Smilespergallon Samba Member
Posted: Wed Oct 15, 2025 7:54 am Post subject: Progressive carb preheat modification |
Type 4 engine with a progressive carb. I understand that this isn’t the stock or most ideal setup, but I’m working with what I have for now. Planning to build a box around the air filter and plumb in warm air to heat it faster. Do I plumb the air from location 1 or 2? I believe 1 is where the stock preheat “toilet” was but the hole in my tin looks different. Does the warm air come off of off the number 1 cylinder? Lastly, what size are my fuel lines? Any advice from those who’ve made this modification welcome!
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13633 Location: West Coast, USA
Posted: Wed Oct 15, 2025 8:16 am Post subject: Re: Progressive carb preheat modification |
Howdy,
Location 1 is the correct spot; location 2 is for the heater booster fan for helping defrost at idle. Cap off #2 and its corresponding round hole on the left side of the engine compartment well, or it's a cooling leak. On that note, you'll want a set of spark plug wires that actively seal the holes in the tin, preventing another coolant leak. Chances are you're missing the oil pressure switch boot too. You guess it, another coolant leak. All those are more important than the foam seal.
The preheated air intake requires more matching tin down below, as well as an optional "donut" shaped intake piece in the engine compartment.
Below the starter, near the original mechanical fuel pump location, there should be a square opening just like your location number 1, but 6-8" lower. Make sure you have this hole*
(Left piece in the photo)
I think someone ran a wire through your engine hole #1, so it's unlikely you have this piece, but you'll want it to connect the engine compartment hole to the hot cylinder head area down low without letting dirt in the engine bay:
Once you have all the factory bits reinstalled, your fuel line replaced with something newer and safer, a paper hose is all that's needed to get most progressives to smooth out in the summer. In winter it's nice to wrap the whole filter so only preheated air comes in.
Good luck,
Robbie _________________ WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Posted: Wed Oct 15, 2025 8:40 am Post subject: Re: Progressive carb preheat modification |
You can't see the piece very well, but I made a flange that fit the holes and then welded a piece of thinwall tubing to it and use a somewhat flexible hose to make the connection. I also adapted the aircleaner from a circa 1975 Datsun-Nissan pickup to serve as an aircleaner, doing so allows the inlet air temperature to be lessened during hot weather.
I also dump the crankcase fumes into the lid of the air cleaner directly above the throat of the carburetor which keeps the oily mist from getting all over the inside of the aircleaner housing and making a mess. Going into the top gives the PCV hose addition slope so it drains well instead of clogging up with engine snot during cold weather.
aeromech Samba Member
Joined: January 24, 2006 Posts: 17784 Location: San Diego, California
Posted: Thu Oct 16, 2025 10:26 am Post subject: Re: Progressive carb preheat modification |
Good luck with your science project. I’d love to see this carburetor icing issue defeated in a cleanly installed and well thought out way. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2806 Location: Plattsburgh, New York
Posted: Thu Oct 16, 2025 1:09 pm Post subject: Re: Progressive carb preheat modification |
I ran this carb for a couple years without doing much to set it up. I think it can be made workable with preheat and some other mods. I like its simplicity. The stock dual carbs are wonderful, but it’s tough keeping up with all the hoses, elbows and wires. Hard to get that stuff to stay put and remain intact.
The part about preheat is how you would turn it off so it wouldn’t suck hot air when the engine no longer needed it. |
Posted: Thu Oct 16, 2025 3:34 pm Post subject: Re: Progressive carb preheat modification |
| orwell84 wrote: |
Several cars sold in the early seventies just had lever that opened a vane with the season, which I image a lot of people never used. If one is just building a box around the carb a simple hole in the box that can be opened and closed with a cover plate as needed will do the job. Don't think this would be much of an issue until the ambient temperature passed 90°, as without a heat riser the carb is still going to be on the cool side due to the expansion of the intake air stream and the evaporation of the fuel. |
Posted: Thu Oct 16, 2025 3:55 pm Post subject: Re: Progressive carb preheat modification |
Carb ice doesn’t care what season it is _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 1033 Location: Eastern north carolina
Posted: Thu Oct 16, 2025 4:31 pm Post subject: Re: Progressive carb preheat modification |
| I am glad to see this carb getting some discussion as to how to solve one of the issues with it. I have read a number of posts on here just dismissing this carb as unsuitable for an air cooled VW. This carb has been used with very good results on numerous vehicles around the world . |
Posted: Thu Oct 16, 2025 4:51 pm Post subject: Re: Progressive carb preheat modification |
I’ll bet those vehicles had some sort of ducted warm air going down the carb throat.
We had a type 4 on my run stand with this carb. After it warmed up it began having a rough idle. You could grab any of the four intake runners and see that they were ice cold. We took a heat gun and warmed the runners. Surprise, the idle smoothed out. Take the heat away and very soon the poor idle returned. This was on a 70 degree day in San Diego. This is what we did on the test stand
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Oct 17, 2025 3:53 am Post subject: Re: Progressive carb preheat modification |
| Aeromech did you find that once the warm air was introduced to the air cleaner that the carb performed well overall, or were their other problems that surfaced with it?. Nice work thanks Bob |
Posted: Fri Oct 17, 2025 5:57 am Post subject: Re: Progressive carb preheat modification |
Yup. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3248 Location: South Benfleet, Essex, UK
Posted: Fri Oct 17, 2025 11:37 am Post subject: Re: Progressive carb preheat modification |
| airschooled wrote: |
Howdy,
Good luck,
Robbie |
The donut piece in the engine compartment, was for 1972~74 VW 1700 & 1800 Type 2's with twin Solex carburettors.
However, the VW 411/412 up to July 1972, with W-series & EA-series, VW 1700 Type 4 style air-cooled engines, Bosch D-Jetronic fuel injection & oil-bath air-cleaner, had a moulded black-plastic adapter (VW Part No. 022 119 623), with 53 mm diameter hose-connection spigot, about which you can learn more in the following topic thread:
Forum Index > 411/412 > Use of black-plastic, air-duct fitting of VW Part No. 022 119 623
https://www.thesamba.com/vw/forum/viewtopic.php?t=687613&highlight=
VW Type 4 style air-cooled engine, with fuel-injection, hot-air pre-heat hose-connection, Item 22
This might be better suited to the set-up of your centrally-mounted, single Webber twin-choke progressive carburettor.
Intake Air Pre-Heat Adapter 022-119-623 for Volkswagen Type 4 Engine | Classic Showcase Parts Store | US $25.00
https://www.ebay.com/itm/276721122935?msockid=223f26d409a766632a5c33ad08a167b6 _________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
Posted: Fri Oct 17, 2025 12:31 pm Post subject: Re: Progressive carb preheat modification |
Woah, I didn’t know that part existed. Super cool buy for anyone doing this on a progressive. Thanks Nigel!
www.airschooled.com
Posted: Fri Oct 17, 2025 12:38 pm Post subject: Re: Progressive carb preheat modification |
Question? By the time you’ve purchased a single progressive and now gone to great lengths to search the world for the above tinware, I’m thinking some dual Webers might be much easier. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3565 Location: Wyoming,USA
Posted: Sun Oct 19, 2025 8:40 am Post subject: Re: Progressive carb preheat modification |
| aeromech wrote: |
| Question? By the time you’ve purchased a single progressive and now gone to great lengths to search the world for the above tinware, I’m thinking some dual Webers might be much easier. |
Or dual SOLEX (Kadron). They are a super simple carb with good support from Kaddie Shack.I am running them on my 1776.With everything adjusted to Jeff’s specs, it runs quite well. It wasn’t without some pain though, all caused by my screw ups. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Sun Oct 19, 2025 8:46 am Post subject: Re: Progressive carb preheat modification |
Kads, I agree.
They ran well on this newly rebuilt engine in a 1974 bus
On display at the San Diego Automotive Museum _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun Oct 19, 2025 9:01 am Post subject: Re: Progressive carb preheat modification |
Damn! Nice looking bus! _________________ If you haven't bled on them, you haven't worked on them.
Posted: Sun Oct 19, 2025 9:13 am Post subject: Re: Progressive carb preheat modification |
Thanks but I can’t claim all of the credit. It was already very nice before it got to me. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun Oct 19, 2025 12:51 pm Post subject: Re: Progressive carb preheat modification |
Robbie |
What would it have been used on though? a Zamboni? |
