Rebuilt transmission; stuck in gear?
Page: Previous  1, 2, 3
Everpress
Everpress is offline
PostPosted: Fri Aug 01, 2025 4:43 am    Post subject: Re: Rebuilt transmission; stuck in gear? Reply with quote
For the sake of my own convictions and hopefully helping anyone else out who is having problems similar to this...
I found the problem. Well, my son found the problem.
We hopped in the bus to take it around the block a few times to start making adjustments to the shift plate. I'd drive, making note of how difficult it was to get into one gear or the other. I'd pull over, make adjustments, drive, make adjustments... We did this 3 or 4 times. Note: I never missed a gear on this 3-5 mile voyage, but everything was still sloppy. Still 100% better than my experience with my old transmission.
So we get back to the house and no real progress was made on the adjustments. What gives?
My boy asks me how this whole shift plate system worked. So, for the Nth time, I remove the 13mm bolts holding the shifter in place and explain like a toddler how this component acts with that component. And while I'm talking, I hand him the shifter. He pulls the spring up a little and says, "Is this supposed to do this?"
The lower 1.5 - 2 inches of the shifter is broken and flopping around (a matter of maybe a millimeter or so) and even twists from side to side a small amount. This is most likely why it was hard to find neutral... being in gear was sloppy, and 3rd and 4th gear were especially sloppy to the point that I was mistaken I was in neutral.
So someone here asked me if I looked at my shifter... I did. But this cheap repro has the spring attached to it that covers the last 4-5 inches, so my visual inspection looked fine. It was not fine. I should have used my hands and not just my eyes.
The popping noise that led to it working? I'm not sure about that. I'm not sure if humidity and a bit of rain could have an effect on a clutch install, but the symptoms of the broken shifter were there before that pop - not being able to find gears easily, side-to-side and forward-to-back play feeling like neutral when I was actually in gear, etc.
Moral of the story - 1) don't buy a reproduction gear shift and expect it to last more than a few miles (seriously less than 50 miles), 2) don't just look at the components giving you problems, use your hands if it's safe, and 3)... well, 3 is to slow down and contemplate the advice you're given. I'm pretty sure someone asked about the shifter on page one of this post.
If I had taken those three steps I would already have a replacement shifter here and I'd be out on the road rather than waiting for a replacement.
Finally, thanks again to all of you for your advice and patience. You guys are helping me do better by my loaf... erm... bus.
1969 Bay Camper - "Lost 'Cause Mk.I"
1904 DP
EMPI 34 PICT 3
2000 MAGNASPARK II Ignition/Distributor
Refurb, not resto (I’m not made of restoration money!)
It's not a perfect loaf, but it's my loaf.
W1K1
W1K1 is offline
PostPosted: Fri Aug 01, 2025 12:01 pm    Post subject: Re: Rebuilt transmission; stuck in gear? Reply with quote
Moral of the story - [b][i]1) don't buy a reproduction gear shift and expect it to last more than a few miles (seriously less than 50 miles), .
what shifter did you buy?
all my replacement shifters have made a positive impact on the gear changes, Berg, CSP, Vintage speed.
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
Everpress
PostPosted: Fri Aug 01, 2025 12:20 pm    Post subject: Re: Rebuilt transmission; stuck in gear? Reply with quote
The broken one is this one: https://www2.cip1.com/vwc-211-798-121-a/
I ordered it a couple of years ago, but I've not put 50 miles on my bus since I've had it. I drove it to my garage where it sat for some years (about 20 miles) while I was going through a few things professionally and personally. I spent some time working on it as I had time. Then I moved so I drove it to my new house (about 8 miles). So honestly, I probably have about 8 miles on the shifter.
I am still figuring out what I want to use to replace it. I've wanted to try a trigger shift style, but I'd like to really try one before I buy one. And while I'm fiddling with that section of the bus, I'm going to go ahead and replace the front shift rod bushing. It's there, but for $2 and some change... sounds like some cheap insurance for smooth shifting.
1904 DP
EMPI 34 PICT 3
raygreenwood
raygreenwood is offline
PostPosted: Fri Aug 01, 2025 4:24 pm    Post subject: Re: Rebuilt transmission; stuck in gear? Reply with quote
Abscate wrote:
Abscate wrote:
SGKent wrote:
Very well could have been nothing more than the clutch glued to the flywheel from moisture in the air and the compounds in the disk.
Transmissions don’t go pop, then suddenly work.
Clarifier - clutches DO go pop, and suddenly work.
This is what it sounds like to me as well....so far. Disk stuck on splines.
But...finally rearing your last post.....glad you found the real cause! Ray
SGKent Premium Member
SGKent is offline
PostPosted: Fri Aug 01, 2025 5:40 pm    Post subject: Re: Rebuilt transmission; stuck in gear? Reply with quote
Ken Madsen at TheBusco or Busted Bus usually have a good stock bus shifters available. There is no need to use reproduction parts. A good stock shifter has a very solid feel when it is set up right.
Page 3 of 3
