Offset intake valve
BFB
BFB is offline
PostPosted: Sat Jul 19, 2025 9:50 am    Post subject: Offset intake valve Reply with quote
ok, so ive been reading on some head & valve stuff again recently and came across a couple articles about the big hp v8 guys that run 2 valve / cylinder heads moving the intake valve over so its more centered in the bore / chamber. This obviously allows a bigger intake along with unshrouding but the size of the exhaust valve has to be sacrificed.
It got me to thinking and wondering why it’s not done in the vw community? Or maybe it is, i dont know? Can’t say ive ever seen anything on it before, hence me bringing it up.
Obviously opening up the heads for larger cylinders more or less centralizes the intake valve more and unshrouds it. But why not move the exhaust valve over and make room for larger intake? Considering the design of vw engines youd think itd wouldnt be any big deal for the PR tubes to shift over some and rockers could be shimmed over too , to a certain extent anyhow.
I could see it being too much work vs return if modifying heads but i wouldnt think itd be that big of a deal for a head designer / manufacturer so make ?
Maybe they already do this if nothing else to a small degree to get more room between the valves?
I dunno? Thoughts?
Most experts aren't.
Brian_e Premium Member
Brian_e is offline
PostPosted: Sat Jul 19, 2025 10:46 am    Post subject: Re: Offset intake valve Reply with quote
Been done forever in the Vw race stuff.
The new 063 heads have the exhausts moved over .050”.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
Alstrup
Alstrup is offline
PostPosted: Sat Jul 19, 2025 12:07 pm    Post subject: Re: Offset intake valve Reply with quote
Yes.
In smaller bore race stuff I have moved the intake over by 0,100" and tilted it 2 degrees more. Thats partly contributing to get 160 cfm @ 0,530" through a 37 mm valve in a 77 mm bore. This fall I will begin on a new version of such a head. My goal is to find 5-10 cfm more with the same port volume. Possible (?) Time will tell.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
dangerous
dangerous is offline
PostPosted: Wed Jul 23, 2025 3:36 pm    Post subject: Re: Offset intake valve Reply with quote
Hi Alstrup, can you share some pictures of the changed angle? I assume you went 11.5 degrees? Where is the offset, in the chamber or top of the guide? I guess you want the tip of the valve still in line with the others.
Alstrup
Alstrup is offline
PostPosted: Thu Jul 24, 2025 9:18 am    Post subject: Re: Offset intake valve Reply with quote
Sorry. no pics. They were lost during a reboot of a German Website a couple of years back, and I had no back up. But the intakes were moved 2,5 mm sideways toward the exhaust and then tiled 2 degrees away from the spark plug, so 2 degrees less actually. This served 3 purposes. 1. getting the valve away from the spark plug. Getting more "free" room on the fast (plug) side. 3 A straighter shot from the manifold flange downwards.
This exersise positioned the outer diameter of the larger valve in the same position in relation to the cylinder wall as a std 33 mm valve.
chrisflstf
chrisflstf is offline
PostPosted: Thu Jul 24, 2025 9:26 am    Post subject: Re: Offset intake valve Reply with quote
Is this done on a head before its machined to locate the valve guide and seat location?
BFB
BFB is offline
PostPosted: Thu Jul 24, 2025 9:56 am    Post subject: Re: Offset intake valve Reply with quote
glad to see this thread has some interest & movement.
Alstrup, im a little confused as to which way you tilted the exhaust valve ? tip of the valve away or towards the plug?
also how'd the tilted valve work with the rockers?
Brian_e is offline
PostPosted: Thu Jul 24, 2025 10:17 am    Post subject: Re: Offset intake valve Reply with quote
Usually you are using a larger OD valve seat, so there is enough room there, and then a slightly oversize guide, or weld up the guide holes. Then the spring boss is usually cut down for dual springs, so there is enough material to work with there also.
The guide holes are usually done first, and then everything registers off them to keep thing concentric.
Brian
-Modok
Alstrup
Alstrup is offline
PostPosted: Fri Jul 25, 2025 3:11 am    Post subject: Re: Offset intake valve Reply with quote
Baqsicly what we did here on a 1460 cc. Lotus Coventry engine. Power achieved with only 252 degrees @ 0,050", 0,480" valve lift and 10,5 CR.
nsracing
nsracing is offline
PostPosted: Fri Jul 25, 2025 9:04 am    Post subject: Re: Offset intake valve Reply with quote
I have talked about this stuff years ago. It is a machining challenge. You have to make custom guides if you move centers in any direction. It is a one-off job.
Roger Crawford did lots of them on race heads. If you will be doing Titanium valves might as well.
It is not for the meek. Either you have a dedicated machinist/s to do all that work or do it yourself.
Same goes for angling the plugs -more welding and machining.
Dedicated jigs be nice to have if you will do lots of these.
Enjoy. Laughing
