CasteSystems Samba Member
Joined: September 19, 2005 Posts: 36 Location: Norwood, NJ
Posted: Sun Jul 27, 2025 2:10 pm Post subject: 2490cc Type 1 |
Our shop has been working on this engine project for the first half of this year. Yes, a 2.5l Type 1 (2498cc) has been possible before with use of a custom or aftermarket case or 90mm crank but as we all know they require a LOT of case clearancing and do not normally rev very high. We really wanted to make a 2.5l utilizing a true Type 1 mag case and do it without sacrificing too much strength for long term use. The other goal was a true 200 wheel horsepower NA without being too high strung, a true street and driver engine that can scare you and also cruise on the highway. So far this has done both. The displacement was achieved with fitting 96mm pistons to the type 1 while maintaining the same cylinder wall thickness as a standard 94mm. The case and cyl head only had to lose .020" to achieve this for adequate cooling with the cylinder walls. Currently without too much fuss we have achieved 203whp and 172ft/lbs, again this is at the wheels. Normal dynojet loss calculations puts this around 240-245 crank HP and 202-209 crank tq.
The specs of the setup below:
2490cc 96x86mm built/machined by CSP
JE Pistons/ custom machined cylinders
CB Performance Chromalloy Crankshaft
Super Race Connecting Rods w/ Chevy Journals
CB Performance SF Cylinder Heads (46x37.5mm valves)
11.2:1 Compression
Eagle Race Camshaft
1.4:1 Ratio Rockers
Berg 2.0" merge 4-1 Header
48mm ITBs w/ port matched manifolds
Custom CSP/Zarpspeed tucked engine harness
MaxxECU standalone ECU Tuned by Matt Ivan @vw1320
Flex Fuel Capability, E85 and Pump 93oct
Bergmann Fan Shroud Kit w/ turn style linkage
Billet Valve Covers, custom catchcan/breather setup
Our overall power testing will continue on our dynojet, (really want 210whp) and also overall endurance and longevity, but hopefully this engine, harness, ECU setup and tuned MAP will be something we will be able to offer to the community in the next year roughly. So far it shows to be promising, and looking to gauge interest and just a general sense of the potential overall to be able to contribute something new/out of the box to the community. No details on costs or anything yet as we are not there. But feel as though we are at a decent point to share current status and progress moving forward.
Thanks for checking it out
_________________ Caste Systems Performance
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
www.CSPerformance.net |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7952 Location: Videbaek Denmark
Posted: Sun Jul 27, 2025 3:16 pm Post subject: Re: 2490cc Type 1 |
Lets see the rest of the power curve. the peak alone is not interesting for a street engine "everything else is"
Also, the dynojet can measure transmission loss, if it is set up for it of course, which can give you real FWHP numbers instead of guesstimate.
Yes, such an engine is not just buy and assemble. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Rome Samba Member
Joined: June 02, 2004 Posts: 10783 Location: Pearl River, NY
Posted: Sun Jul 27, 2025 4:19 pm Post subject: Re: 2490cc Type 1 |
James, I'm glad you made the VW community aware of this special engine!
To theSamba readers- James showed his custom '68 Beetle at the Bug-a Fair VW show in Terryville, CT last month. He also drove it to a local VW gathering near his shop 2 weeks ago where I saw it in person. Very noteworthy is what James told me at the gathering, that he finished the engine installation just a few nights before the Bug-a-Fair and drove it to the meet- approx. 95 miles, mostly highway.
Over the last 2 decades, James converted his Beetle to right-hand drive, and "aged" it with early 60's fenders and engine lid to create a Herbie (The Love Bug) tribute. Significant modifications to the suspension along with Porsche "twist" alloy rims. He also recently installed a modern LCD instrument cluster and control pad for his engine management programs.
The "CSP" in his post above refers to his shop in northern NJ. Not to be confused with Custom and Speed Parts in Germany.  |
Victor H Samba Member
Joined: November 28, 2004 Posts: 121 Location: Lexington, South Carolina
Posted: Sun Jul 27, 2025 4:47 pm Post subject: Re: 2490cc Type 1 |
You're making your peak power around 6,100 rpm? Seems like you have the ingredients for higher rpm.
What are the cam specs? |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4237 Location: San Diego
Alexander_Monday Samba Member
Joined: November 09, 2007 Posts: 457 Location: Springfield Missouri
Posted: Mon Jul 28, 2025 4:55 am Post subject: Re: 2490cc Type 1 |
Looking at the full dyno curve there is a dip between 4K & 5K that looks like it could be valve spring harmonics.
Just an observation and possible reason. _________________ Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
Alexander_Monday->What were the rings gapped at?
bedlamite->Almost enough.
| andk5591 wrote: |
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell. |
Posted: Mon Jul 28, 2025 4:58 am Post subject: Re: 2490cc Type 1 |
Also, kudos to you for getting a 90mm crank in a mag case.
How bad was the camshaft to crank and rod interference? _________________ Danth’s or Parker’s Law:
| andk5591 wrote: |
Posted: Mon Jul 28, 2025 6:11 am Post subject: Re: 2490cc Type 1 |
OK. Its always a b*tch to get the harmonics dialed down to a minimum with agressive cams etc. But it looks to me as the induction length is on the short side. I would definitely try to increase induction length with 20-25 mm and see where that gets you.
You can probably also play a little with the sec. collector volume/length. Get those two factors closer to right and the harmonics will 90% certain be reduced by 50-75%.
Have fun.
T _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
RickS Samba Member
Posted: Mon Jul 28, 2025 6:58 am Post subject: Re: 2490cc Type 1 |
| Alexander_Monday wrote: |
How bad was the camshaft to crank and rod interference? |
He is not running a 90mm crank. He has 96mm pistons x 86mm crank. |
Posted: Mon Jul 28, 2025 7:22 am Post subject: Re: 2490cc Type 1 |
| RickS wrote: |
Thanks for the clarification, I obviously did not read it slow enough and was distracted by Monday morning calls and texts.
86 isn't a walk in the park, building an 86 X 94 now and 82 was way less headache.
I wouldn't even want to tackle the 96 bore. _________________ Danth’s or Parker’s Law:
| andk5591 wrote: |
RickS Samba Member
Posted: Mon Jul 28, 2025 8:06 am Post subject: Re: 2490cc Type 1 |
| RickS wrote: |
I wouldn't even want to tackle the 96 bore. |
I recently built an 86 mm stroke engine. It went together just like stock. I did use a TF-1 case though!  |
Posted: Mon Jul 28, 2025 8:20 am Post subject: Re: 2490cc Type 1 |
| RickS wrote: |
Cheater!
Lol, I wish I would have used one.
| andk5591 wrote: |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 863 Location: South Bay LA, California
Posted: Mon Jul 28, 2025 11:23 am Post subject: Re: 2490cc Type 1 |
My God can you even slip a piece of paper between there?
I don't feel nearly as nervous about my cam to crank clearance after seeing this... |
Posted: Mon Jul 28, 2025 11:30 am Post subject: Re: 2490cc Type 1 |
No, it actually interferes for a short distance.
Going to have to grind some off the crank counterbalance and get it re balanced. _________________ Danth’s or Parker’s Law:
| andk5591 wrote: |
txoval Samba Member
Joined: January 23, 2004 Posts: 3894 Location: The Woodlands, TX
Posted: Mon Jul 28, 2025 12:05 pm Post subject: Re: 2490cc Type 1 |
Definitely agree on TF1
Then you could go 86mm crank and 4” pistons |
RickS Samba Member
Posted: Mon Jul 28, 2025 12:42 pm Post subject: Re: 2490cc Type 1 |
| txoval wrote: |
Then add some JPM MS230 heads! |
Posted: Mon Jul 28, 2025 4:56 pm Post subject: Re: 2490cc Type 1 |
That is not the accurate dyno chart posted above by Chrisflst, that was initial testing also using a tri-y 1.75" sebring style exhaust which was build for the car's old 2110cc.
This is just changing from that old exhaust to the berg 2" header
Alstrup that was the next thing we were thinking, try roughly 1" taller velocity stack. _________________ Caste Systems Performance
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
Posted: Tue Jul 29, 2025 10:01 am Post subject: Re: 2490cc Type 1 |
| txoval wrote: |
Agreed, but the goal here was a true 2.5L utilizing a mag case for cost with reliability. _________________ Caste Systems Performance
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
94touring Samba Member
Joined: October 24, 2020 Posts: 653 Location: Tulsa - OK
Posted: Tue Jul 29, 2025 10:04 am Post subject: Re: 2490cc Type 1 |
| That's very cool, though I'm confused with the concept of reliable with the mag case versus the already clearanced and pinned alloy cases. Is that an all type 4 main crank? |
Posted: Tue Jul 29, 2025 10:10 am Post subject: Re: 2490cc Type 1 |
Still type 1 mains. The case is clearanced for 86mm crank which I think these days is considered clearance wise safe for longevity, vs 88/90mm cranks which need a LOT more clearancing to both case and camshafts. Using the mag case then lowers the cost of not needing something aftermarket like TF-1, etc and still make a larger displacement motor capable of 200whp NA pretty easily without being over stressed hardware and tuning wise. _________________ Caste Systems Performance
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
