wiring open ends 73 T2b Riviera GE engine
1973T2bRivieraGE
1973T2bRivieraGE is offline
PostPosted: Sun Aug 10, 2025 4:32 am    Post subject: wiring open ends 73 T2b Riviera GE engine Reply with quote
Hi,
I'm still working on an introduction to the forum with my 1973 Riviera T2b project which is almost done. Any hints on correct forum placement are most welcome.
Here I have a left question regarding wiring. As you see in the pictures I have some "open ends".
1.) There are two resistors (as I would identify them) in the engine bay. The white one seems to be a "pre-resistor" for the coil? No wire attached to it. Engine starting and running as it should. Can anybody help me identifying (and connecting it) correctly?
The metallic one could be related to the radio? Does anybody recognize it and again help me identifying (and connecting it) correctly?
2.) There is a wire with a grey isolation holding two green wires and an open copper wire. I'm absolutely lost what this could be for! Does anybody recognize it, explain it, guide me to correctly connect it?
Thank you and greetings from Cologne!
Markus
With greetings of a Classics Enthusiast from Cologne, Germany!
Markus
busdaddy
busdaddy is offline
PostPosted: Sun Aug 10, 2025 8:28 am    Post subject: Re: wiring open ends 73 T2b Riviera GE engine Reply with quote
Welcome!
VW didn't install either of those resistors, a factory style electrical system doesn't use them.
Without seeing where that gray cable goes I can't confirm, but it's very likely part of the dealer diagnostic system, also redundant now.
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Sun Aug 10, 2025 4:27 pm    Post subject: Re: wiring open ends 73 T2b Riviera GE engine Reply with quote
Your gray sheathing looks like it contains two green conductors plus a shield wire or at least on uninsulated ground.. Nothing like that on there from the factory that I am aware of.
1973T2bRivieraGE
PostPosted: Tue Aug 12, 2025 1:01 am    Post subject: Re: wiring open ends 73 T2b Riviera GE engine Reply with quote
busdaddy wrote:
Welcome!
Yes - the wire seems to be related to the dealer diagnostic system.
I remember the white pre-resistor from my Mustang. It looks very similar. I guess it goes to the coil there to keep the voltage low and thus "de-stress" the coil.
I'll insulate the open end and ignore both for now.
Thank you very much!
Markus
busdaddy
busdaddy is offline
PostPosted: Tue Aug 12, 2025 7:43 am    Post subject: Re: wiring open ends 73 T2b Riviera GE engine Reply with quote
The correct coil uses no resistor, it's powered direct from the harness.
Слава Україні!
jjvincent
jjvincent is offline
PostPosted: Tue Aug 12, 2025 9:35 am    Post subject: Re: wiring open ends 73 T2b Riviera GE engine Reply with quote
Those look like old school resistors that someone put in because of LED's installed.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Sat Aug 16, 2025 6:22 pm    Post subject: Re: wiring open ends 73 T2b Riviera GE engine Reply with quote
Agreed!
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
