vanis13 Samba Member
Joined: August 15, 2010 Posts: 4434 Location: ABQ NM USA.... Except when not
Posted: Sat Jul 19, 2025 9:07 pm Post subject: Re: Gas can in luggage rack? |
I got something similar at the dollar store for $1.25.
Cut off some of the tip to get a bigger final diameter and thus a better flow rate.
Like the extended side, makes pouring in way better. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
RicMcK  Samba Member
Posted: Sun Jul 20, 2025 8:15 am Post subject: Re: Gas can in luggage rack? |
I have two 10 liter flat plastic fuel containers (Amazon or AliExpress). They are the same height as the luggage rack I can fit 3 across if I need to. Never had a leak issue.
Hard to see I strap them in place with 1" webbing. _________________ Rick McK
Seattle
89 Westfalia-2.2L WBX "VINNY"
2006 TDI Jetta
1936 Ford Pick up
70 tin top, 700k mi when sold in 91
58 split window (first car)
58 split window bug - long gone. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8413 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jul 20, 2025 10:55 am Post subject: Re: Gas can in luggage rack? |
RicMcK wrote: |
I have two 10 liter flat plastic fuel containers (Amazon or AliExpress). They are the same height as the luggage rack I can fit 3 across if I need to... |
Pic or link to the actual container? I’m curious if the spout opening is on the top or side when “strapped in”...???
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
RicMcK  Samba Member
Posted: Sun Jul 20, 2025 12:58 pm Post subject: Re: Gas can in luggage rack? |
It's like this one. I can't find the orginal vendor
https://shop.carmart.ae/product/force-usa-flat-plastic-jerry-can-10-liter-2/
Pre tariffs, (late winter I got them from both AliExpress and Amazon. It looks like they are hard to get now. _________________ Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Posted: Sun Jul 20, 2025 4:44 pm Post subject: Re: Gas can in luggage rack? |
Quote: |
…I’m curious if the spout opening is on the top or side when “strapped in”... |
FYI…Side, it seems. Keep us posted on leakage (if any)…
"The WonderVan"
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5716 Location: Bemidji, MN
Posted: Sun Jul 20, 2025 5:12 pm Post subject: Re: Gas can in luggage rack? |
yahp... one really wants the filler cap, any openings on the top of the resting position as well as dip tubes, fuel outlets, etc. it's a requirement for the marine world and is a stipulation that is borne out from tragedy with plastic threads and expansion in the hot sun. you'll notice all the RotopaX storage cells are top fill oriented.
underbody fuel *tanks* obviously have fuel outlets below the gravity line but they are permanent affairs and still have fuel fillers above the gravity line.
race fuel cells, an even more stringent application, have everything on the topside.
but... there's no law preventing you from doing what you want. well, maybe in some jurisdictions but enforcement will be weak. orient the aux fuel tank how you want and spin the big wheel. c'mon Big Money. _________________ -dan
www.thefixitworkshop.com |
RicMcK  Samba Member
Posted: Sun Jul 20, 2025 5:57 pm Post subject: Re: Gas can in luggage rack? |
Yes and. I do check them and be sure they don't get pressurized due to the sun I do have to piece of white plastic on top during the summer. I also leave plenty of head room. Yes I know it's not 'the best ", however so far so good,and it's not a fill and forget solution. _________________ Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
hdenter Samba Member
Joined: October 14, 2008 Posts: 2940 Location: San Luis Obispo, CA
Posted: Sun Jul 20, 2025 6:01 pm Post subject: Re: Gas can in luggage rack? |
I have to say, I'm not a fan of the idea of having a gas can in the overhead luggage rack. In the event of an accident, if the gas can is damaged, where does that leaking fuel go? It drips down over the front doors and open or broken windows. If gas cans are mounted in the rear, if there is an accident, the leaking fuel is much more likely to run down in places where there are no passengers trying to escape the vehicle or first responders rendering assistance...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
zerotofifty Samba Member
Posted: Sun Jul 20, 2025 6:31 pm Post subject: Re: Gas can in luggage rack? |
I dont think tariffs have anything to do with this can not being available, as the site you linked that is selling it that is out of stock is a site in the United Arab Emirates (UAE), offered for sale in local UAE money..
However MidWest Can makes American made plastic gas cans....
https://www.midwestcan.com/military.html
Consider the availability of some cans we previously could buy might be restricted because to EPA/CARB spout regulations. Hopefully these regulations can be removed, as it is real pain to use some of these EPA/CARB regulated spouts. We have way too much regulation.  _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
RicMcK  Samba Member
Posted: Sun Jul 20, 2025 7:46 pm Post subject: Re: Gas can in luggage rack? |
Yes, I noted the out of stock problem.
The ones that I got have some kind of safety spout. You have to actively push the spout into the filler hole. I think it's a supply chain issue.
Tariff price hike = no ordering = no stock. _________________ Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Posted: Sun Jul 20, 2025 8:10 pm Post subject: Re: Gas can in luggage rack? |
[/tariff discussion] . . . as not germane to the “what gas can fits?” question (which is the original topic of the thread).
<shrug>
"The WonderVan"
Posted: Sun Jul 20, 2025 8:32 pm Post subject: Re: Gas can in luggage rack? |
RicMcK wrote: |
Tariff price hike = no ordering = no stock. |
They are out of stock in the United Arab Emirates, per the prior posted link. Out of stock in the UAE has nothing to do with American tariffs.
Those mandated safety spouts cause a price hike by the way, yet you were able to buy a can with such a price hiked spout, so that kind of blows a hole in the price hike = no ordering=no stock theory you wrote about.
Buy American and avoid the tariff.
Of course I still have the near 10% sales tax I have to pay, that too is a price hike, and it is on all automotive products I buy. Price hike (10%) does not equate to no orders, nor to no stock. _________________ Sorry About That Chief.
Words to live by. |
kamzcab86 Samba Moderator
Posted: Sun Jul 20, 2025 10:01 pm Post subject: Re: Gas can in luggage rack? |
zerotofifty wrote: |
I dont think tariffs have anything to do with this can not being available, as the site you linked that is selling it that is out of stock is a site in the United Arab Emirates (UAE), offered for sale in local UAE money.. |
The sticker on the can says Force USA. Force USA is a gym equipment manufacturer: https://www.forceusa.com/ . Force Off-road no longer exists, based on a quick search. That's probably the reason why only mid-East retailers appear and why they're "out of stock", even on the large version.
Edit: Looks like, perhaps, they're now X-Offroad, or Force USA's offroad products were bought by them: https://www.xoffroad.world/1180/plastic-jerry-can-red-2-6-gallon-10-litres/ .
because EPA/CARB regulations. |
Even VP now has to call their famous cans a "utility jug" or "liquid container" because their spouts are not approved for fuel usage by the [insert your preferred descriptive words for our government].
I had to put a couple gallons of gasoline into my Cabriolet several years ago after some fuel tank work and the little red can I've had for a long while for emergency use was infuriating. Finally discovered that VP makes a small version of their 5-gallon jug and found one locally... sanity spared. _________________ ~Kamz
2016 Golf GTI S
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23911 Location: NYC/Upstate/ROW
Posted: Mon Jul 21, 2025 3:03 am Post subject: Re: Gas can in luggage rack? |
hdenter wrote: |
Hans |
Most of those plastic cans shown aren’t addressing chafe adequately. Anywhere plastic touches something in an automotive application chafe has to be addressed. I chafed open a fuel tank on a boat once just touching a fiberglass wall, interesting when you are offshore and your boat is full of gas fumes. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
dougnlina  Samba Member
Joined: January 19, 2016 Posts: 301 Location: San Francisco, CA
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4620 Location: United States, Iowa
Posted: Mon Jul 21, 2025 2:49 pm Post subject: Re: Gas can in luggage rack? |
This 5G unit "fits" but I haven't carried gas in it up there.
Nor have I made straps for under here, but it fits here too..
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
shagginwagon83 Samba Member
Posted: Thu Jul 31, 2025 7:37 am Post subject: Re: Gas can in luggage rack? |
squeegee_boy wrote: |
shagginwagon83 wrote: |
It is on the side. It isn't to prevent leaking. You can buy new gaskets for these, but no need to.
I would keep a set in the van somewhere. I've had a set of these for ~18 years now, and have replaced the seals twice. They lasted 7 ish years for me, more or less.
Super cheap insurance if they suddenly start to leak on the road.
Robyn |
I ate my own words. I checked mine today and it is leaking. Luckily I have a spair gasket in the van. Hopefully it is still good _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin
Instagram: @joannthevan |
