Paint engine bay with spray cans
Yannvanh
Yannvanh is offline
PostPosted: Thu Jul 24, 2025 7:06 am    Post subject: Paint engine bay with spray cans Reply with quote
Hello,
I am almost ready for painting the engine compartment in my split bus.
I sanded everything and sprayed 2 coats of epoxy primer.
Did it with a spray gun but i ended up bumpin in to everything when i wanted to spray the tiny spots and corners
Because its primer it sands out easily but i don't want to bump against everything with final paint.
I have seem some good results with spray cans so does anybody did it before and can tell me how many spray cans i need?
Thanks!
'66 vw splitbus project:
Instagram page:
yannicks_splitbus_project
Always there to help!
chrisflstf
chrisflstf is offline
PostPosted: Thu Jul 24, 2025 9:06 am    Post subject: Re: Paint engine bay with spray cans Reply with quote
There are smaller spray guns for confined spaces
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu Jul 24, 2025 12:04 pm    Post subject: Re: Paint engine bay with spray cans Reply with quote
I have used krylon and rustoleum spray cans to paint many things over the last 50 years. It is pretty good stuff and easy to touch up it it gets damaged. I would say get at least 3 normal size cans. Try a small inconspicuous area first to make sure it is compatible with the primer you put on. Wear a respirator in a confined space like that. Good luck-Bob
Bikerndiver
Bikerndiver is offline
PostPosted: Sat Jul 26, 2025 9:52 am    Post subject: Re: Paint engine bay with spray cans Reply with quote
There are places that will put real auto paint into spray cans for you... Or, buy an airbrush gun, can't get much smaller than that!
1966 Manx clone (possibly a Joe Poty Enterprises) named SANDY. '70 to '73 1300 cc w/1600 DP heads, twin carbs and headers
Bobs67vwagen
PostPosted: Sat Jul 26, 2025 12:50 pm    Post subject: Re: Paint engine bay with spray cans Reply with quote
I used some of that original color paint that is mixed and put into spray cans a few years ago on one of my civics. It has held up pretty well but is now starting to crack. If I recall correctly they are a lacquer based product and you put a lacquer based clear on top. At the time I bought it it was about 4 times the price of a can of krylon or rustoleum. I live in North Carolina and the car stays outside so it gets some pretty intense sun, so I would say all in all it held up pretty well and the color match was good.
