EVCSNOW Samba Member
Posted: Sat Apr 03, 2021 1:29 pm Post subject: Help! Shifter bushing fell out while driving! 1995 EVC |
Does anyone know what I can do to get moving again? Stuck in San Diego area.
Thank you |
SteveZ Samba Member
Joined: January 02, 2019 Posts: 143 Location: Nova Scotia
Posted: Sat Apr 03, 2021 3:13 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Mine did that in in Minnesota! Memorial Day 2019. Miserable rainy, cold day. I was about 100 miles from St. Paul, where VanGo replaced them for me.
But to get there I held the linkage together with cable ties and shifted very carefully and delicately.
Because everyone was abandoning their Memorial Day plans and heading home, the road was bumper to bumper and slow - it took us over 6 hours to get there. I write this to state that the cable ties held out with a lot - I mean a lot - of shifting as we started and stopped continuously.
Good luck.
Oh, and if one of your bushings has perished, hardened, or shrunk enough to fall out, have the rest replaced to avoid another incident.
I got our bushings from https://europarts-sd.com/default.asp. who are in San Diego. Got an oil change and new shocks installed while visiting my son in San Diego by Kotter's VW in Escondido. https://www.kottersvw.com
Eurovan Rescue is a good resource for finding shops while on the road. http://www.eurovanrescue.com |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Sat Apr 03, 2021 4:08 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Yeah, a few zip ties should hold long enough to get home. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Saturn Samba Member
Joined: April 06, 2019 Posts: 250 Location: San Francisco
Posted: Sun Apr 04, 2021 11:08 am Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Had this happen on my 95 EVC in July 2019, a friend had borrowed my van for the weekend as the bushing failed about 3 miles from getting home while going through the middle of San Francisco. What you can do is to manually put the transmission into a specific gear by reaching through the engine and moving the shifter rod as it reachable and not that hard to access from above. He got the transmission into 2nd gear and was able to get it back to his driveway where repairs commenced a couple days later.
Here is a diagram of the shifting mechanism/linkage/parts as well as part numbers if ordering from VW (P/N 701711066 is the bushing.) There are two bushings on either side lever, and there is a small washer needed at the base of the ball joints.
https://www.jimellisvwparts.com/showAssembly.aspx?ukey_assembly=739024&ukey_product=5299705
Was unable to insert the new bushing into the lever under the car so removed it the rod connecting the lever to the cabin shifter assembly. Did the same thing with the rod going to the transmission. Used a vice and a bit of lube to install the bushing as it is a tight fit. When then reconnecting it back together, utilized a C-clamp to mate the lever onto the ball joint. Also replaced bushing #37 in the diagram in the process as that was pretty worn/weathered as well.
Posted: Thu Jul 31, 2025 12:38 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
For those of you who have rebuilt the shift linkage, what's your trick to separating the large rod running forward from the shift box? I don't have a lift, so my access is pretty limited to what I can do while lying on my back. The rod will rotate just fine, but it won't slide forward. There's got to be a trick I just haven't discovered yet. _________________ Casey--
y u rune klassik? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11220 Location: Oregon
Posted: Thu Jul 31, 2025 12:47 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Zeitgeist 13 wrote: |
For those of you who have rebuilt the shift linkage, what's your trick to separating the large rod running forward from the shift box? I don't have a lift, so my access is pretty limited to what I can do while lying on my back. The rod will rotate just fine, but it won't slide forward. There's got to be a trick I just haven't discovered yet. |
US or Canadian delivery?
Also, Manual or auto? It sounds like you have a manual.
Oh yeah, diesel or petrol? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Thu Jul 31, 2025 12:55 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
I opted to post in this thread because it pertains to the same year and model van--'95 EVC five speed manual with the ACU gas engine. _________________ Casey--
y u rune klassik? |
gesoffen Samba Member
Joined: August 22, 2009 Posts: 235 Location: NoVA, USA
Posted: Thu Jul 31, 2025 1:11 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Assuming the "large rod" is #20 in the linked diagram, and assuming it is similar to the shift linkage I installed as part of my 2003 EV manual swap:
1) Mark the end of #20 with respect to the knurled insert it clamps onto on the bottom of the shifter. This helps realignment upon installation.
2) If replacing bushings, go ahead and remove the pivot and other ends of the shift rod from the trans and bottom of shifter.
3)Loosen the clamping fastener at the shifter side of #20 (13mm hex head and nut if i recall).
4) Use a large flat head screw driver or similar to spread the clamp slightly. Depending on level of corrosion, a squirt of penetrating oil or similar could help.
5) If necessary, use same flat head to pry or combine with hammer to tap off the shift rod (or really tap off the shifter from the rod).
Diagram: https://www.vanagain.com/product/shift-clevis-for-...gK7eR45QrI _________________ 1973 VW Superbeetle (1302) w/ RAT 2270 T4
2003 VW Eurovan Weekender w/ 2.8L VR6 AXK, DYA 5 Spd Manual Conversion |
1994Karuso Samba Member
Posted: Thu Jul 31, 2025 5:52 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
It definitely took some hammering when I had to separate mine. Just in case you are timid  |
Posted: Thu Jul 31, 2025 9:03 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Thanks, I was a bit timid. Turns out I prematurely dropped the shifter box which made it difficult to hold everything while tapping the rod forward. Once I bolted it back up the rod began moving nicely. _________________ Casey--
y u rune klassik? |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24024 Location: NYC/Upstate/ROW
Posted: Fri Aug 01, 2025 4:42 am Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Old thread, but for getting home, stuff with heavy but soft paper towels to fab a temp bushing, then duct tape or zip tie to keep rods oriented.
Shift carefully. Get home. Fix it. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Fri Aug 01, 2025 9:20 am Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
My van had a bearlock installed by the PO, so there was a steel plate surrounding the gear shift linkage mounted with tamperproof bolts. It was difficult to even see that the bushing had failed and I couldn't manage to get a zip tie in there.
I managed to limp home by stuffing a crumpled up McDonalds paper bag between the dropped linkage and the plate to keep it elevated into the socket. |
Salem7 Samba Member
Joined: January 24, 2010 Posts: 217 Location: Washington County, New York
Posted: Fri Aug 08, 2025 7:25 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
I had the same thing happen on a trip from NY to PA. Stop and go traffic on I-84 when it happend, got over to the side and jury rigged with wire and tape to complete the journey. I have replaced the offending failed bushing on the ball joint. No problems shifting with jury rig but now that things are back together correctly(?) it doesn't shift in any discernable pattern. Wth much searching I can find reverse and 1st. 2nd 3rd and 4th are there but it is very vauge as to where they are it won't shift into 5th I have the Bently manual and have been studying how to adjust the linkages. I think that the shiter on the case is out of sync with the shifter handle. I do not know how I can be sure which gear I am in as the manual asks to put the transimission in various gears. I have no way of knowing what gear it is in at the transmission. Any help or pointers would be appreciated. 1995 EVC ACU 5 speed. Thanks _________________ 1982 Westfalia 1.6NA diesel. Converted to Turbo 1.6 and sold.
1995 Eurovan Camper Winnebago, early serial number 5 speed |
Posted: Sat Aug 09, 2025 4:33 am Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Salem7 wrote: |
No problems shifting with jury rig but now that things are back together correctly(?) it doesn't shift in any discernable pattern. |
Iβd start by confirming the big shift rod (#20 mentioned in a post above) is securely clamped on the knurled insert at the bottom of the shifter. If there is any play between those two, your shift pattern will be all over the place.
Beyond that, check the other bushings throughout the linkage (see diagram linked above) - if one had already failed, pretty good bet that all the rest are in the same or worse shape.
If you can get someone to run through the shift pattern while you observe the linkage at its various key locations, any problems should become evident. _________________ 1973 VW Superbeetle (1302) w/ RAT 2270 T4
Salem7 Samba Member
Posted: Sat Aug 09, 2025 6:55 am Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Thanks. I appreciate yoiur advice. The Bently shows a special clamping tool.
Is there and alternative to the VW tool? _________________ 1982 Westfalia 1.6NA diesel. Converted to Turbo 1.6 and sold.
Salem7 Samba Member
Posted: Sun Aug 10, 2025 2:02 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
I am still struggling with this. I do not have a VW 3258 alignment tool. I have looked to see if I could get a file to 3D print one. No luck there. I have tried following the Bently and put a 2mm shim while in what I think is first gear. 1-2 3-4 seem to work. No reverse of 5th so far. I can get it in reverse but it pops right back out unless the shifter is held down with a lot of pressure. The part #16 has a rubber coat on it that is pretty much worn away(previous post). I have tried realigning the location of the main shifter rod clamp relationship. Nothing really changes. Is the rubber coating essential to get the reverse to be held down by itiself? What am I missing on what appears to be a simple proceedure? Any help would b e greatly appreciated.
Saturn Samba Member
Posted: Sun Aug 10, 2025 7:13 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Salem7 wrote: |
I am still struggling with this. I do not have a VW 3258 alignment tool. I have looked to see if I could get a file to 3D print one. No luck there. I have tried following the Bently and put a 2mm shim while in what I think is first gear. 1-2 3-4 seem to work. No reverse of 5th so far. I can get it in reverse but it pops right back out unless the shifter is held down with a lot of pressure. |
Have you Inspected the condition of all of the bushings in the shifter system? There are the several located under/around the shifter where it comes through the floor (17, 35, 54) as well as several next to the transmission in the engine compartment (38. 41. 42, 45). When I purchased my Weekender, it would pop out of 2nd and 4th gear. The source of the problem turned out to be interference between the shifter lever (26) and the rubber line coming from the fuel filter. This situation would not really account for your issue with reverse and 5th gear. Though to me if the sifter is popping out of gear, especially when the engine is not running, is probably due to interference somewhere. Highly suggest you have some one else cycle through all the gears while watching the top of the transmission as well as from underneath the van.
I have replaced most of these shifter bushings between my 1993 Weekender and 1995 EVC. Take a look at these two posts which go into further detail around replacing the specific bushings out.
1: https://www.thesamba.com/vw/forum/viewtopic.php?p=9980208#9980208
2: https://www.thesamba.com/vw/forum/viewtopic.php?p=9995942#9995942
Salem7 Samba Member
Posted: Mon Aug 11, 2025 6:31 am Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Thanks for your reply.
Let me rephrase my issue. The transmission doesn't pop out of reverse. It doesn't stay in reverse unless I hold the shifter down. In the previous post I included a picture of the worn rubber on top of the shifter part that holds the lockout down. When I take pressure off the shifter the shifter rises and goes out of gear. Things act like there should be more to the rubber piece to hold it in reverse.
Part 2 of the question can the transmission be successully reoriented without the VW 3258 tool? I do not have the tool nor can I locate one. If it is possible to align the shifter without the tool? could some one tell me how they did it?
I have watched thie shifter from above and below while my helper gose through the shift pattern. Any worn bushing have been inspected and replaced as neccesary. _________________ 1982 Westfalia 1.6NA diesel. Converted to Turbo 1.6 and sold.
Salem7 Samba Member
Posted: Mon Aug 11, 2025 1:00 pm Post subject: Re: Help! Shifter bushing fell out while driving! 1995 EVC |
Issue solved.
After much trial and error I have the gear shifter working correctly. It sure would have helped to have a VW 3258 tool to do it. Minute adjustments on the clamp hold down yeilded results.
Thanks for the replies. _________________ 1982 Westfalia 1.6NA diesel. Converted to Turbo 1.6 and sold.
