New Dune Runner Owner
1stindoor
1stindoor is offline
PostPosted: Fri Jul 18, 2025 8:17 am    Post subject: New Dune Runner Owner Reply with quote
Hello all,
Long time reader and follower of the site. I'm now the new owner of a Dune Runner. (4th VW I've owned...to date). Built on a 1960 pan with an 1835 engine. Trying to find information on the buggy. All I have at this point is it was from Dune Buggy Enterprises and has the T Bird hood. Hoping to fix all the glass issues and get it repainted sometime in the near future. Meanwhile it's a blast to drive. I'll get a picture uploaded shortly.
1stindoor
PostPosted: Fri Jul 18, 2025 10:37 am    Post subject: Re: New Dune Runner Owner Reply with quote
1stindoor
PostPosted: Mon Jul 21, 2025 12:12 pm    Post subject: Re: New Dune Runner Owner Reply with quote
The battery is sitting on the pan behind the right rear wheel; outside of the body. It appears the only way to access it is to jack it up and remove the tire and then pulling it over the axle. I'm hoping when I get it to the body shop I can get them to either make an access point behind the passenger seat or build a battery well behind the passenger seat. Looking for suggestions on which would be the preferred course of action. Thanks.
KAmes
KAmes is offline
PostPosted: Mon Jul 21, 2025 6:06 pm    Post subject: Re: New Dune Runner Owner Reply with quote
That's a wild color! My buggy came with the battery trapped like that also. There's absolutely no way to get it out without removing the tire, like you I was concerned I should change it. After some years owning it, in practice it has turned out to be a non issue. It's super easy to put jumper cables or a charger on, and the cables are tidy being so close to the starter. I've come to like it this way.
1stindoor
PostPosted: Mon Jul 21, 2025 6:46 pm    Post subject: Re: New Dune Runner Owner Reply with quote
Thanks for the feedback. It's one of those things that really isn't an issue (yet), I'm just anticipating possible problems. I'll leave it be for awhile. The color wasn't a big deal to me. It's unique, but my preference is a candy apple red. I've always wanted either a red or blue buggy. I'm more partial to the red. I've got a soft top on the way.
oprn
oprn is offline
PostPosted: Wed Jul 23, 2025 3:55 am    Post subject: Re: New Dune Runner Owner Reply with quote
That color is brilliant! I love it! Very unique.
This is my own personal opinion but the only color I can think of that would be more ordinary, boring, uninteresting, blasé than blue would be... perhaps... gray?
To me one of the reasons I drive a Buggy is because it stands out from the ordinary. They deserve unique stand out colors.
1stindoor
PostPosted: Thu Jul 24, 2025 10:40 am    Post subject: Re: New Dune Runner Owner Reply with quote
Noted, and thanks. I'm partial to red and blue because those are what I saw a lot of growing up. Most likely will stick to red when I get there. Meanwhile I'm having fun driving it. The more I learn about the Dune Runner, the more I like it. Definitely less common...unless you're old enough to remember Wonderbug.
1stindoor
PostPosted: Fri Aug 01, 2025 12:36 pm    Post subject: Re: New Dune Runner Owner Reply with quote
New question...the buggy came with an EMPI Off Road Exhaust. I've always been partial to the "standard" Buggy Dual Exhaust (I had it on my sand rail). Is there an advantage or disadvantage of one over the other? At first glance it would seem tune-ups would be easier with the dual exhaust. Thanks all.
EVfun Premium Member
EVfun is offline
PostPosted: Fri Aug 01, 2025 2:17 pm    Post subject: Re: New Dune Runner Owner Reply with quote
What intake do you have on your buggy engine? If you have a center mounted carb, or dual 2 barrel carbs, the split dual exhaust generally drives fine. If you have dual 1 barrel carbs the whole lower end runs like shit. The 2 cylinders on each side are adjacent to each other in the firing order and with that imbalance on both the intake and exhaust the engine strongly runs on cylinders 2 and 4 at low throttle positions. Transitioning back to hitting all 4 as you roll on the throttle is usually less than graceful.
With a suitable intake the dune buggy duals generally cost a little low end torque, but it is much easier to work back there when you don’t have to avoid the exhaust! Plus, a buggy is usually light enough you won’t really miss a little low end grunt.
One possible option, if you have dual 1 barrel carbs, is the EMPI 18-1047 four pipe exhaust. I did see a trike with Weber ICT carbs and that exhaust leaving a large parking lot, I didn't quite manage to catch up it, but it seemed to idle fine and I didn't hear any off-idle hesitation.
Wildthings wrote:
oprn
oprn is offline
PostPosted: Sat Aug 02, 2025 3:16 am    Post subject: Re: New Dune Runner Owner Reply with quote
In addition to the rough running below 2500 RPM the conventional duals are quite loud. My Street Buggy came with a set and after my first 2.5 hour drive on the highway my ears rang all evening.
If you go that route a set of ear plugs will help save your hearing. I expect the power pipes would be the same for noise.
1stindoor
PostPosted: Sat Aug 02, 2025 9:33 am    Post subject: Re: New Dune Runner Owner Reply with quote
Thanks all. I appreciate the time and help. I have dual 2 barrel webers on there. No issues with the exhaust as it is, just an astetics issue. I haven't had to do anything to the engine yet (knock on wood) so I can't determine if the off road exhaust will get in the way.
1stindoor
PostPosted: Sat Aug 02, 2025 9:37 am    Post subject: Re: New Dune Runner Owner Reply with quote
