Who's baja is getting a motor rebuild and trans rebuild? Me
Page: Previous  1, 2, 3, 4
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Fri Jul 11, 2025 8:13 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Look like the Led Gravity lights for $700. Shocked Shocked Shocked ouch!
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
indianpeaksjoe
indianpeaksjoe is offline
PostPosted: Fri Jul 11, 2025 11:22 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Those are KC rock lights, the old ones were cheapo trailer lights: https://robonza.com/beetle/index.php/2024/04/12/replacing-the-front-blinkers-with-kc-rock-lights/
Now, those front headlights are amazing! They are KC 7" Gravity LEDs for a Jeep TJ. They are bright as heck, they look amazing and are stupid expensive. I had bought Vintage LED headlights, they were better than 50 year old stock, but not worth $300. https://robonza.com/beetle/index.php/2024/08/22/kc-7-gravity-led-headlights-on-66-beetle/
You can always find a coupon for 5-10-15% off KC if you look around KCREV5 has worked forever for me.
-Joe
Adventures in owning a 66 beetle
indianpeaksjoe
PostPosted: Fri Jul 11, 2025 11:23 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Had I known I was rebuilding the engine, trans and a ton of other stuff, I probably would have bought something cheaper Very Happy
-Joe
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Fri Jul 11, 2025 12:06 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
No matter how bright mounting the lights 2 feet off the ground up front is pointless just going to light up the ground 10 feet in front or the woop 3 feet ahead. Angle them back you just light up the sky and blind the shit out of other drivers. Put them on the roof or at least on the hood.
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
indianpeaksjoe
PostPosted: Fri Jul 11, 2025 12:21 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
I have driving spots on the roof, flood spots on the bumper and headlights in the ... headlights? I like em! I just cruise double track and appreciate that the multiple sets of lights get rid of those shadows that make every rock look like a cliff at night.
The stock LEDs in my wife's LJ are brighter than those KC headlights on the beetle and when you drive the Jeep at night people think you have the high beams on. I think those mopar lights are pretty expensive though.
-Joe
Schepp
Schepp is offline
PostPosted: Fri Jul 11, 2025 1:27 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Low mounted yellow lights are great for fog and dust visibility.
I put the Lasfit (Diode Dynamics Knockoffs) fog pods on all our cars. Crisp clean cut-off lenses don't blind other drivers. Factory wired for waterproof DT connectors. $130/pair. So far they've survived 10yrs of daily use with no condensation inside.
Money spent on quality round 7" headlights is a good investment. I put Jeep lights in my car. Wish I would've spent a little more on a better brand like Joe did. Being able to see well at night will help keep you safe.
indianpeaksjoe
PostPosted: Fri Jul 11, 2025 4:22 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
She's alive!
-Joe
jimmyhoffa
jimmyhoffa is offline
PostPosted: Sat Jul 12, 2025 9:15 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Nice! That sounds decently responsive for a single that doesn't have much tuning time on it. Moab was the best my single ever ran, just due to atmospheric conditions in general, I suspect.
Sidenote, I didn't know you guys even knew about Diode Dynamics Laughing I guess I assumed it was sort of a toasted ravioli situation. I just figured all the Midwest and Northern, and maybe East coast guys used Diode Dynamics, and you guys out west all ran Baja Designs. I live about 30 mins from Diode Manufacturing HQ, I guess it really has blown up over the last few years! DD company open house is August 9th if anyone happens to be in StL, I'll show ya around.
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
indianpeaksjoe
PostPosted: Tue Jul 15, 2025 9:46 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
The engine and new clutch are in. Hoses and wires getting hooked up today.
-Joe
67rustavenger
67rustavenger is offline
PostPosted: Tue Jul 15, 2025 10:13 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Getting closer to the day it's finally coming home. Very Happy
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
indianpeaksjoe
PostPosted: Tue Jul 15, 2025 10:30 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
I have to admit there has been a little bit of scope creep in this project.
I originally called them to put on rear discs, a spin on oil filter adapter and new shocks. Which then turned into rebuilding the motor and trans because I knew they were messed up but was in denial. They were just worse than I had assumed. And then we added an LSD, modding up the motor for more power, new front bumper, repainting the old rear bumper, adding oil temp, pressure and tach, new shifter bushings, new clutch, remote oil filter, oil breather, etc.
I really should have had them cut off the trailer hitch on the rear bumper before getting it powder coated, oh well...
-Joe
ORANGECRUSHer
PostPosted: Tue Jul 15, 2025 10:44 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
they sure are taking their time
Brian H.
67rustavenger
PostPosted: Tue Jul 15, 2025 11:32 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Shhhh, Brian. You're saying the quiet part out loud.
Buy Once, Cry Once!
ORANGECRUSHer
PostPosted: Tue Jul 15, 2025 12:39 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
that's cuz I'm stoopid Embarassed
Brian H.
indianpeaksjoe
PostPosted: Tue Jul 15, 2025 3:23 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Yeah, I know, I was out of town for 6 weeks and did not push them, so part my fault but also... nothing I can do about it.
-Joe
indianpeaksjoe
PostPosted: Mon Jul 21, 2025 8:53 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
It drives!!!
-Joe
67rustavenger
PostPosted: Tue Jul 22, 2025 11:42 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
indianpeaksjoe wrote:
It drives!!!
-Joe
Sweet!
The only things missing in that video is, You your dog and the car offroading in Moab. Lol!
Buy Once, Cry Once!
indianpeaksjoe
PostPosted: Wed Jul 23, 2025 6:39 am    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
Kicking a man when he's down Smile
-Joe
67rustavenger
PostPosted: Wed Jul 23, 2025 1:34 pm    Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me Reply with quote
-Joe
Anything I can do to help "Kick" this process along! Very Happy
Buy Once, Cry Once!
Page 4 of 4
