Please advise: Semaphore WD40 Woes!
RockStock
RockStock is offline
PostPosted: Sun Jul 13, 2025 3:56 pm    Post subject: Please advise: Semaphore WD40 Woes! Reply with quote
I foolishly (yes, I know) squirted some WD40 penetrating oil on a semaphore a year or so back,as it seemed to be sticking…as it was, it probably just needed a cleaner earth or cleaner wiring contacts
Then I read don’t do this, as it can will short out the solenoid…
I’ve waited some months, hoping the wd40 would evaporate, before trying again, but it smokes a little when I go to fire her up
Assuming I haven’t burnt it out:
Does anyone have any tips on how to clean it up/decontaminate it?
I’m also wondering whether it is possible/easy to remove the solenoid rod to clean the rod/inside the solenoid coil…maybe by removing that small pivot pin at the top?
Overall the semaphore looks to be in very good condition bar the missing solenoid coil wrapping.
Its matching pair is working fine.
Thank you
RS
-StockRocks-
Matts Bug Parts
Matts Bug Parts is offline
PostPosted: Sun Jul 13, 2025 9:31 pm    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
I am happy to help. Its best if u call me. I will send a pm.
Matt
Bub
Bub is offline
PostPosted: Mon Jul 14, 2025 8:16 am    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
Electrical contact cleaner will clean it right up, and all the gunk will rinse out.
Hard to tell if any damage is done, but that's where I'd start. To lube mine I use some fairly light machine oil, almost like thread cutting oil? I dunno, it's in a squirt can here on a shelf.
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jul 14, 2025 8:35 am    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
Sewing machine oil might also be a good choice.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Bub
Bub is offline
PostPosted: Mon Jul 14, 2025 8:45 am    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
Yes! that too...
.it just occurred to me that I wonder if it's not actually a 'short' from the Wd40. When it flips and heats up it'll burn off that lubricant pretty quick, and you've seen WD40 smoke...it'll look like a damn fire.
I swear those flappy signals draw more amps than the starter.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Jul 14, 2025 7:08 pm    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
You can rewrap the solenoid coil with High temperature electrical harness tape. Amazon has several possibilities.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
esde
esde is offline
PostPosted: Tue Jul 15, 2025 9:35 am    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
You only need to lubricate the pivots. Any solvent in the coil can damage the insulation..
I’d use a little contact cleaner followed up with compressed air to blow it clean and dry..
SD
modok wrote:
BulliBill
BulliBill is offline
PostPosted: Wed Jul 16, 2025 8:28 am    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
I'd at least talk with Matt at "Matts Bus Parts" for his expert advice, or have him fully go thru that semaphore. Despite any cost, in the long run you'll be happy you did!
BIll Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Matts Bug Parts
PostPosted: Sat Jul 26, 2025 9:30 am    Post subject: Re: Please advise: Semaphore WD40 Woes! Reply with quote
I did advise the writer almost immediately after my post.
Some advice: you never want to use any type of oil on semaphores. Unless they are sitting on a shelf and you want to stop and rust over the next 50 years.
All oil will do is attract and hold dust and dirt further impairing their function. Over the years a lot of crude accumulates in the coil affecting performance. A shot of oil can temporarily improve performance only to worsen in time.
Matt
