Oil Cooler Leak
SixVolt Premium Member
SixVolt is offline
PostPosted: Sat Sep 20, 2025 6:30 am    Post subject: Oil Cooler Leak Reply with quote
1957 Oval with stock 36HP engine. I have an oil cooler leak. Can I remove the engine lid and get the fan shroud off to get to the cooler to replace it? I'd like to avoid pulling the engine if possible. Anyone done this before? Thanks.
consvws Premium Member
consvws is offline
PostPosted: Sat Sep 20, 2025 6:46 am    Post subject: Re: Oil Cooler Leak Reply with quote
i think the fan shroud will just come right off without even removing the engine lid.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Sep 20, 2025 11:17 am    Post subject: Re: Oil Cooler Leak Reply with quote
But it is easier with the lid out of the way!
Jimbo
TDCTDI wrote:
consvws is offline
PostPosted: Sat Sep 20, 2025 11:29 am    Post subject: Re: Oil Cooler Leak Reply with quote
I guess..... unless your doing out in your driveway in the rain. You can use the deck lid as an umbrella
sunroof
sunroof is offline
PostPosted: Sat Sep 20, 2025 3:58 pm    Post subject: Re: Oil Cooler Leak Reply with quote
To get the fan shroud off without pulling the engine the decklid has to come off and the hinge mounts swung to the side. I have done this many times.
Don
Better and better mistakes!
SixVolt is offline
PostPosted: Sun Sep 21, 2025 5:50 am    Post subject: Re: Oil Cooler Leak Reply with quote
Don
Thanks! That's exactly what I needed to know.
