Stainless Steel Heater Box Shells
Wildthings
Wildthings is offline
PostPosted: Sun Sep 14, 2025 5:04 pm    Post subject: Stainless Steel Heater Box Shells Reply with quote
Has anyone ever heard of stainless steel heater box shells for either a Type 1 or a Type 4? Seems there might be a demand for such.
mikedjames
mikedjames is offline
PostPosted: Mon Sep 15, 2025 8:54 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
It used to be that Ikea sold medicine cabinets that were made of 0.5mm stainless steel. Would have been ideal. I cut one up to make an air scoop for an oil cooler.
The last time I saw the same Ikea design it was stainless steel foil on fibreboard..
Maybe theres a use for Cybertruck panels that fall off...
Ancient vehicles and vessels
raygreenwood
raygreenwood is offline
PostPosted: Mon Sep 15, 2025 8:59 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
There was q thread a while back where someone had found a stainless heat exchanger...type 4 I think.
Ray
SGKent Premium Member
SGKent is offline
PostPosted: Mon Sep 15, 2025 12:14 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
make a die and have some stamped. Maybe you will break even, maybe not. The simplest solution is to see if Dansk would market the shells separately that they use to make replacement heat exchangers.
George Carlin:
Skills@EuroCarsPlus:
Opossum
Opossum is offline
PostPosted: Wed Sep 17, 2025 12:13 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
Maybe this would work: https://www.ebay.com/itm/114920757792?epid=1703775...SwS5thCoyh
For a 914 Porsche
"You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Sep 17, 2025 9:01 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
For a 914 Porsche
I love the thought of the muffler sticking out two feet behind the bus.
That's 61 centimeters for Nigel.
If I was building an absolute race bus, I would run those facing forward and finish off the equal length pipes into a muffler that exits in front of the rear wheels.
Robbie
www.airschooled.com
Road trip reports and tech blog:
Abscate Premium Member
Abscate is offline
PostPosted: Thu Sep 18, 2025 3:04 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
airschooled wrote:
For a 914 Porsche
Robbie
For Nigelโ€ฆ. Very Happy Very Happy Very Happy
What would MOT think of that, I wonder?
busdaddy
busdaddy is offline
PostPosted: Thu Sep 18, 2025 7:52 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
airschooled wrote:
For a 914 Porsche
Robbie
Forward, with chrome side pipes! Razz
Слава Україні!
W1K1
W1K1 is offline
PostPosted: Thu Sep 18, 2025 10:12 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
[quote="busdaddy"]
airschooled wrote:
Robbie
oh now that brings up the memory of that guy that was making side exit(ahead of the back wheel), backwards headers/exhaust a while back for beetles.... what were they called? d'oh!
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
67rustavenger
67rustavenger is offline
PostPosted: Thu Sep 18, 2025 10:43 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
[quote="W1K1"]
busdaddy wrote:
airschooled wrote:
Robbie
JC Whitney "Bolt-on Side Pipe Kit" Wink
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1055326
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
SGKent is offline
PostPosted: Thu Sep 18, 2025 3:40 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
airschooled wrote:
For a 914 Porsche
Robbie
Smile and be DNS'd. The exhaust must exit behind the driver's position and to the opposite side on most race cars. Straight line racing has some classes of old machines that blow exhaust out to either side of the driver in front of him/ (Shirley Muldowney), and classes that allow exhaust straight up or up and out. Hydro boats were the same with the big Merlin and Allison engines sitting in front of the drivers, but some drivers were getting fumigated / intoxicated by misfiring cylinders when burning methanol and nitro methane etc.. You could use those to turn to the passenger side ahead of the rear wheel. I've always thought the python systems look well designed as street systems but no heat, recognizing Mike's original question.
George Carlin:
raygreenwood
PostPosted: Thu Sep 18, 2025 4:33 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
A long while back I had thought about making a simple, 2 piece concrete cast of the outside shell of the heat exchangers. Then make a male cast of the inside of each side
Then get some 0.010 stainless sheet and load this thing into my 12 ton HF press. I have pressure formed some metal parts over the years but never that crudely.
Then I watched what this guy did with some metal sheets welded together....and connected to a cheap pressure washer. Hydroforming.
https://youtu.be/llhcATrmsBg?si=-FhhB1iV2XtUzEC4
Make the concrete form I mentioned above. Weld together a couple of THIN stainless sheets. Clamp between the two mold halves. Get some 5000 psi ratchet straps and strap the mold together and then hit it with the pressure washer.
If it forms them well enough, trim the welded edges off, roll/fold them with duckbill pliers and rivet it together.
Ray
NASkeet
NASkeet is offline
PostPosted: Sat Sep 20, 2025 10:16 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
Abscate wrote:
airschooled wrote:
For a 914 Porsche
Robbie
Having an exhaust system projecting 2 feet behind a vehicle, would probably be regarded unfavourably at the MOT roadworthiness inspection; if not by traffic police enforcing The Motor Vehicle (Construction & Use) Regulations 1986
https://www.legislation.gov.uk/uksi/1986/1078/contents
https://www.legislation.gov.uk/uksi/1986/1078/part/II/chapter/K
Proper scientists, technologists & engineers use millimetres rather than centimetres, which would normally be the preserve of laypeople or plebians. One could conceivably use decimetres, but I have yet to encounter any examples of their use.
If we are going to work in S.I. - Systeme Internationale units, then 2 feet would be equivalent to 610 millimetres or 0โ€ข610 metres; the convention being to use increments of a 1000x or 1/1000x of the basic unit, such as am - attometres, fm - femtometres, pm - picometres, nm - nanometres, micrometres, mm - millimetres, m - metres, km - kilometres, Mm megametres, Gm - gigametres, Tm - terrametres, etc
https://en.wikipedia.org/wiki/International_System_of_Units
https://en.wikipedia.org/wiki/Metric_prefix
VW Type 4 engine, custom heat exchangers & exhaust system
Picture originally featured in:
On the scene, Volksworld, June 2003, Page 14.
Custom heat exchangers & exhaust system for a VW-Porsche 914 engine, transplanted into a split-screen, pre-1968 VW Type 2.
1997~2005, United Kingdom specification, Brazilian VW 1600 Type 2 engine
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
orwell84
orwell84 is offline
PostPosted: Sat Sep 20, 2025 1:43 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
Abscate wrote:
airschooled wrote:
For a 914 Porsche
Robbie
As expected, the MOT would not be amused. Not in the slightest. In fact, they would flip their powdered wigs if you pulled that shit.
NASkeet
NASkeet is offline
PostPosted: Sun Sep 21, 2025 11:45 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
airschooled wrote:
For a 914 Porsche
Robbie
What many Americans forget, is that many if not all of we older Britons were brought up with the full spectrum of Imperial measurements, of which length measurements are just one, ranging from barleycorns to leagues. These are the ones with which I have long been acquainted, but there might be a few more! Wink
barleycorns
inches (3 barleycorns)
palms (3 inches)
hands (4 inches | commonly used in the equestrian world, in which I participated as a youth)
feet (12 inches, 4 palms & 3 hands)
cubits (1ยฝ feet = 18 inches)
yards (3 feet)
fathoms (6 feet)
rod, pole & perch (5ยฝ yards)
chains (22 yards - length of a cricket pitch)
furlongs (220 yards)
cable (1/10 nautical mile)
miles [statute] (1760 yards & 5,280 feet)
miles [nautical] (6,080 feet)
leagues (3 nautical miles)
https://en.wikipedia.org/wiki/Imperial_units
https://en.wikipedia.org/wiki/Imperial_units#Length
https://en.wikipedia.org/wiki/Rod_(unit)
https://en.wikipedia.org/wiki/Palm_(unit)
I conveniently remember the acre as equivalent to a rectangle of dimensions 1 chain x 1 furlong
The origin of the mile, is 1.000 double-stride lengths of soldiers in the Roman legions; recalling that in present-day ENGLISH, millennium is 1,000 years and mille is the French word for 1,000.
Strangely, those Americans who still cling to Imperial units, seem to use only a small subset of those units, as indicated by weighing cars & aircraft solely in pounds, rather than hundredweights and long-tons. Rolling Eyes
I also recall the pre-decimal British currency system of pounds, shillings, pounds & guineas.
1 guinea = 21 shillings
1 pound = 20 shillings = 240 pence / pennies
1 crown = 5 shillings
1 double-florin = 4 shillings
ยฝ crown = 2ยฝ shillings
1 florin = 2 shillings
1 shilling = 12 pence / pennies
1 sixpence = 6 pennies
1 thu'pence / threepence = 3 pennies
1 penny = 2 half-pennies = 4 farthings
I was born during the last mintage-year of the farthing
There have also been two-penny, four-penny, half-farthing, third-farthing (exclusive to Malta) and quarter-farthing coins.
Even during the later years of the British Empire, British West Africa had tenth-penny coins (i.e. 1 pound = 2,400 tenth-pennies), of which I have a few examples in my coin-collection of the British Commonwealth, Colonies, Protectorates & Mandates (encompassed circa one quarter of the World's population); which includes some of King Edward VIII.
https://onlinecoin.club/Coins/Country/British_West_Africa/One_tenth_Penny_1939/
Regards.
Nigel A. Skeet
Wildthings
PostPosted: Sun Sep 21, 2025 1:06 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
"Feedings" is my favorite units, the distance a horse, oxen, etc could go before it needed to be fed, which of course is affected by many variables. It would have been an important unit for the American West where distances were huge, travel dangerous, and the lack of forage, water, and shelter for draft animals life threatening.
Tbob
Tbob is offline
PostPosted: Mon Sep 22, 2025 10:56 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
I am really tickled at the concept of an "absolute Race Bus".
1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps
Bnanwel
Bnanwel is offline
PostPosted: Mon Sep 22, 2025 1:32 pm    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
Those designs make adjusting the valves a lot of fun!
โ€˜72 Karmann Ghia Conv.
โ€˜73 Karmann Ghia Coupe
โ€˜74 Karmann Ghia Coupe
โ€˜70 Deluxe
โ€˜72 Deluxe
NASkeet
NASkeet is offline
PostPosted: Today 2:34 am    Post subject: Re: Stainless Steel Heater Box Shells Reply with quote
That's one of several reasons why armies changed over to motorised transport for most transport functions, although the British Empire force - Chindits (included at least two Scottish regiments, such as the Black watch & Cameronian Highlanders) relied upon mules in the Second World War Burma campaign, as did the USA's "Merrill's Marauders" (trained by the British in India, alongside the Chindits Very Happy )
https://en.wikipedia.org/wiki/Chindits
I don't think cylinder-head valve-clearance adjustment was foremost in the minds of those exhaust-system designers! Crying or Very sad
Regards.
Nigel A. Skeet
