Blown head gasket or something else?
my_vw_sucks
my_vw_sucks is offline
PostPosted: Fri Aug 15, 2025 11:53 am    Post subject: Blown head gasket or something else? Reply with quote
Well, I noticed a bunch of coolant on the ground at the back of the van this morning. I had just returned from Tahoe to the Bay Area and figured something had given up on the drive home. Coolant looked to be leaking from the overflow tank. I figured it was cracked. I opened the coolant cap behind the license plate door and clean coolant just dumped out. It was full to the brim. I opened the cap on the expansion tank and it too was full to the brim. Almost appeared to be pressurized with coolant pouring out the top.
My first thought was maybe blown head-gasket pressurizing the cooling system. But coolant is very, very clean. Checked the oil and that too is clean. No signs of milkshake. There was no drivability issues while driving. Power seemed fine and temps were normal.
The motor is a Gowesty 2.3L that the PO installed about 50k miles ago. While I’ve owned and worked on VWs all my life I haven’t had a WBX in about 30 years. So I’m unsure how a blown head gasket or other problem like this would present itself. Any recommendations on how I should go about diagnosing this or ideas on what it might be? Any help is greatly appreciated.
my_vw_sucks
PostPosted: Fri Aug 15, 2025 12:04 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
I’m starting with a head gasket leak tester to see if there is combustion gasses in the coolant. I don’t have high hopes. We’ll see tomorrow when Amazon shows up.
E1
E1 is offline
PostPosted: Fri Aug 15, 2025 12:14 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Did it get hot?
If not and you have a stock expansion tank (the large one) with a blue cap, change the cap. They routinely fail, recommend the Blau or Meyle brands and no others.
Don’t freak just yet, this has happened to us several times, and it’s never been a head gasket. It takes some time for coolant to cool enough to produce a vacuum that reclaims coolant.
If the expansion tanks stays full when cool, after overfilling the overflow, either you now have air in the system that precludes vacuum draw and/or the cap isn’t opening to draw it back in, either.
If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?”
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Fri Aug 15, 2025 12:21 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Just wondering, but any chance you checked to see if there was air in the radiator? I know this might seem to be a strange question, but if the pressure tank and the overflow tank were full, where is the air that would build up if there were an exhaust leak?
Next, what was the last coolant fill, and the procedure you used?
-bobby
space
space is offline
PostPosted: Fri Aug 15, 2025 12:57 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Similar happened to my van
It ended up being the pressure tank
Replaced w an gw aluminum problem solved!
82 westy
w:
2.5 JDM Subie
Rear discs
my_vw_sucks
PostPosted: Fri Aug 15, 2025 1:20 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
The cooling system and all engine components were at ambient temperature when I checked their levels. I opened the bleed valve and no gas hiss. Kept the valve open and brought the van up to op temp. No coolant came out of the bleed valve but the fan did cycle numerous times.
My plan is test the cooling system for gas when I get the kit tomorrow. If no gas present I'll go ahead and replace the expansion cap as suggested and take the opportunity to flush and bleed the system. I'm a bit dubious to the cap being bad but happy to be wrong, as the expansion tank is also full. I'd figure it would be empty. But maybe it just gulped air on the cap fail and backed up the system.
I've never done a bleed on the system, as the PO just had the coolant replaced a little under two years ago right before I bought it. If I get as far as replacing the cap I'll be doing some research on bleeding techniques. I did just watch a video of a guy using a PVC pipe/bong to fill the expansion tank that looked fairly straightforward. I'm open to suggestions.
DanHoug
DanHoug is offline
PostPosted: Fri Aug 15, 2025 1:33 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
right. you need to begin with a cold engine, CLOSE the radiator bleeder, start motor and warm up until you feel pressure in the hoses, THEN crack the radiator bleed screw open in order to use the built-up pressure to force air out.
-dan
www.thefixitworkshop.com
E1
E1 is offline
PostPosted: Fri Aug 15, 2025 1:38 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
If it’s a cap bleeding off somewhere below the 14.5 psi/1 bar, the tank indeed will be full when hot — or so it was whenever ours have failed.
You may have air trapped, before or now. Try bringing to temp at idle, and run all the heaters.
Did you bleed the rad at full temp, and with the nose raised? There might be lots in there now, or somewhere else, for a variety of possible reasons.
jlrftype7
jlrftype7 is offline
PostPosted: Fri Aug 15, 2025 1:49 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
There are threads, and pictures, of people getting their Vanagon at a kind of steep angle to help bleed air out of the Coolant system.
And then there's the Libby Bong method as well.
Once you get actual coolant out of the Radiator Bleed hole, then worry about testing for Combustion Gas getting into your Coolant System from a possible failing Fire Ring Seal. That's our version of a failed Head Gasket as far as comparing to a more normal gasket set-up on other vehicles.
If you have a fire ring failing, you'll often lose output from the Front Heater Core as combustion air /pressure gets into the coolant system.
If you didn't seem to have pressure that relieved when you took your pressure cap off, all of this might be more normal, and cheaper, things like others have posted about. Failed Blue Cap, tank issue, system not bled of air in too many months.
So, fingers crossed and start with the simple stuff first.
‘84 Tin Top - Hilga....Auto
my_vw_sucks
PostPosted: Fri Aug 15, 2025 2:13 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Thank you all for the very helpful suggestions and community! I've ordered a Blau expansion cap. I'll go ahead and flush and bleed the system when it arrives. All of the comments really have me hopeful that it's a bad cap.
Chootrain470
Chootrain470 is offline
PostPosted: Fri Aug 15, 2025 2:27 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
I had a combustion leak about two years ago. The symptoms were my coolant would shoot out of the overflow tank after a drive like soda pop. I also would have a small puddle of coolant after parking for a while. Needless to say, I had low coolant issues too. I ended up needing to do a cylinder head replacement.
my_vw_sucks
PostPosted: Fri Aug 15, 2025 2:34 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
And now less hopeful. This is exactly what is happening. I'm going to try the cap and keep my fingers crossed.
E1
E1 is offline
PostPosted: Fri Aug 15, 2025 2:39 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Chootrain, did you notice any air bubbling into your overflow once the gasket went bad?
Asking for a friend… Wink
A failed blue cap will also jet out the overflow vent on top. I was in your exact shoes in worry, it was just a blue cap — and my first post here.
Fingers crossed bigly, odds are it’s a lesser cause like some others mentioned.
The longer and hotter the drive, the more the coolant pressure and coolant out a bad cap.
A shorter or cooler or less-stressful of a drive might cause everything from no rise to a lesser rise not quite overflowing.
Pressure-testing the system would be a good move, too.
Chootrain470
PostPosted: Fri Aug 15, 2025 3:07 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
It's been a while so my memory might not be right, but yes I believe it was bubbling. Very similar to a shaken soda can.
E1
E1 is offline
PostPosted: Fri Aug 15, 2025 3:10 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Thanks for that. Cool
Crooked Designer
Crooked Designer is offline
PostPosted: Fri Aug 15, 2025 3:35 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Simple test on the blue cap. I have never done this as by the time I became aware of this video I already moved on to an aluminum expansion tank, but seems pretty simple.
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
E1
E1 is offline
PostPosted: Fri Aug 15, 2025 4:04 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
I filmed that, of a Bestie.
Crooked Designer
PostPosted: Fri Aug 15, 2025 4:58 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Love it! Makes me laugh every time.
E1
E1 is offline
PostPosted: Fri Aug 15, 2025 5:12 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Haha, Thanks, Ian’s a wonderful guy and clearly a Master of Ad Lib.
Makes us still laugh, too… the bulging eyes were not in the script. Laughing
All I did was hold my iPhone.
Certainly not an Engineering method, but has proven workable to finding our bad blue caps since. I think we shot it in early 2017.
my_vw_sucks
PostPosted: Sat Aug 16, 2025 1:22 pm    Post subject: Re: Blown head gasket or something else? Reply with quote
Ran the test and have a dying trumpet and can easily drink a coke through the cap (no closed b-hole on this one). Back to being optimistic. That new cap needs to hurry up.
