engine mount dis-congruity on 2 liter
Page: Previous  1, 2
germansupplyscott
germansupplyscott is offline
PostPosted: Mon Sep 22, 2025 2:49 pm    Post subject: Re: engine mount dis-congruity on 2 liter Reply with quote
airschooled wrote:
Metal brackets on the case. Rubber onto the metal brackets. Mustache bar installs from below.
If you’re doing it out of that order, we need to see photos. Help us help you.
Robbie
I mentioned this above also. Not as succinctly.
This photo seems to indicate a different sequence, you can see the stud of the mount passing into the bracket but the bracket isn't fastened to case.
What I am getting from OP posts is the holes in the bracket cannot be made to align with the holes on the case. But need wider photos to see what's happening, the pics are too close up to to be very helpful.
SL
wagen19
wagen19 is offline
PostPosted: Tue Sep 23, 2025 8:47 am    Post subject: Re: engine mount dis-congruity on 2 liter Reply with quote
Robbie
Can this have something to do with that aftermarket oil pump?
Wildthings
Wildthings is offline
PostPosted: Tue Sep 23, 2025 11:56 am    Post subject: Re: engine mount dis-congruity on 2 liter Reply with quote
If the mount hits the pump, then yes.
blatzer
blatzer is offline
PostPosted: Mon Sep 29, 2025 10:12 am    Post subject: Re: engine mount dis-congruity on 2 liter Reply with quote
the bus has received rear impact, years ago at parking lot speed and this problem never popped up before, until recently i dinged the rear bumper and this caused my mounts to rip and here i am
air schooled seems to have the solution- i was trying to install with mustache bar in and i will try bracket, mount and bar in that order
surveillance plus data equal control
blatzer
blatzer is offline
PostPosted: Sat Oct 04, 2025 10:51 am    Post subject: Re: engine mount dis-congruity on 2 liter Reply with quote
and it turns out the upper drivers side transmission mount was loose and the whole engine/transmission was wobbly
amazing what you find out when s... breaks
Page: Previous  1, 2
Page 2 of 2
