MIDNR Samba Member
Posted: Sat Jul 12, 2025 10:16 am Post subject: 69 Beetle, Shifting problems |
I have a new to me 69 beetle and I recently started having problems shifting into 1 or 2nd. Issue occurs when moving or when starting from a stop.
I did some research on the forum and started by taking apart my shifter. I noticed that the lockout plate is considerably thicker than others I have seen. Could this be my problem?
Photos for reference
NJ John Samba Member
Joined: September 21, 2007 Posts: 2891 Location: HdG, MD & NJ
Posted: Sat Jul 12, 2025 10:40 am Post subject: Re: 69 Beetle, Shifting problems |
That extra thickness is a “Quick Shift” that someone added. You can remove it and give it a try. Keep the factory plate. You may have to use shorter bolts. Check the shift rod bushing right there at the shifter. Then the one under the seat. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
MIDNR Samba Member
Posted: Sat Jul 12, 2025 11:09 am Post subject: Re: 69 Beetle, Shifting problems |
Thanks!
Did a little more investigating, found the problem. New coupler and bushings ordered.
my3bugs Samba Member
Joined: June 18, 2003 Posts: 871 Location: Moreno Valley
Posted: Sat Jul 12, 2025 11:36 am Post subject: Re: 69 Beetle, Shifting problems |
i remember putting in one of those quick shift kits in my youth , i think i took it back out the same day , didnt like it . |
Posted: Sat Jul 12, 2025 12:02 pm Post subject: Re: 69 Beetle, Shifting problems |
Everyone says those red bushing break and there you go. Also, add safety wire through that grub screw. They can eventually loosen. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Cusser Samba Member
Joined: October 02, 2006 Posts: 33098 Location: Hot Arizona
Posted: Sat Jul 12, 2025 12:37 pm Post subject: Re: 69 Beetle, Shifting problems |
I hope your new coupler actually fits, mine did not, was too small to fit over shift rod. I transferred the bushings into the old coupler. Why someone cannot copy a part correctly - beyond my understanding !!!!
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 367 Location: Eastern north carolina
Posted: Sat Jul 12, 2025 1:22 pm Post subject: Re: 69 Beetle, Shifting problems |
While you have it apart you may want to check the shift rod bushing that is a couple of inches behind the shift rod socket that the bottom portion of the shifter sits in. I just did one on a 74 bug and the bushing had broken and fallen out of its holder. You have to slide the shift rod all the way forward and out of the bushing holder to replace it. Good luck-Bob |
Cusser Samba Member
Posted: Sat Jul 12, 2025 1:47 pm Post subject: Re: 69 Beetle, Shifting problems |
Bobs67vwagen wrote: |
While you have it apart you may want to check the shift rod bushing that is a couple of inches behind the shift rod socket that the bottom portion of the shifter sits in. |
Absolutely !!!
volky1970 Samba Member
Joined: November 11, 2006 Posts: 407 Location: A very hot Island with BUGS that KILL!!!
Posted: Wed Jul 16, 2025 1:00 pm Post subject: Re: 69 Beetle, Shifting problems |
NJ John wrote: |
Also, add safety wire through that grub screw. They can eventually loosen. |
Yep, recently I had my tranny rebuild and for some reason forgot to put the wire on the grub screw. Long story short, one night around 11:00 pm and raining, I couldn't shift, pulled to the side and started inspecting until I saw the screw loose.
I ride with tools for everything just in case. Tighten it, and the next day used two paper clips. _________________ 1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors. |
CoastalBug Samba Member
Posted: Wed Jul 16, 2025 1:41 pm Post subject: Re: 69 Beetle, Shifting problems |
I'm having the same issue. Ground the gears in going into reverse, first, and second all day yesterday. I assume because she's being driven regularly now that I'll have to look into the same things you are. _________________ Chris - 1968 Beetle Sedan, a book, and a lot of determination. |
olnick Samba Member
Joined: September 12, 2010 Posts: 44 Location: Milford NH USA
Posted: Thu Jul 17, 2025 1:08 pm Post subject: Re: 69 Beetle, Shifting problems |
Don't waste your time with the OEM style shifter bushing! Look up on line for a two piece replacement bushing. Mine was ~ $40.00 well worth the investment!! NO need to remove the shift rod only remove it from the transaxle to allow additional movement. total time for me was about an hour out and in. this included removing the driver seat for better access.
after this was installed the shifter works like a straight into the transmission shifter lever ZERO free play and shifts smooth as silk!!
Olnick |
RLFD213 Samba Member
Posted: Thu Jul 17, 2025 2:36 pm Post subject: Re: 69 Beetle, Shifting problems |
lol… that coupler is done…. Buy a good coupler. There is a guy in the classifieds that sells good solid shift couplers. Keep the short shift kit and you’ll enjoy the shifting. |
abicat Samba Member
Joined: May 18, 2018 Posts: 2 Location: Pacific Northwest
Posted: Tue Jul 22, 2025 4:01 pm Post subject: Re: 69 Beetle, Shifting problems |
Can anyone recommend best place to order a replacement shifter for 68 beetle? |
Posted: Tue Jul 22, 2025 5:43 pm Post subject: Re: 69 Beetle, Shifting problems |
There always seems to be quite a few listed in the samba classifieds in the 68 and newer parts section. Check there. |
