2490cc Type 1
CasteSystems
CasteSystems is offline
PostPosted: Sun Jul 27, 2025 2:10 pm    Post subject: 2490cc Type 1 Reply with quote
Our shop has been working on this engine project for the first half of this year. Yes, a 2.5l Type 1 (2498cc) has been possible before with use of a custom or aftermarket case or 90mm crank but as we all know they require a LOT of case clearancing and do not normally rev very high. We really wanted to make a 2.5l utilizing a true Type 1 mag case and do it without sacrificing too much strength for long term use. The other goal was a true 200 wheel horsepower NA without being too high strung, a true street and driver engine that can scare you and also cruise on the highway. So far this has done both. The displacement was achieved with fitting 96mm pistons to the type 1 while maintaining the same cylinder wall thickness as a standard 94mm. The case and cyl head only had to lose .020" to achieve this for adequate cooling with the cylinder walls. Currently without too much fuss we have achieved 203whp and 172ft/lbs, again this is at the wheels. Normal dynojet loss calculations puts this around 240-245 crank HP and 202-209 crank tq.
The specs of the setup below:
2490cc 96x86mm built/machined by CSP
JE Pistons/ custom machined cylinders
CB Performance Chromalloy Crankshaft
Super Race Connecting Rods w/ Chevy Journals
CB Performance SF Cylinder Heads (46x37.5mm valves)
11.2:1 Compression
Eagle Race Camshaft
1.4:1 Ratio Rockers
Berg 2.0" merge 4-1 Header
48mm ITBs w/ port matched manifolds
Custom CSP/Zarpspeed tucked engine harness
MaxxECU standalone ECU Tuned by Matt Ivan @vw1320
Flex Fuel Capability, E85 and Pump 93oct
Bergmann Fan Shroud Kit w/ turn style linkage
Billet Valve Covers, custom catchcan/breather setup
Our overall power testing will continue on our dynojet, (really want 210whp) and also overall endurance and longevity, but hopefully this engine, harness, ECU setup and tuned MAP will be something we will be able to offer to the community in the next year roughly. So far it shows to be promising, and looking to gauge interest and just a general sense of the potential overall to be able to contribute something new/out of the box to the community. No details on costs or anything yet as we are not there. But feel as though we are at a decent point to share current status and progress moving forward.
Thanks for checking it out
Caste Systems Performance
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
www.CSPerformance.net
Alstrup
Alstrup is offline
PostPosted: Sun Jul 27, 2025 3:16 pm    Post subject: Re: 2490cc Type 1 Reply with quote
Lets see the rest of the power curve. the peak alone is not interesting Smile for a street engine "everything else is"
Also, the dynojet can measure transmission loss, if it is set up for it of course, which can give you real FWHP numbers instead of guesstimate.
Yes, such an engine is not just buy and assemble.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
Rome
Rome is offline
PostPosted: Sun Jul 27, 2025 4:19 pm    Post subject: Re: 2490cc Type 1 Reply with quote
James, I'm glad you made the VW community aware of this special engine!
To theSamba readers- James showed his custom '68 Beetle at the Bug-a Fair VW show in Terryville, CT last month. He also drove it to a local VW gathering near his shop 2 weeks ago where I saw it in person. Very noteworthy is what James told me at the gathering, that he finished the engine installation just a few nights before the Bug-a-Fair and drove it to the meet- approx. 95 miles, mostly highway.
Over the last 2 decades, James converted his Beetle to right-hand drive, and "aged" it with early 60's fenders and engine lid to create a Herbie (The Love Bug) tribute. Significant modifications to the suspension along with Porsche "twist" alloy rims. He also recently installed a modern LCD instrument cluster and control pad for his engine management programs.
The "CSP" in his post above refers to his shop in northern NJ. Not to be confused with Custom and Speed Parts in Germany. Wink
Victor H
Victor H is offline
PostPosted: Sun Jul 27, 2025 4:47 pm    Post subject: Re: 2490cc Type 1 Reply with quote
You're making your peak power around 6,100 rpm? Seems like you have the ingredients for higher rpm.
What are the cam specs?
chrisflstf
chrisflstf is offline
PostPosted: Sun Jul 27, 2025 6:00 pm    Post subject: Re: 2490cc Type 1 Reply with quote
https://www.thesamba.com/vw/forum/album_page.php?pic_id=2606931
Full dyno chart, from his gallery
Alexander_Monday
Alexander_Monday is offline
PostPosted: Mon Jul 28, 2025 4:55 am    Post subject: Re: 2490cc Type 1 Reply with quote
Looking at the full dyno curve there is a dip between 4K & 5K that looks like it could be valve spring harmonics.
Just an observation and possible reason.
Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
Alexander_Monday->What were the rings gapped at?
bedlamite->Almost enough.
andk5591 wrote:
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell.
Alexander_Monday
PostPosted: Mon Jul 28, 2025 4:58 am    Post subject: Re: 2490cc Type 1 Reply with quote
Also, kudos to you for getting a 90mm crank in a mag case.
How bad was the camshaft to crank and rod interference?
Alstrup
Alstrup is offline
PostPosted: Mon Jul 28, 2025 6:11 am    Post subject: Re: 2490cc Type 1 Reply with quote
OK. Its always a b*tch to get the harmonics dialed down to a minimum with agressive cams etc. But it looks to me as the induction length is on the short side. I would definitely try to increase induction length with 20-25 mm and see where that gets you.
You can probably also play a little with the sec. collector volume/length. Get those two factors closer to right and the harmonics will 90% certain be reduced by 50-75%.
Have fun.
T
RickS
RickS is offline
PostPosted: Mon Jul 28, 2025 6:58 am    Post subject: Re: 2490cc Type 1 Reply with quote
He is not running a 90mm crank. He has 96mm pistons x 86mm crank.
Alexander_Monday
PostPosted: Mon Jul 28, 2025 7:22 am    Post subject: Re: 2490cc Type 1 Reply with quote
Thanks for the clarification, I obviously did not read it slow enough and was distracted by Monday morning calls and texts.
86 isn't a walk in the park, building an 86 X 94 now and 82 was way less headache.
I wouldn't even want to tackle the 96 bore.
RickS
RickS is offline
PostPosted: Mon Jul 28, 2025 8:06 am    Post subject: Re: 2490cc Type 1 Reply with quote
I recently built an 86 mm stroke engine. It went together just like stock. I did use a TF-1 case though! Very Happy
Alexander_Monday
PostPosted: Mon Jul 28, 2025 8:20 am    Post subject: Re: 2490cc Type 1 Reply with quote
Cheater!
Lol, I wish I would have used one.
Rob Combs
Rob Combs is offline
PostPosted: Mon Jul 28, 2025 11:23 am    Post subject: Re: 2490cc Type 1 Reply with quote
My God can you even slip a piece of paper between there?
I don't feel nearly as nervous about my cam to crank clearance after seeing this...
Alexander_Monday
PostPosted: Mon Jul 28, 2025 11:30 am    Post subject: Re: 2490cc Type 1 Reply with quote
No, it actually interferes for a short distance.
Going to have to grind some off the crank counterbalance and get it re balanced.
txoval
txoval is offline
PostPosted: Mon Jul 28, 2025 12:05 pm    Post subject: Re: 2490cc Type 1 Reply with quote
Definitely agree on TF1 Very Happy
Then you could go 86mm crank and 4” pistons
RickS
RickS is offline
PostPosted: Mon Jul 28, 2025 12:42 pm    Post subject: Re: 2490cc Type 1 Reply with quote
Then add some JPM MS230 heads!
CasteSystems
PostPosted: Mon Jul 28, 2025 4:56 pm    Post subject: Re: 2490cc Type 1 Reply with quote
That is not the accurate dyno chart posted above by Chrisflst, that was initial testing also using a tri-y 1.75" sebring style exhaust which was build for the car's old 2110cc.
This is just changing from that old exhaust to the berg 2" header
Alstrup that was the next thing we were thinking, try roughly 1" taller velocity stack.
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
CasteSystems
PostPosted: Tue Jul 29, 2025 10:01 am    Post subject: Re: 2490cc Type 1 Reply with quote
Agreed, but the goal here was a true 2.5L utilizing a mag case for cost with reliability.
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
94touring
94touring is offline
PostPosted: Tue Jul 29, 2025 10:04 am    Post subject: Re: 2490cc Type 1 Reply with quote
That's very cool, though I'm confused with the concept of reliable with the mag case versus the already clearanced and pinned alloy cases. Is that an all type 4 main crank?
CasteSystems
PostPosted: Tue Jul 29, 2025 10:10 am    Post subject: Re: 2490cc Type 1 Reply with quote
Still type 1 mains. The case is clearanced for 86mm crank which I think these days is considered clearance wise safe for longevity, vs 88/90mm cranks which need a LOT more clearancing to both case and camshafts. Using the mag case then lowers the cost of not needing something aftermarket like TF-1, etc and still make a larger displacement motor capable of 200whp NA pretty easily without being over stressed hardware and tuning wise.
57 Oak Street
Norwood, NJ 07648
845-418-CSTE
