'59 Karmann Ghia fever
Page: Previous  1, 2, 3 ... 366, 367, 368
kingkarmann
kingkarmann is offline
PostPosted: Tue Jul 29, 2025 12:51 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
The mounts look nearly the same as far as the studs and holes in the bracket goes.
The overall shape of the new bracket looks larger than the original.
I would think the new one could be used.
Maybe mount each bracket to the frame and take measurements to compare the overall depth of each.
Braukuche
Braukuche is offline
PostPosted: Wed Jul 30, 2025 7:54 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Your car would have came with a split case trans and was converted to the later tunnel trans. You need the same style mount that was on the car (not a split case).
The new mounts suck. The rubber splits in weeks in some cases. I take my old mount, drill a hole through them and run a 10mm acros the flats bolt and nut through them. Never have a problem after that.
Other guys have started running mid mounts because the problem is so ubiquitous.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
Loren Premium Member
Loren is offline
PostPosted: Thu Jul 31, 2025 12:49 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
There are few NOS mounts for various years for sale in the classifieds. This might be the better options than the new ones?
Trylon
Trylon is offline
PostPosted: Mon Aug 04, 2025 9:53 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Now for something completely different!
1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel!
kingkarmann
PostPosted: Wed Aug 06, 2025 6:34 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Very cool Cool
I think you could have taken them on the outside!
I had an opportunity to take a couple of laps around the Mid Ohio Sports Car Course with Sophia. Thirteen years ago Shocked
Great memories.
Trylon
Trylon is offline
PostPosted: Sat Aug 23, 2025 5:33 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Seems my last post did not pass muster. Let me try a different approach.
Our Car is a bit on hold as I undertake selling my Victorian Mansionette.
https://photos.app.goo.gl/8jGRd59XLXW7bmnZ8
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
fedwards58KGLL
fedwards58KGLL is offline
PostPosted: Sat Aug 23, 2025 8:36 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
trylon,
I had to swap my original transmission of my 58 LL.
I went for a 1997 1.6 engine and transmission, had to build this piece as adapter and works fine.
maybe it helps.
BTW, what a beautiful house you've got...
Trylon
Trylon is offline
PostPosted: Mon Sep 15, 2025 1:46 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Well, had a little hiatus while I dealt with a CV joint in the 914 that came unbolted…
So, I am back to trying to get things back together and into our car. The next challenge seems to be that the rear wheel bearings do not fit tightly into their housings on their respective axle tubes. I can turn them freely in each housing by hand. It seems that the likely reason is that the housings have expanded overtime. Thought there was a bearing made for this problem that with an oversized outer race that will stay put in the old housing. I can’t find ‘em— am I missing something?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Wed Nov 05, 2025 6:21 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Man, seems like I am becoming a full time mechanic!
Did the rear brakes on my Fiat 500 — first time I ever dealt with disc brakes pads and rotors. They were down to the metal though I did not hear a peep out of them. That car is around 10 years old now! Would you believe that it failed to start in some mall parking lot?! I did not expect to have three classic cars to tend to. Well, the cable end on the battery terminal seems to have been made of tin foil. It cracked and the battery was no longer being properly charged. Installed a new cable end and battery. It starts now.
The 914 fix I did unfixed itself. I had replaced the part of the ignition switch the key turns (that in turn engages the switch) as it required too much pressure turning the key. It worked for a while but now no matter what I do with the key it will not start. And, as usual, fussing with the wiring has given me intermittent problems with the horn (which I had so carefully restored) and the wipers (which were working just fine). I know, all that wiring needs careful attention.
Meanwhile, we had left our car in a state of major surgery. With the help of ChatGPT and a newly found car buddy with decades of VW experience, I am happy to say that I think I fixed our transaxle woes and it and the engine are now back in the car! Will hook up the engine this week and see what I have wrought.
I think I am officially becoming a ‘car guy’ after all.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Marcdeb
Marcdeb is offline
PostPosted: Wed Nov 05, 2025 7:09 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
But it's usually fun, isn't it? Except sometimes when we have to fix what we just recently fixed. Looking forward to hearing about the 59 Ghia getting back on the road. Very Happy
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
kingkarmann
PostPosted: Wed Nov 05, 2025 7:38 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
And all before the snow flies!
Bravo Applause
Trylon
Trylon is offline
PostPosted: Wed Nov 26, 2025 2:43 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
On the road again!
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
obus Premium Member
obus is offline
PostPosted: Wed Nov 26, 2025 3:52 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Great news! Looks great. Just in time for Winter. UUUUggh!
Marcdeb
Marcdeb is offline
PostPosted: Wed Nov 26, 2025 6:40 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Congratulations. Wow, I really like this photo. The lighting really works with the color and the angle really captures how beautiful the Karmann Ghia nose is. This is perfect for framing.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
John Moxon Premium Member
John Moxon is offline
PostPosted: Thu Nov 27, 2025 9:27 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Yep, it's a beautiful car and that beautiful Lowlight nose is what seduced me 30 years ago. Very Happy
John.
kingkarmann
PostPosted: Thu Nov 27, 2025 9:59 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Great portrait Cool
In the words of the late great Gene Autry,
"I'm back in the saddle again..." Doo bee doo bee doo Laughing
PostPosted: Thu Nov 27, 2025 12:05 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
We should do a poll to see how many Ghia owners have nasophilia Very Happy
PostPosted: Thu Nov 27, 2025 2:13 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Laughing Unashamedly guilty m'lord.
John.
kingkarmann
PostPosted: Thu Nov 27, 2025 3:52 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Snooty ? Very Happy
Trylon
Trylon is offline
PostPosted: Mon Dec 01, 2025 9:38 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Ha! Turn my back and the hoi poli take over the thread.
Our car thanks you for your kind comments!
Now where were we when we left off…?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Page 368 of 368
