MFerioli Samba Member
Joined: June 19, 2016 Posts: 127 Location: Colorado Springs
Posted: Thu Jul 17, 2025 10:21 am Post subject: Re: Gowesty gas tank vs others? |
thanks for the link, I was going to look for some sealant like that.
Excellent work on that tank mod, you shouldn't have any issue with that setup.
I agree, all these companies know how to make the tank, it's more of whether they choose to do a good job or just don't care much. For some reason though, none of them seem to care about packing them well for shipping. _________________ 1989 Westfalia full camper, 2WD, 4-speed, 2.1 WBX |
Posted: Fri Aug 01, 2025 11:32 am Post subject: Re: Gowesty gas tank vs others? |
well, I noticed that the filler neck hole area was also dented so I ended up returning it and getting a new one. New one arrived today and only one corner is bent, no dents at all! I also ended up getting it 10$ cheaper. $172 and change all in.
Maybe I'll have the van back together soon and focus on other issues. ha! _________________ 1989 Westfalia full camper, 2WD, 4-speed, 2.1 WBX |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4410 Location: ABQ NM USA.... Except when not
Posted: Fri Aug 01, 2025 12:10 pm Post subject: Re: Gowesty gas tank vs others? |
MFerioli wrote: |
Maybe I'll have the van back together soon and focus on other issues. ha! |
good on 'ya for doing the return...if we accept crap, we'll get crap, its only after the bean counters see that shipping is costing them only then will they make adjustments to packaging and/or lean on the shipper _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
tdivan82  Samba Member
Joined: September 17, 2023 Posts: 278 Location: Virginia
Posted: Fri Aug 01, 2025 2:10 pm Post subject: Re: Gowesty gas tank vs others? |
Its too bad these are all straight copies of the original design. Would be nice if someone made one that had a larger volume. 80 liters (21 gal) would be a worthwhile upgrade. _________________ - George
'82 Westy TDI (ahu)
'96 Passat TDI |
Posted: Fri Aug 01, 2025 2:16 pm Post subject: Re: Gowesty gas tank vs others? |
tdivan82 wrote: |
Its too bad these are all straight copies of the original design. Would be nice if someone made one that had a larger volume. 80 liters (21 gal) would be a worthwhile upgrade. |
I wonder if there would have to be a certification process for that? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10377 Location: Orbiting San Diego
Posted: Fri Aug 01, 2025 3:36 pm Post subject: Re: Gowesty gas tank vs others? |
There was a 20+ gal VW RSA tank you could buy but they went NLA years ago.
I knew a few people with them in their Vanagons.
Ken at Vanagain sold them at one time.
Not exactly bolt-in but not too difficult.
The tank simply extended back farther than the original tank.
edit: here are some old threads about them
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Mark
tdivan82 wrote: |
Posted: Fri Aug 01, 2025 4:45 pm Post subject: Re: Gowesty gas tank vs others? |
crazyvwvanman wrote: |
There was a 20+ gal VW RSA tank you could buy but they went NLA years ago. |
Very cool, yes that's exactly what I'd like as an upgrade. Too bad nobody is selling them any more. Someone should locate one and produce a run of them. A right profitable venture that would be. You could probably sell tens of them. TENS!! _________________ - George
'82 Westy TDI (ahu)
'96 Passat TDI |
kamzcab86 Samba Moderator
Posted: Fri Aug 01, 2025 4:49 pm Post subject: Re: Gowesty gas tank vs others? |
Except even they have the stupid "saddle" in the center.  _________________ ~Kamz
2016 Golf GTI S
