1978 beetle convertible questions
rlutterb
rlutterb is offline
PostPosted: Fri Sep 05, 2025 8:36 am    Post subject: 1978 beetle convertible questions Reply with quote
The newest beetle I have ever owned is a 1973 super, so my new to me 1978 convertible has some things I’m not familiar with. I have questions about the things in these pictures?
What is the green dot button?
Is this an amplifier for the stereo?
I suspect this goes in the front trunk somewhere as a cover?
Where do I strap this hook from the rear boot cover? I don’t see an obvious spot.
I’m assuming this is part of the speedometer given that the end of that Cable looks familiar, but why is there a box and what is the multi prong plug that is below where the cable goes in? It was unplugged when I got the car.
Thanks in advance for helping a new vert owner
1973 Super Beetle project
1978 VW convertable
1987 El Camino
1995 Miata M
2015 Chevy Silverado
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Sep 05, 2025 8:50 am    Post subject: Re: 1978 beetle convertible questions Reply with quote
Fuel injection computer
Egr mileage counter om the speedo cable
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Cusser
Cusser is offline
PostPosted: Fri Sep 05, 2025 10:48 am    Post subject: Re: 1978 beetle convertible questions Reply with quote
Sorry for the horrible photo, but there's a little screw hook that strap hooks onto. If yours isn't there, hardware store should have some, or bend some eyescrews.
busdaddy
busdaddy is offline
PostPosted: Fri Sep 05, 2025 11:11 am    Post subject: Re: 1978 beetle convertible questions Reply with quote
Is there a gas heater in the trunk?, the mystery switch could be for that.
The cardboard thing is the cover for the fuel injection ECU.
Nice looking car!, let's see the engine compartment.
Слава Україні!
rlutterb
rlutterb is offline
PostPosted: Fri Sep 05, 2025 11:22 am    Post subject: Re: 1978 beetle convertible questions Reply with quote
busdaddy wrote:
Is there a gas heater in the trunk?, the mystery switch could be for that……… let's see the engine compartment.
No gas heater
1978 VW convertable
1987 El Camino
1995 Miata M
rlutterb
rlutterb is offline
PostPosted: Fri Sep 05, 2025 11:24 am    Post subject: Re: 1978 beetle convertible questions Reply with quote
Learn something every day, when I plugged the EGR mileage counter back in the speedometer started working!
1978 VW convertable
1987 El Camino
1995 Miata M
busdaddy
busdaddy is offline
PostPosted: Fri Sep 05, 2025 2:20 pm    Post subject: Re: 1978 beetle convertible questions Reply with quote
rlutterb wrote:
No gas heater
Very nice!, try not to molest it, it looks original and well cared for.
Of course I'll have to add the standard PSA about if you don't know the age of the rubber fuel hoses replace them with new FI rated ethanol proof hose soon, FI leaks get exciting real quick and by the time you notice the flames behind you it's too late.
And do any of the rubber seals under the injectors or on the manifold joints too, L-jet isn't smart enough to compensate for vacuum leaks.
Слава Україні!
