe they would learn something.
In the 80's one of my helpers always showed on time and was enthusiastic.
We found a '60 bug and put it together for him. His family moved to Halifax and he drove the bug across Canada and used it for a few years.
His father was a doctor and his mom was a nurse so he and his 2 brothers became doctors.
Flash forward to today he stopped in to say hi and wanted to see my VW fleet.
First I showed him my 1957 black beetle and he asked if it still runs.
I told him of the long story of how a friend traded it to me for doing a brake job on their Toyota. How another high school guy and I stripped it down and rebuilt it.
I checked the oil and pushed on the vee belt .
It is just a little above freezing here so I told him to push the manual choke on the carburetor because the choke cable is broken.
Then noticed that the flex fuel hose was split and just sitting on the fuel pump with the outlet aimed right at the distributor.
I replaced the hose and we started it right up.
I'm sure glad I was showing off and not just got in and tried to drive off.
BTW I do have a on board fire extinguisher _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sun Nov 06, 2022 8:50 am Post subject: Re: What did you do to your Oval today? |
Da TOW'D wrote: |
Gratifying I'm sure to know you played a part in him becoming a good quality human.
It really does take a village! _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
markendee Samba Member
Joined: April 30, 2009 Posts: 293 Location: Kyabram, Australia
Posted: Thu Jul 13, 2023 3:38 am Post subject: Re: What did you do to your Oval today? |
I registered the 54 in March but couldn't decide on a way to attach the plates that made me happy.
I finally fitted my number plates today.
I Really did not want to drill holes in front bumper and have the plate hanging down and getting all bent up.
I looked at frames at accessory shops and online but couldn't find what I wanted.
We replaced the front bumper (?) in my daughter's Toyota on Monday and I liked the look of the number plate support frame.
Bit of recycling and jobs done.
Also like that the rear plate colour matches the Hearts (sort of)
_________________ Member # 145244 |
WadeLinger Samba Member
Posted: Mon Jan 08, 2024 1:10 pm Post subject: Re: What did you do to your Oval today? |
Wired up the headlights.
Posted: Mon Jan 29, 2024 9:29 am Post subject: Re: What did you do to your Oval today? |
Hooked up the wires behind the dash.
MJMarkham Samba Member
Posted: Wed Feb 21, 2024 6:33 pm Post subject: Re: What did you do to your Oval today? |
After years of the cheap TMI vinyl interior kit, I have reworked the interior on the '57... new headliner, carpet, seat covers and door panels. Also upgraded the steering wheel...
_________________ M J Markham
57 Ragtop Oval, 58 Lowlight Coupe
WANTED: Original 58 Ghia Dash Knob |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 2058 Location: San Fernando Valley, CA
slayer61 Samba Member
Posted: Thu Jun 13, 2024 6:46 am Post subject: Re: What did you do to your Oval today? |
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
Car Craft turbo header |
Strawman914  Samba Member
Joined: August 28, 2012 Posts: 1 Location: San Luis Obispo
Posted: Fri Jun 21, 2024 9:34 am Post subject: Re: What did you do to your Oval today? |
Long-time lurker, but it is finally time that I shared my VW project. Long story is that when I was born, my parents were broke college students and had to sell their '56 Euro (for $280) to pay my birthing bills in New Haven, CT in 1966. My first car was a 1964 Beetle sunroof that I bought in 1982 while a sophomore at Sacred Heart High School in San Francisco. I used my paper route money to hotrod it in my mother's San Francisco house with a tiny garage. Mods included: 1385cc pistons/barrels, Engle 110 cam, header, dual Kadrons, lowered with a lowering front sway bar (remember those?), and one-piece windows. It was stolen from in front of my house about six months into the project, and I replaced it with a '66 11-window Bus. I've also owned one more Beetle ('63), '66 Fastback, '69 Squareback, '67 rusted-out 21-window Bus that I bought for its engine (and sent to the crusher in 1983!), Manx-style buggy, '75 Bus during college, '81 diesel Westy (GTi Golf-swapped in 1999), '86 Syncro Westy (Suby-swapped in 2001), and most recently a '93 Westy Eurovan (TDI & manual swapped). But it was always my dream to build a "legacy" Euro Beetle.
I finally found a '56 Euro Beetle in a Samba ad about two years ago. My wife and I dragged it out of the guy's front yard in Oakland, CA using a come-along. It is a complete basket-case: the MY '58 36hp engine is locked up; the doors were cut for one-piece windows; the trim holes are welded-up (poorly); it is missing the semaphores & W-lid; the seats are hashed; it has the wrong aprons (riveted on!), fenders and hood; it came with no lights/lenses; it has no interior panels; etc. But it is surprisingly straight and there's not too much rust. The cowl is damaged from the hinges; obviously, the hood flew open at one point...
Because I'm a Porsche 914 guy and I recently bought out a guy's estate that included two 914s, five engines, six transaxles and four trailer loads of "stash," I am in the midst of building an upright Type 4 engine and have recently completed a 901 5-speed conversion into a '74 Beetle IRS chassis. Regarding that pan, I narrowed the front beam 2" and installed CB Performance disc brakes on raised spindles, welded-in adjusters, new balljoints, and I installed narrowed tie-rods and sway bar. I also narrowed the rear trailing arms 1" each side so that the wheels will tuck under correctly beneath the narrower early body. I welded-in early pans so I can install early-style seats; I have a set of 1980s era Corbeaus that I might use, although I might opt for 914 seats since I've got a couple good sets.
This is a medium-term project, since I've got a couple other projects that I'm trying to finish up (M54B30 swap into an '85 BMW 524td chassis, Suby EG33 swap into 1975 Porsche 914 that I plan to flip, and I'm helping a friend swap an M54B30 into a 2000 BMW 323 wagon) before going whole-hog into this Beetle. I also autocross a built EJ257-swapped '73 914 (302whp, LSD in modified Suby transaxle, metal flares, 911 front suspension, big front sway bar, etc.), and my wife autocrosses an '01 Corvette or her mostly stock '75 914 -- and those cars always need attention.
As shown below, last night I finished welding up a rotisserie that will make it easier for me to address rust -- mostly in the bottom of the heater channels. My luggage tray has some rust-through, too.
obus  Samba Member
Joined: March 08, 2001 Posts: 11652 Location: just off Garden State Parkway Exit 81
redbug64 Samba Member
Joined: July 21, 2005 Posts: 520 Location: Fairfax/Essex, Vermont
Posted: Fri Jun 13, 2025 12:10 pm Post subject: Re: What did you do to your Oval today? |
After owning my 1954 For close to 20 years, having saved it from laying dormant in a barn for probably 20 prior to that, I was able to drive it for the first time today. Be it still in need of many things, it moved under its own power!
_________________ Jason Arms
Fairfax, Vermont
1954 Standard Beetle
1965 Firetruck Red Double Cab
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Random Toyota daily drivers because winter. |
obus  Samba Member
Posted: Thu Jul 10, 2025 9:07 pm Post subject: Re: What did you do to your Oval today? |
I have not driven my '57 beetle at all for the last 3 years. I've started it and let it run for a while just to keep things lubed up a few times.
Yesterday I figured it time to take a cruise, I put it in first had the clutch on the floor yet when I twisted the key we started moving ahead and then the engine started. I still had clutch pedal on the floor. I shut the engine off and tried again same thing-- the clutch was seized and not disengaging.
So today i pulled the old fresh air 40hp. out. After I removed the pressure plate bolts I found that the disk was stuck against the pressure plate and flywheel with rust, i had to tap around the pressure plate to knock it off.
The flywheel, pressure plate and disk got cleaned up with a grinder with a flex pad. I removed the gland bolt and cleaned it with gas and repacked it with a little grease. no leaks on the front seal so I left it. All the valves checked good so tomorrow it is going back together.
The bug was sitting out side all that time so it is time to clean the addition next to my shop and give it a spot out of the rain coast weather.
Part of the cycle Fix it, Enjoy it, Neglect it , Fix it again and so on _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
